dabslab
Keeps restarting won't connect
Hello All,
 Was on the vpn last night no problem went to connect today and just keep getting restart wheel. Any suggestions? ive uninstalled reinstalled already.
Eddie System/Environment Report - 7/14/2020 - 7:33 PM UTC
Eddie version: 2.18.9
Eddie OS build: windows_x64
Eddie architecture: x64
OS type: Windows
OS name: Windows 10 Pro
OS version: Microsoft Windows NT 10.0.18363.0
OS architecture: x64
Mono /.Net Framework: v4.0.30319
TUN driver: 0901: 9.24.2; wintun: Not found
OpenVPN: 2.4.8 - OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
Hummingbird:  ()
SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
curl: 7.68.0 (C:\Program Files\AirVPN\curl.exe)
Profile path: C:\Users\mouse\AppData\Local\Eddie\default.profile
Data path: C:\Users\mouse\AppData\Local\Eddie
Application path: C:\Program Files\AirVPN
Executable path: C:\Program Files\AirVPN\Eddie-UI.exe
Command line arguments: (1 args) path="home"
Network Lock Active: No
Connected to VPN: No
Detected DNS: 10.31.122.1, 192.168.0.1, fde6:7a:7d20:1b7a::1
Test DNS IPv4: Ok
Test DNS IPv6: Ok
Test Ping IPv4: 134 ms
Test Ping IPv6: 149 ms
Test HTTP IPv4: Ok
Test HTTP IPv6: Ok
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
servers.whitelist: 62c16fac11b3d779c62e5144b222534283e9221ab6e05b401182b341bc8c9ff1
Logs:
. 2020.07.14 15:16:06 - Eddie version: 2.18.9 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: Microsoft Windows NT 10.0.18363.0, Mono/.Net: v4.0.30319
. 2020.07.14 15:16:06 - Command line arguments (1): path="home"
. 2020.07.14 15:16:08 - Raise system privileges
. 2020.07.14 15:16:15 - Profile path: C:\Users\mouse\AppData\Local\Eddie\default.profile
. 2020.07.14 15:16:15 - Reading options from C:\Users\mouse\AppData\Local\Eddie\default.profile
. 2020.07.14 15:16:18 - Tun Driver - 0901: 9.24.2; wintun: Not found
. 2020.07.14 15:16:18 - OpenVPN - Version: 2.4.8 - OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2020.07.14 15:16:18 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2020.07.14 15:16:18 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2020.07.14 15:16:18 - curl - Version: 7.68.0 (C:\Program Files\AirVPN\curl.exe)
. 2020.07.14 15:16:19 - Recovery. Unexpected crash?
. 2020.07.14 15:16:19 - Routes, added a new route, 184.75.221.195 for gateway 10.31.122.1
. 2020.07.14 15:16:19 - Routes, added a new route, 2606:6080:1001:15:45d:2b31:f931:2e2 for gateway fde6:7a:7d20:1b7a::1
I 2020.07.14 15:16:20 - Ready
. 2020.07.14 15:16:21 - Collect information about AirVPN completed
I 2020.07.14 15:16:24 - Session starting.
I 2020.07.14 15:16:25 - Checking authorization ...
! 2020.07.14 15:16:26 - Connecting to Saiph (Canada, Toronto, Ontario)
. 2020.07.14 15:16:26 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.14 15:16:26 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.14 15:16:26 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.14 15:16:26 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:16:26 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:16:26 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:16:26 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:16:26 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.229:443
. 2020.07.14 15:16:26 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.14 15:16:26 - OpenVPN > UDP link local: (not bound)
. 2020.07.14 15:16:26 - OpenVPN > UDP link remote: [AF_INET]184.75.223.229:443
. 2020.07.14 15:16:26 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.229:443, sid=04efe481 6703a1a8
. 2020.07.14 15:16:26 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.14 15:16:26 - OpenVPN > VERIFY KU OK
. 2020.07.14 15:16:26 - OpenVPN > Validating certificate extended key usage
. 2020.07.14 15:16:26 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.14 15:16:26 - OpenVPN > VERIFY EKU OK
. 2020.07.14 15:16:26 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saiph, emailAddress=info@airvpn.org
. 2020.07.14 15:16:26 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.14 15:16:26 - OpenVPN > [Saiph] Peer Connection Initiated with [AF_INET]184.75.223.229:443
. 2020.07.14 15:16:28 - OpenVPN > SENT CONTROL [Saiph]: 'PUSH_REQUEST' (status=1)
. 2020.07.14 15:16:28 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.230.1,dhcp-option DNS6 fde6:7a:7d20:18e6::1,tun-ipv6,route-gateway 10.28.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:18e6::1080/64 fde6:7a:7d20:18e6::1,ifconfig 10.28.230.130 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2020.07.14 15:16:28 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.14 15:16:28 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.14 15:16:28 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.14 15:16:28 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.14 15:16:28 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.14 15:16:28 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.14 15:16:28 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.14 15:16:28 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.14 15:16:28 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.14 15:16:28 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.14 15:16:28 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:16:28 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:16:28 - OpenVPN > interactive service msg_channel=0
. 2020.07.14 15:16:28 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=10 HWADDR=d0:50:99:ab:1d:38
. 2020.07.14 15:16:28 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.14 15:16:28 - OpenVPN > GetBestInterfaceEx() returned if=24
. 2020.07.14 15:16:28 - OpenVPN > GDG6: II=24 DP=::/3 NH=fe80::8
. 2020.07.14 15:16:28 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.14 15:16:28 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=24
. 2020.07.14 15:16:28 - OpenVPN > open_tun
. 2020.07.14 15:16:28 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{18975750-849F-4D50-898E-DE8038EA33C3}.tap
. 2020.07.14 15:16:28 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.14 15:16:28 - OpenVPN > Exiting due to fatal error
! 2020.07.14 15:16:28 - Disconnecting
. 2020.07.14 15:16:28 - Connection terminated.
