Not connected, Your IP: 3.21.97.61
Woah, what the hell happened there? Are you running some security software by any chance?
10 hours ago, Flx said:
64 TAP adapters WOW.
Did you install them manually or Eddie installed them for you?
it had to be Eddie. While I was trying to get Eddie to work I had to reinstall the driver several times, but not 64 times. And I had removed a bunch of the extra ones already.
