Guest ergolon Posted ... Just tried your instructions for dd-wrt router (https://airvpn.org/ddwrt/) but my router doesn´t show all of the OpenVPN-Client-Options: I´m using DD-WRT v24-sp2 (08/12/10) mega (SVN revision 14929) on a Cisco Linksys E2000. Any ideas? Best wishes, ergolon Quote Share this post Link to post
Staff 10307 Posted ... Hello! You need to change firmware and find one which has all the options, otherwise you'll be forced to create scripts in order to connect. For Linksys E2000 the following firmware has been reported by our customers as fully functional and OpenVPN bug-free: dd-wrt.v24-16785_NEWD-2_K2.6_big-e2k-e3k Kind regards Quote Share this post Link to post
Guest ergolon Posted ... Thanks a lot, you were right. I chose the latest version for my router though: DD-WRT v24-sp2 (04/07/12) mega (SVN revision 18946M NEWD-2 K2.6 Eko) OpenVPN is supposed to work just fine with this version and it actually does. :-) Hope I´ll get the last woes sorted out (see https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=2377&Itemid=142#2377, post is pending) so I can subscribe to AirVPN forever. Best wishes, ergolon Quote Share this post Link to post