I 2020.07.14 15:16:30 - Cancel requested.
! 2020.07.14 15:16:30 - Session terminated.
! 2020.07.14 15:23:10 - Logged out.
I 2020.07.14 15:23:12 - Checking login ...
! 2020.07.14 15:23:13 - Logged in.
I 2020.07.14 15:23:15 - Session starting.
I 2020.07.14 15:23:16 - Checking authorization ...
! 2020.07.14 15:23:16 - Connecting to Saiph (Canada, Toronto, Ontario)
. 2020.07.14 15:23:16 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.14 15:23:17 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.14 15:23:17 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.14 15:23:17 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:23:17 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:23:17 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:23:17 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:23:17 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.229:443
. 2020.07.14 15:23:17 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.14 15:23:17 - OpenVPN > UDP link local: (not bound)
. 2020.07.14 15:23:17 - OpenVPN > UDP link remote: [AF_INET]184.75.223.229:443
. 2020.07.14 15:23:17 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.229:443, sid=68ca656c 6990260c
. 2020.07.14 15:23:17 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.14 15:23:17 - OpenVPN > VERIFY KU OK
. 2020.07.14 15:23:17 - OpenVPN > Validating certificate extended key usage
. 2020.07.14 15:23:17 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.14 15:23:17 - OpenVPN > VERIFY EKU OK
. 2020.07.14 15:23:17 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saiph, emailAddress=info@airvpn.org
. 2020.07.14 15:23:17 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.14 15:23:17 - OpenVPN > [Saiph] Peer Connection Initiated with [AF_INET]184.75.223.229:443
. 2020.07.14 15:23:18 - OpenVPN > SENT CONTROL [Saiph]: 'PUSH_REQUEST' (status=1)
. 2020.07.14 15:23:18 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.230.1,dhcp-option DNS6 fde6:7a:7d20:18e6::1,tun-ipv6,route-gateway 10.28.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:18e6::1080/64 fde6:7a:7d20:18e6::1,ifconfig 10.28.230.130 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2020.07.14 15:23:18 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.14 15:23:18 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.14 15:23:18 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.14 15:23:18 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.14 15:23:18 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.14 15:23:18 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.14 15:23:18 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.14 15:23:18 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.14 15:23:18 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.14 15:23:18 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.14 15:23:18 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:23:18 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:23:18 - OpenVPN > interactive service msg_channel=0
. 2020.07.14 15:23:18 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=10 HWADDR=d0:50:99:ab:1d:38
. 2020.07.14 15:23:18 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.14 15:23:18 - OpenVPN > GetBestInterfaceEx() returned if=24
. 2020.07.14 15:23:18 - OpenVPN > GDG6: II=24 DP=::/3 NH=fe80::8
. 2020.07.14 15:23:18 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.14 15:23:18 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=24
. 2020.07.14 15:23:18 - OpenVPN > open_tun
. 2020.07.14 15:23:18 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{18975750-849F-4D50-898E-DE8038EA33C3}.tap
. 2020.07.14 15:23:18 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.14 15:23:18 - OpenVPN > Exiting due to fatal error
! 2020.07.14 15:23:18 - Disconnecting
. 2020.07.14 15:23:18 - Connection terminated.
I 2020.07.14 15:23:21 - Cancel requested.
! 2020.07.14 15:23:21 - Session terminated.
! 2020.07.14 15:25:13 - Activation of Network Lock - Windows Filtering Platform
I 2020.07.14 15:25:20 - Session starting.
I 2020.07.14 15:25:20 - Checking authorization ...
