Not connected, Your IP: 216.73.216.170
kongolav
Eddie on mac - open for LAN connections?
Hi there, I'm using eddie/AirVPN on a mac mini that I'm using as a seedbox and a plex server, is there any (preferably a simple and safe) way of allowing LAN traffic into the box without going through the VPN?
Eddie comes with some network lock specific settings
Settings -> Network lock
Allow lan/private: check-box
Allow ping: check-box
Is that what you need?
