Denise6363 1 Posted ... Please i'm using port forwarding features and i realize that my tun0 IP address was set randomly, how can i make it static, including my public IP Share this post Link to post
Tech Jedi Alex 1513 Posted ... Public IP depends on the AirVPN server. If you connect to the same server, that IP will never change. There is no way of setting a tunnel IP static. Though if you disconnect from a server and then reconnect with the same port and protocol within a short time frame, chances are you will get the same. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Denise6363 1 Posted ... You mean if i connect to Austin, TX..... with exit ip 11.11.11.22 if i'm still connecting with the same location my exit IP will never be change????? or else i manually go to severs tab and choose new server right ??? Share this post Link to post
Tech Jedi Alex 1513 Posted ... 36 minutes ago, Denise6363 said: if i'm still connecting with the same location my exit IP will never be change????? Yes, exactly. You can even change ports or the protocol, the IP will be the same, as long as you connect to the same server. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