W 2020.07.14 15:26:41 - Authorization check failed, continue anyway (curl: (28) Connection timed out after 20000 milliseconds)
! 2020.07.14 15:26:41 - Connecting to Saiph (Canada, Toronto, Ontario)
. 2020.07.14 15:26:41 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.14 15:26:41 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.14 15:26:41 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.14 15:26:41 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:26:41 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:26:41 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:26:41 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:26:41 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.229:443
. 2020.07.14 15:26:41 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.14 15:26:41 - OpenVPN > UDP link local: (not bound)
. 2020.07.14 15:26:41 - OpenVPN > UDP link remote: [AF_INET]184.75.223.229:443
. 2020.07.14 15:26:55 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.229:443, sid=e1abfbe5 c7a4475a
. 2020.07.14 15:26:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.14 15:26:55 - OpenVPN > VERIFY KU OK
. 2020.07.14 15:26:55 - OpenVPN > Validating certificate extended key usage
. 2020.07.14 15:26:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.14 15:26:56 - OpenVPN > VERIFY EKU OK
. 2020.07.14 15:26:56 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saiph, emailAddress=info@airvpn.org
. 2020.07.14 15:26:56 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.14 15:26:56 - OpenVPN > [Saiph] Peer Connection Initiated with [AF_INET]184.75.223.229:443
. 2020.07.14 15:26:57 - OpenVPN > SENT CONTROL [Saiph]: 'PUSH_REQUEST' (status=1)
. 2020.07.14 15:26:57 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.230.1,dhcp-option DNS6 fde6:7a:7d20:18e6::1,tun-ipv6,route-gateway 10.28.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:18e6::1080/64 fde6:7a:7d20:18e6::1,ifconfig 10.28.230.130 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2020.07.14 15:26:57 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.14 15:26:57 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.14 15:26:57 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.14 15:26:57 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.14 15:26:57 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.14 15:26:57 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.14 15:26:57 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.14 15:26:57 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.14 15:26:57 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.14 15:26:57 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.14 15:26:57 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:26:57 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:26:57 - OpenVPN > interactive service msg_channel=0
. 2020.07.14 15:26:57 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=10 HWADDR=d0:50:99:ab:1d:38
. 2020.07.14 15:26:57 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.14 15:26:57 - OpenVPN > GetBestInterfaceEx() returned if=24
. 2020.07.14 15:26:57 - OpenVPN > GDG6: II=24 DP=::/3 NH=fe80::8
. 2020.07.14 15:26:57 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.14 15:26:57 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=24
. 2020.07.14 15:26:57 - OpenVPN > open_tun
. 2020.07.14 15:26:57 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{18975750-849F-4D50-898E-DE8038EA33C3}.tap
. 2020.07.14 15:26:57 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.14 15:26:57 - OpenVPN > Exiting due to fatal error
! 2020.07.14 15:26:57 - Disconnecting
. 2020.07.14 15:26:57 - Connection terminated.
I 2020.07.14 15:27:00 - Cancel requested.
! 2020.07.14 15:27:00 - Session terminated.
! 2020.07.14 15:27:02 - Deactivation of Network Lock
I 2020.07.14 15:27:05 - Session starting.
I 2020.07.14 15:27:06 - Checking authorization ...
! 2020.07.14 15:27:06 - Connecting to Saiph (Canada, Toronto, Ontario)
. 2020.07.14 15:27:06 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.14 15:27:06 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.14 15:27:06 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.14 15:27:06 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:27:06 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:27:06 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:27:06 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:27:06 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.229:443
. 2020.07.14 15:27:06 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.14 15:27:06 - OpenVPN > UDP link local: (not bound)
. 2020.07.14 15:27:06 - OpenVPN > UDP link remote: [AF_INET]184.75.223.229:443
. 2020.07.14 15:27:06 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.229:443, sid=1daf1518 515a79b0
. 2020.07.14 15:27:07 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.14 15:27:07 - OpenVPN > VERIFY KU OK
. 2020.07.14 15:27:07 - OpenVPN > Validating certificate extended key usage
. 2020.07.14 15:27:07 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.14 15:27:07 - OpenVPN > VERIFY EKU OK
. 2020.07.14 15:27:07 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saiph, emailAddress=info@airvpn.org
. 2020.07.14 15:27:07 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.14 15:27:07 - OpenVPN > [Saiph] Peer Connection Initiated with [AF_INET]184.75.223.229:443
. 2020.07.14 15:27:08 - OpenVPN > SENT CONTROL [Saiph]: 'PUSH_REQUEST' (status=1)
. 2020.07.14 15:27:08 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.230.1,dhcp-option DNS6 fde6:7a:7d20:18e6::1,tun-ipv6,route-gateway 10.28.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:18e6::1080/64 fde6:7a:7d20:18e6::1,ifconfig 10.28.230.130 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2020.07.14 15:27:08 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.14 15:27:08 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.14 15:27:08 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.14 15:27:08 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.14 15:27:08 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.14 15:27:08 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.14 15:27:08 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.14 15:27:08 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.14 15:27:08 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.14 15:27:08 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.14 15:27:08 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:27:08 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:27:08 - OpenVPN > interactive service msg_channel=0
. 2020.07.14 15:27:08 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=10 HWADDR=d0:50:99:ab:1d:38
. 2020.07.14 15:27:08 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.14 15:27:08 - OpenVPN > GetBestInterfaceEx() returned if=24
. 2020.07.14 15:27:08 - OpenVPN > GDG6: II=24 DP=::/3 NH=fe80::8
. 2020.07.14 15:27:08 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.14 15:27:08 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=24
. 2020.07.14 15:27:08 - OpenVPN > open_tun
. 2020.07.14 15:27:08 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{18975750-849F-4D50-898E-DE8038EA33C3}.tap
. 2020.07.14 15:27:08 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.14 15:27:08 - OpenVPN > Exiting due to fatal error
! 2020.07.14 15:27:08 - Disconnecting
. 2020.07.14 15:27:08 - Connection terminated.
I 2020.07.14 15:27:11 - Checking authorization ...
! 2020.07.14 15:27:12 - Connecting to Saiph (Canada, Toronto, Ontario)
. 2020.07.14 15:27:12 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.14 15:27:12 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.14 15:27:12 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.14 15:27:12 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:27:12 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:27:12 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:27:12 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:27:12 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.229:443
. 2020.07.14 15:27:12 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.14 15:27:12 - OpenVPN > UDP link local: (not bound)
. 2020.07.14 15:27:12 - OpenVPN > UDP link remote: [AF_INET]184.75.223.229:443
. 2020.07.14 15:27:12 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.229:443, sid=b684c031 582d611f
! 2020.07.14 15:27:12 - Disconnecting
. 2020.07.14 15:27:12 - Sending soft termination signal
. 2020.07.14 15:27:15 - Connection terminated.
