Disarray 0 Posted ... My setup: Windows 7 ultimate 32-bit I'm having issues using AirVPN over TOR, this is my setup: 1. Connect to TOR Browser 2. Enable SOCKS proxy in AirVPN on 127.0.0.1 with port 9050 However, when I try to connect to a server in AirVPN, it fails to connect. Anyone know the issue? Thank you Quote Share this post Link to post
Staff 10307 Posted ... My setup: Windows 7 ultimate 32-bitI'm having issues using AirVPN over TOR, this is my setup:1. Connect to TOR Browser2. Enable SOCKS proxy in AirVPN on 127.0.0.1 with port 9050However, when I try to connect to a server in AirVPN, it fails to connect.Anyone know the issue?Thank youHello!Can you please send us your client logs?Kind regards Quote Share this post Link to post
androgent 0 Posted ... HI I am having a similar problem but on Mountain Lion. I connect to Tor no problem and I use tunnelblick to connect to airvpn through tor. It will connect but then I can not receive any traffic after it has connected. Do you think that once I am connnected to you, then tor itself tries to access the internet through tunnelblick and this causes some sort of loop? Please help! Quote Share this post Link to post
