Thrace
AsusWRT - OpenVPN Port Forwarding
I have Asus Router with stock AsusWRT.
I installed ovpn and everything is fine. My router shares VPN to all my netwotk.
Also i am hosting a monero node at my local pc.
I forwarded 3 ports and set monero to listen on those 3 ports.
A website to check ports says my ports are closed. Also Port forwarding page of AirVPN shows dark grey about my ports. Also my monero node doesnt have incoming connections.
So definitely something is wrong.
i suspected that:
My router is connected AirVPN and those ports supposed to be open at my router. So i tried to forward those 3 ports to my local pc. But no luck.
I am sure if connect to AirVPN with my pc with Eddie it will work. But I need to do this with my router.
So any suggestions?
Cheers
Did you also forward them explicitly from the tun interface?
tun interface?
There is OpenVPN settings and Port Forwardin at AsusWRT.
Port forwarding doesnt forwards ports from vpn connections.
So not sure how to forward open ports from AirVPN to my pc.
You'll probably need to SSH into the router to paste the proper iptables according to the above guide.
With stock asus you'll have to do this every reboot of the router.  If you got merlin asus you may be able to automate this using scripts saved in jffs .
Thanks for your time.
I have added iptables rules and all good now :D
I had entware at my stock asus router system for deluge torrent.
I guess i can run a script at router boot with entware to add those iptables.
Cheers
Edit: I accomplished to add those iptables rules automatically after boot at stock AsusWRT.
So now my router forwards my AirVPN opened ports to my PC.
I had a 2 day trial to test it out.
And few mins ago i purchased for 3 years :D
Thanks again.
Edited ... by Yanik39
update