. 2020.07.14 15:27:15 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2020.07.14 15:27:15 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.14 15:27:15 - OpenVPN > VERIFY KU OK
. 2020.07.14 15:27:15 - OpenVPN > Validating certificate extended key usage
. 2020.07.14 15:27:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.14 15:27:15 - OpenVPN > VERIFY EKU OK
. 2020.07.14 15:27:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saiph, emailAddress=info@airvpn.org
W 2020.07.14 15:27:15 - Object reference not set to an instance of an object.
. 2020.07.14 15:27:15 - Above log line repeated 1 times more
. 2020.07.14 15:27:15 - OpenVPN > SENT CONTROL [Saiph]: 'PUSH_REQUEST' (status=1)
. 2020.07.14 15:27:15 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.230.1,dhcp-option DNS6 fde6:7a:7d20:18e6::1,tun-ipv6,route-gateway 10.28.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:18e6::1080/64 fde6:7a:7d20:18e6::1,ifconfig 10.28.230.130 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2020.07.14 15:27:15 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.14 15:27:15 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.14 15:27:15 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.14 15:27:15 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.14 15:27:15 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.14 15:27:15 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.14 15:27:15 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.14 15:27:15 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.14 15:27:15 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.14 15:27:15 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.14 15:27:15 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:27:15 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:27:15 - OpenVPN > interactive service msg_channel=0
. 2020.07.14 15:27:15 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=10 HWADDR=d0:50:99:ab:1d:38
. 2020.07.14 15:27:15 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.14 15:27:15 - OpenVPN > GetBestInterfaceEx() returned if=24
. 2020.07.14 15:27:15 - OpenVPN > GDG6: II=24 DP=::/3 NH=fe80::8
. 2020.07.14 15:27:15 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.14 15:27:15 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=24
. 2020.07.14 15:27:15 - OpenVPN > open_tun
. 2020.07.14 15:27:15 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{18975750-849F-4D50-898E-DE8038EA33C3}.tap
. 2020.07.14 15:27:15 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.14 15:27:15 - OpenVPN > Exiting due to fatal error
I 2020.07.14 15:27:15 - Cancel requested.
! 2020.07.14 15:27:15 - Session terminated.
I 2020.07.14 15:27:17 - Session starting.
I 2020.07.14 15:27:17 - Checking authorization ...
! 2020.07.14 15:27:18 - Connecting to Saiph (Canada, Toronto, Ontario)
. 2020.07.14 15:27:18 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.14 15:27:18 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.14 15:27:18 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.14 15:27:18 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:27:18 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:27:18 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:27:18 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:27:18 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.229:443
. 2020.07.14 15:27:18 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.14 15:27:18 - OpenVPN > UDP link local: (not bound)
. 2020.07.14 15:27:18 - OpenVPN > UDP link remote: [AF_INET]184.75.223.229:443
. 2020.07.14 15:27:18 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.229:443, sid=ae293ae1 6f0e94be
. 2020.07.14 15:27:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.14 15:27:18 - OpenVPN > VERIFY KU OK
. 2020.07.14 15:27:18 - OpenVPN > Validating certificate extended key usage
. 2020.07.14 15:27:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.14 15:27:18 - OpenVPN > VERIFY EKU OK
. 2020.07.14 15:27:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saiph, emailAddress=info@airvpn.org
. 2020.07.14 15:27:19 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.14 15:27:19 - OpenVPN > [Saiph] Peer Connection Initiated with [AF_INET]184.75.223.229:443
. 2020.07.14 15:27:20 - OpenVPN > SENT CONTROL [Saiph]: 'PUSH_REQUEST' (status=1)
. 2020.07.14 15:27:20 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.230.1,dhcp-option DNS6 fde6:7a:7d20:18e6::1,tun-ipv6,route-gateway 10.28.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:18e6::1080/64 fde6:7a:7d20:18e6::1,ifconfig 10.28.230.130 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2020.07.14 15:27:20 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.14 15:27:20 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.14 15:27:20 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.14 15:27:20 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.14 15:27:20 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.14 15:27:20 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.14 15:27:20 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.14 15:27:20 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.14 15:27:20 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.14 15:27:20 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.14 15:27:20 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:27:20 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:27:20 - OpenVPN > interactive service msg_channel=0
. 2020.07.14 15:27:20 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=10 HWADDR=d0:50:99:ab:1d:38
. 2020.07.14 15:27:20 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.14 15:27:20 - OpenVPN > GetBestInterfaceEx() returned if=24
. 2020.07.14 15:27:20 - OpenVPN > GDG6: II=24 DP=::/3 NH=fe80::8
. 2020.07.14 15:27:20 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.14 15:27:20 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=24
. 2020.07.14 15:27:20 - OpenVPN > open_tun
. 2020.07.14 15:27:20 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{18975750-849F-4D50-898E-DE8038EA33C3}.tap
. 2020.07.14 15:27:20 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.14 15:27:20 - OpenVPN > Exiting due to fatal error
! 2020.07.14 15:27:20 - Disconnecting
. 2020.07.14 15:27:20 - Connection terminated.
I 2020.07.14 15:27:23 - Checking authorization ...
