Not connected, Your IP: 216.73.216.54
Flx
Guide---Multi Session/Tunnel---TCP/UDP---Windows OS & Comodo scenario Native OpenVPN 2.5 Wintun adapters---
Easy-Way:
Comodo configuration files(links below)
Windows 7 config file
https://airvpn.org/forums/topic/17440-guide-fix-for-tap-adapter-in-windows/page/3/?tab=comments#comment-106650
Windows 10 config file
https://airvpn.org/forums/topic/17440-guide-fix-for-tap-adapter-in-windows/page/3/?tab=comments#comment-109051
How-to:(link below)
https://airvpn.org/forums/topic/17440-guide-fix-for-tap-adapter-in-windows/page/3/?tab=comments#comment-109909
Other details:
1.Install a few extra Wintun adapters:
--------Open a cmd.exe window Run-as-Admin---install.wintun.bat---
cd \
cd Program Files
cd OpenVPN
cd bin
tapctl.exe create --hwid wintun
Or
Copy and Paste "tapctl.exe create --hwid wintun" in your cmd.exe window Run As Admin
Repeat the above until you install the 4 or 5 wintun adapters required.
2.Comodo Firewall Ruleset for OpenVPN Multisession scenario:
Apply it to both openvpn.exe and openvpn-gui.exe files in Comodo under "Application Rules".
3.After you have created and imported the necessary yourairvpn.ovpn files (key1_port443 key2_port80 key3_port53 key4_port41185 etc.) in OpenVPN-GUI.
4. Command-line: Script for command-line client to server connection(2.5_git version)
Open 3 cmd.exe windows by Right-click the multi.bat file and "Run as Admin".
AFTER you have imported yourairvpn.ovpn profiles.
5. OpenVPN-GUI(2.5 version)
Right click on your Taskbar icon OpenVPN-GUI and you will see there the profiles imported.
On each profile click Connect and wait for it to establish a connect to server; then Click "Show Status".
Re-do the above; for each NEW session/tunnel you wish to create on a different key.
6.Most "suggested/preferred" double or triple session!
7. Don't forget:
Modify/Change your config profiles to work for wintun mode!
------buffersize------
rcvbuf 562144
sndbuf 562144
windows-driver wintun
Next:
Block all your interfaces other than VPN/TAP and apply this to browsers/torrent clients under "Application Rules".
ONLY allows for data transfer/traffic over VPN established tunnels/sessions.
and:
Segment your airvpn.ip-range properly.
8. Errors that you may encounter:
Windows Smart screen may block the multi.bat and/or install.wintun.bat file.
Comodo will/may block the install.wintun.bat and/or multi.bat as well. Switch it from "Unrecognized" to "Trusted" in Comodo-->>File List
NOTE:
This is NOT an "out-of-the-box" concept. All this is provided AS IS.(files/examples etc.)
Regards,
Flx
multi.zip
Server-side port(s) assigned that you define in/for each of your yourairvpn.ovpn:
remote-random
remote xxx.xxx.xxx.xxx 80
remote xxx.xxx.xxx.xxx 443
remote xxx.xxx.xxx.xxx 2018
remote xxx.xxx.xxx.xxx 41185
For more on TCP/UDP ports check out the Specs page.(Protocols and entry-IP addresses of each VPN server).
Another sort of error encountered and connection fails due to "ring-buffers":
OpenVPN looks for the first installed Wintun adapter.
1. Disable the first installed Wintun Adapter. Now connect to server on a different/next Profile Imported (e.g. AIrVPN profile2) . Let it connect.
2. Re-enable the first installed Wintun Adapter. Now try connect to server on (e.g. AirVPN profile1), which will use the first installed Wintun Adapter you have just re-enabled.
Now it will work.
Happy browsing and Stay Safe.