! 2020.07.14 15:27:24 - Connecting to Saiph (Canada, Toronto, Ontario)
. 2020.07.14 15:27:24 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.14 15:27:24 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.14 15:27:24 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.14 15:27:24 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:27:24 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:27:24 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:27:24 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:27:24 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.229:443
. 2020.07.14 15:27:24 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.14 15:27:24 - OpenVPN > UDP link local: (not bound)
. 2020.07.14 15:27:24 - OpenVPN > UDP link remote: [AF_INET]184.75.223.229:443
. 2020.07.14 15:27:24 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.229:443, sid=33881e09 7c77b772
. 2020.07.14 15:27:24 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.14 15:27:24 - OpenVPN > VERIFY KU OK
. 2020.07.14 15:27:24 - OpenVPN > Validating certificate extended key usage
. 2020.07.14 15:27:24 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.14 15:27:24 - OpenVPN > VERIFY EKU OK
. 2020.07.14 15:27:24 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saiph, emailAddress=info@airvpn.org
. 2020.07.14 15:27:24 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.14 15:27:24 - OpenVPN > [Saiph] Peer Connection Initiated with [AF_INET]184.75.223.229:443
. 2020.07.14 15:27:26 - OpenVPN > SENT CONTROL [Saiph]: 'PUSH_REQUEST' (status=1)
. 2020.07.14 15:27:26 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.230.1,dhcp-option DNS6 fde6:7a:7d20:18e6::1,tun-ipv6,route-gateway 10.28.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:18e6::1080/64 fde6:7a:7d20:18e6::1,ifconfig 10.28.230.130 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2020.07.14 15:27:26 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.14 15:27:26 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.14 15:27:26 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.14 15:27:26 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.14 15:27:26 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.14 15:27:26 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.14 15:27:26 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.14 15:27:26 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.14 15:27:26 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.14 15:27:26 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.14 15:27:26 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:27:26 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:27:26 - OpenVPN > interactive service msg_channel=0
. 2020.07.14 15:27:26 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=10 HWADDR=d0:50:99:ab:1d:38
. 2020.07.14 15:27:26 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.14 15:27:26 - OpenVPN > GetBestInterfaceEx() returned if=24
. 2020.07.14 15:27:26 - OpenVPN > GDG6: II=24 DP=::/3 NH=fe80::8
. 2020.07.14 15:27:26 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.14 15:27:26 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=24
. 2020.07.14 15:27:26 - OpenVPN > open_tun
. 2020.07.14 15:27:26 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{18975750-849F-4D50-898E-DE8038EA33C3}.tap
. 2020.07.14 15:27:26 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.14 15:27:26 - OpenVPN > Exiting due to fatal error
! 2020.07.14 15:27:26 - Disconnecting
. 2020.07.14 15:27:26 - Connection terminated.
I 2020.07.14 15:27:28 - Cancel requested.
! 2020.07.14 15:27:28 - Session terminated.
! 2020.07.14 15:28:44 - Activation of Network Lock - Windows Filtering Platform
I 2020.07.14 15:29:21 - Session starting.
I 2020.07.14 15:29:22 - Checking authorization ...
W 2020.07.14 15:30:42 - Authorization check failed, continue anyway (curl: (28) Connection timed out after 20001 milliseconds)
I 2020.07.14 15:30:42 - Cancel requested.
! 2020.07.14 15:30:42 - Session terminated.
! 2020.07.14 15:30:50 - Deactivation of Network Lock
I 2020.07.14 15:30:52 - Session starting.
I 2020.07.14 15:30:53 - Checking authorization ...
! 2020.07.14 15:30:57 - Connecting to Saiph (Canada, Toronto, Ontario)
. 2020.07.14 15:30:57 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.14 15:30:57 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.14 15:30:57 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.14 15:30:57 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:30:57 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:30:57 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:30:57 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:30:57 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.229:443
. 2020.07.14 15:30:57 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.14 15:30:57 - OpenVPN > UDP link local: (not bound)
. 2020.07.14 15:30:57 - OpenVPN > UDP link remote: [AF_INET]184.75.223.229:443
. 2020.07.14 15:30:57 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.229:443, sid=4ad8bb8c 2ec7c949
. 2020.07.14 15:30:57 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.14 15:30:57 - OpenVPN > VERIFY KU OK
. 2020.07.14 15:30:57 - OpenVPN > Validating certificate extended key usage
. 2020.07.14 15:30:57 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.14 15:30:57 - OpenVPN > VERIFY EKU OK
. 2020.07.14 15:30:57 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saiph, emailAddress=info@airvpn.org
. 2020.07.14 15:30:58 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.14 15:30:58 - OpenVPN > [Saiph] Peer Connection Initiated with [AF_INET]184.75.223.229:443
. 2020.07.14 15:30:59 - OpenVPN > SENT CONTROL [Saiph]: 'PUSH_REQUEST' (status=1)
. 2020.07.14 15:30:59 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.230.1,dhcp-option DNS6 fde6:7a:7d20:18e6::1,tun-ipv6,route-gateway 10.28.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:18e6::1080/64 fde6:7a:7d20:18e6::1,ifconfig 10.28.230.130 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2020.07.14 15:30:59 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.14 15:30:59 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.14 15:30:59 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.14 15:30:59 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.14 15:30:59 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.14 15:30:59 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.14 15:30:59 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.14 15:30:59 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.14 15:30:59 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.14 15:30:59 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.14 15:30:59 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:30:59 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:30:59 - OpenVPN > interactive service msg_channel=0
. 2020.07.14 15:30:59 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=10 HWADDR=d0:50:99:ab:1d:38
. 2020.07.14 15:30:59 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.14 15:30:59 - OpenVPN > GetBestInterfaceEx() returned if=24
. 2020.07.14 15:30:59 - OpenVPN > GDG6: II=24 DP=::/3 NH=fe80::8
. 2020.07.14 15:30:59 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.14 15:30:59 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=24
. 2020.07.14 15:30:59 - OpenVPN > open_tun
. 2020.07.14 15:30:59 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{18975750-849F-4D50-898E-DE8038EA33C3}.tap
. 2020.07.14 15:30:59 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.14 15:30:59 - OpenVPN > Exiting due to fatal error
! 2020.07.14 15:30:59 - Disconnecting
. 2020.07.14 15:30:59 - Connection terminated.
I 2020.07.14 15:31:02 - Checking authorization ...
! 2020.07.14 15:31:02 - Connecting to Saiph (Canada, Toronto, Ontario)
. 2020.07.14 15:31:03 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.14 15:31:03 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.14 15:31:03 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.14 15:31:03 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:31:03 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:31:03 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:31:03 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:31:03 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.229:443
. 2020.07.14 15:31:03 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.14 15:31:03 - OpenVPN > UDP link local: (not bound)
. 2020.07.14 15:31:03 - OpenVPN > UDP link remote: [AF_INET]184.75.223.229:443
. 2020.07.14 15:31:03 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.229:443, sid=ae4d4aa8 d712c131
. 2020.07.14 15:31:03 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.14 15:31:03 - OpenVPN > VERIFY KU OK
. 2020.07.14 15:31:03 - OpenVPN > Validating certificate extended key usage
. 2020.07.14 15:31:03 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.14 15:31:03 - OpenVPN > VERIFY EKU OK
. 2020.07.14 15:31:03 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saiph, emailAddress=info@airvpn.org
. 2020.07.14 15:31:03 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.14 15:31:03 - OpenVPN > [Saiph] Peer Connection Initiated with [AF_INET]184.75.223.229:443
. 2020.07.14 15:31:04 - OpenVPN > SENT CONTROL [Saiph]: 'PUSH_REQUEST' (status=1)
. 2020.07.14 15:31:05 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.230.1,dhcp-option DNS6 fde6:7a:7d20:18e6::1,tun-ipv6,route-gateway 10.28.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:18e6::1080/64 fde6:7a:7d20:18e6::1,ifconfig 10.28.230.130 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2020.07.14 15:31:05 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.14 15:31:05 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.14 15:31:05 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.14 15:31:05 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.14 15:31:05 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.14 15:31:05 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.14 15:31:05 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.14 15:31:05 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.14 15:31:05 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.14 15:31:05 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.14 15:31:05 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:31:05 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:31:05 - OpenVPN > interactive service msg_channel=0
. 2020.07.14 15:31:05 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=10 HWADDR=d0:50:99:ab:1d:38
. 2020.07.14 15:31:05 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.14 15:31:05 - OpenVPN > GetBestInterfaceEx() returned if=24
. 2020.07.14 15:31:05 - OpenVPN > GDG6: II=24 DP=::/3 NH=fe80::8
. 2020.07.14 15:31:05 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.14 15:31:05 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=24
. 2020.07.14 15:31:05 - OpenVPN > open_tun
. 2020.07.14 15:31:05 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{18975750-849F-4D50-898E-DE8038EA33C3}.tap
. 2020.07.14 15:31:05 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.14 15:31:05 - OpenVPN > Exiting due to fatal error
! 2020.07.14 15:31:05 - Disconnecting
. 2020.07.14 15:31:05 - Connection terminated.
I 2020.07.14 15:31:07 - Cancel requested.
! 2020.07.14 15:31:07 - Session terminated.
I 2020.07.14 15:31:10 - Session starting.
I 2020.07.14 15:31:11 - Checking authorization ...
! 2020.07.14 15:31:12 - Connecting to Saiph (Canada, Toronto, Ontario)
. 2020.07.14 15:31:12 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.14 15:31:12 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.14 15:31:12 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.14 15:31:12 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:31:12 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:31:12 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:31:12 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:31:12 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.229:443
. 2020.07.14 15:31:12 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.14 15:31:12 - OpenVPN > UDP link local: (not bound)
. 2020.07.14 15:31:12 - OpenVPN > UDP link remote: [AF_INET]184.75.223.229:443
. 2020.07.14 15:31:12 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.229:443, sid=6ffd54e1 85b7c48a
. 2020.07.14 15:31:12 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.14 15:31:12 - OpenVPN > VERIFY KU OK
. 2020.07.14 15:31:12 - OpenVPN > Validating certificate extended key usage
. 2020.07.14 15:31:12 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.14 15:31:12 - OpenVPN > VERIFY EKU OK
. 2020.07.14 15:31:12 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saiph, emailAddress=info@airvpn.org
. 2020.07.14 15:31:13 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.14 15:31:13 - OpenVPN > [Saiph] Peer Connection Initiated with [AF_INET]184.75.223.229:443
. 2020.07.14 15:31:14 - OpenVPN > SENT CONTROL [Saiph]: 'PUSH_REQUEST' (status=1)
. 2020.07.14 15:31:14 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.230.1,dhcp-option DNS6 fde6:7a:7d20:18e6::1,tun-ipv6,route-gateway 10.28.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:18e6::1080/64 fde6:7a:7d20:18e6::1,ifconfig 10.28.230.130 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2020.07.14 15:31:14 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.14 15:31:14 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.14 15:31:14 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.14 15:31:14 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.14 15:31:14 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.14 15:31:14 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.14 15:31:14 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.14 15:31:14 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.14 15:31:14 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.14 15:31:14 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.14 15:31:14 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:31:14 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:31:14 - OpenVPN > interactive service msg_channel=0
. 2020.07.14 15:31:14 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=10 HWADDR=d0:50:99:ab:1d:38
. 2020.07.14 15:31:14 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.14 15:31:14 - OpenVPN > GetBestInterfaceEx() returned if=24
. 2020.07.14 15:31:14 - OpenVPN > GDG6: II=24 DP=::/3 NH=fe80::8
. 2020.07.14 15:31:14 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.14 15:31:14 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=24
. 2020.07.14 15:31:14 - OpenVPN > open_tun
. 2020.07.14 15:31:14 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{18975750-849F-4D50-898E-DE8038EA33C3}.tap
. 2020.07.14 15:31:14 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.14 15:31:14 - OpenVPN > Exiting due to fatal error
! 2020.07.14 15:31:14 - Disconnecting
. 2020.07.14 15:31:14 - Connection terminated.
I 2020.07.14 15:31:17 - Checking authorization ...
! 2020.07.14 15:31:17 - Connecting to Saiph (Canada, Toronto, Ontario)
. 2020.07.14 15:31:18 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.14 15:31:18 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.14 15:31:18 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.14 15:31:18 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:31:18 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:31:18 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.14 15:31:18 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.14 15:31:18 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.229:443
. 2020.07.14 15:31:18 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.14 15:31:18 - OpenVPN > UDP link local: (not bound)
. 2020.07.14 15:31:18 - OpenVPN > UDP link remote: [AF_INET]184.75.223.229:443
. 2020.07.14 15:31:18 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.229:443, sid=2a8e9a80 56baae92
. 2020.07.14 15:31:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.14 15:31:18 - OpenVPN > VERIFY KU OK
. 2020.07.14 15:31:18 - OpenVPN > Validating certificate extended key usage
. 2020.07.14 15:31:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.14 15:31:18 - OpenVPN > VERIFY EKU OK
. 2020.07.14 15:31:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saiph, emailAddress=info@airvpn.org
. 2020.07.14 15:31:18 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.14 15:31:18 - OpenVPN > [Saiph] Peer Connection Initiated with [AF_INET]184.75.223.229:443
. 2020.07.14 15:31:19 - OpenVPN > SENT CONTROL [Saiph]: 'PUSH_REQUEST' (status=1)
. 2020.07.14 15:31:19 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.230.1,dhcp-option DNS6 fde6:7a:7d20:18e6::1,tun-ipv6,route-gateway 10.28.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:18e6::1080/64 fde6:7a:7d20:18e6::1,ifconfig 10.28.230.130 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2020.07.14 15:31:19 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.14 15:31:19 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.14 15:31:19 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.14 15:31:19 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.14 15:31:19 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.14 15:31:19 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.14 15:31:19 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.14 15:31:19 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.14 15:31:19 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.14 15:31:19 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.14 15:31:19 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:31:19 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.14 15:31:19 - OpenVPN > interactive service msg_channel=0
. 2020.07.14 15:31:19 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=10 HWADDR=d0:50:99:ab:1d:38
. 2020.07.14 15:31:19 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.14 15:31:19 - OpenVPN > GetBestInterfaceEx() returned if=24
. 2020.07.14 15:31:19 - OpenVPN > GDG6: II=24 DP=::/3 NH=fe80::8
. 2020.07.14 15:31:19 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.14 15:31:19 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=24
. 2020.07.14 15:31:20 - OpenVPN > open_tun
. 2020.07.14 15:31:20 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{18975750-849F-4D50-898E-DE8038EA33C3}.tap
. 2020.07.14 15:31:20 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.14 15:31:20 - OpenVPN > Exiting due to fatal error
! 2020.07.14 15:31:20 - Disconnecting
. 2020.07.14 15:31:20 - Connection terminated.
I 2020.07.14 15:31:22 - Cancel requested.
! 2020.07.14 15:31:22 - Session terminated.
Network Interfaces and Routes:
    "support_ipv4": true,
    "support_ipv6": true,
    "routes": [
            "address": "0.0.0.0\/0",
            "interface": "{BBFE85C6-2B65-4B6E-86EC-8D74193DC32B}",
            "gateway": "192.168.0.1",
            "metric": "35"
            "address": "0.0.0.0\/1",
            "interface": "{18975750-849F-4D50-898E-DE8038EA33C3}",
            "gateway": "10.31.122.1",
            "metric": "25"
            "address": "10.31.122.0\/24",
            "gateway": "link",
            "metric": "281"
            "address": "10.31.122.95",
            "gateway": "link",
            "metric": "281"
            "address": "10.31.122.255",
            "gateway": "link",
            "metric": "281"
            "address": "127.0.0.0\/8",
            "interface": "{6EDB8422-D3EE-11E7-AE97-806E6F6E6963}",
            "gateway": "link",
            "metric": "331"
            "address": "127.0.0.1",
            "gateway": "link",
            "metric": "331"
            "address": "127.255.255.255",
            "gateway": "link",
            "metric": "331"
            "address": "128.0.0.0\/1",
            "metric": "25"
            "address": "184.75.221.195",
            "metric": "26"
            "address": "184.75.221.197",
            "metric": "35"
            "address": "192.168.0.0\/24",
            "gateway": "link",
            "metric": "291"
            "address": "192.168.0.106",
            "gateway": "link",
            "metric": "291"
            "address": "192.168.0.255",
            "gateway": "link",
            "metric": "291"
            "address": "224.0.0.0\/4",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "291"
            "gateway": "link",
            "metric": "281"
            "address": "255.255.255.255",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "291"
            "gateway": "link",
            "metric": "281"
            "address": "::\/3",
            "gateway": "fe80::8",
            "metric": "281"
            "address": "::1",
            "gateway": "link",
            "metric": "331"
            "address": "2000::\/4",
            "metric": "281"
            "address": "2606:6080:1001:15:45d:2b31:f931:2e2",
            "gateway": "fde6:7a:7d20:1b7a::1",
            "metric": "281"
            "address": "3000::\/4",
            "metric": "281"
            "address": "fc00::\/7",
            "metric": "281"
            "address": "fde6:7a:7d20:1b7a::\/64",
            "metric": "281"
            "address": "fde6:7a:7d20:1b7a::105d",
            "gateway": "link",
            "metric": "281"
            "address": "fe80::\/64",
            "gateway": "link",
            "metric": "291"
            "gateway": "link",
            "metric": "281"
            "address": "fe80::3d5e:da6b:6894:a781",
            "gateway": "link",
            "metric": "281"
            "address": "fe80::f555:b2d3:4a6d:55c2",
            "gateway": "link",
            "metric": "291"
            "address": "ff00::\/8",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "291"
            "gateway": "link",
            "metric": "281"
            "metric": "4294967295"
    "interfaces": [
            "friendly": "Local Area Connection",
            "id": "{18975750-849F-4D50-898E-DE8038EA33C3}",
            "name": "Local Area Connection",
            "description": "TAP-Windows Adapter V9",
            "type": "53",
            "status": "Up",
            "bytes_received": "13822888339",
            "bytes_sent": "370032818",
            "ips": [
                "10.31.122.95"
            "gateways": [
                "10.31.122.1",
                "fe80::8",
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Ethernet",
            "id": "{BBFE85C6-2B65-4B6E-86EC-8D74193DC32B}",
            "name": "Ethernet",
            "description": "Realtek PCIe GbE Family Controller",
            "type": "Ethernet",
            "status": "Up",
            "bytes_received": "113066153220",
            "bytes_sent": "4071011790",
            "ips": [
                "192.168.0.106"
            "gateways": [
                "192.168.0.1"
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Loopback Pseudo-Interface 1",
            "id": "{6EDB8422-D3EE-11E7-AE97-806E6F6E6963}",
            "name": "Loopback Pseudo-Interface 1",
            "description": "Software Loopback Interface 1",
            "type": "Loopback",
            "status": "Up",
            "bytes_received": "0",
            "bytes_sent": "0",
            "ips": [
                "::1",
                "127.0.0.1"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
    "ipv4-default-gateway": "10.31.122.1",
    "ipv4-default-interface": "{18975750-849F-4D50-898E-DE8038EA33C3}",
    "ipv6-default-gateway": "fe80::8",
    "ipv6-default-interface": "{18975750-849F-4D50-898E-DE8038EA33C3}"
ipconfig /all:
Windows IP Configuration
   Host Name . . . . . . . . . . . . : DESKTOP-MF2T0PV
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Unknown adapter Local Area Connection:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : TAP-Windows Adapter V9
   Physical Address. . . . . . . . . : 00-FF-18-97-57-50
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   IPv6 Address. . . . . . . . . . . : fde6:7a:7d20:1b7a::105d(Preferred)
   Link-local IPv6 Address . . . . . : fe80::3d5e:da6b:6894:a781%24(Preferred)
   IPv4 Address. . . . . . . . . . . : 10.31.122.95(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Monday, July 13, 2020 7:57:14 PM
   Lease Expires . . . . . . . . . . : Wednesday, July 14, 2021 2:45:42 PM
   Default Gateway . . . . . . . . . :
   DHCP Server . . . . . . . . . . . : 10.31.122.254
   DHCPv6 IAID . . . . . . . . . . . : 402718488
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-24-17-47-0A-D0-50-99-AB-1D-38
   DNS Servers . . . . . . . . . . . : fde6:7a:7d20:1b7a::1
                                       10.31.122.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Ethernet:
   Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
   Physical Address. . . . . . . . . : D0-50-99-AB-1D-38
   Link-local IPv6 Address . . . . . : fe80::f555:b2d3:4a6d:55c2%10(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.0.106(Preferred)
   Lease Obtained. . . . . . . . . . : Tuesday, July 14, 2020 2:45:48 PM
   Lease Expires . . . . . . . . . . : Tuesday, July 14, 2020 5:22:52 PM
   Default Gateway . . . . . . . . . : 192.168.0.1
   DHCP Server . . . . . . . . . . . : 192.168.0.1
   DHCPv6 IAID . . . . . . . . . . . : 63983769
   DNS Servers . . . . . . . . . . . : 192.168.0.1
Edited ... by giganerd
Apply LOG format to logs
