5o52xwmftthyuq2gmdy6
Pi-Hole on a Linux box using /usr/sbin/openvpn for AirVPN
I have a Linux box that is in "always-on" mode to AirVPN using command line /usr/sbin/openvpn with downloaded configs from AirVPN.
If I want to run pi-hole on this same machine (I've never run it before), is the process:
* Run pi-hole
* point my router's DNS settings to this machine
* point pi-hole to openDNS (or whatever)
* everything in my house now uses my-router -> pi-hole -> openDNS
Is that understanding correct?
If so, is doing this in this fashion going to send all my house's DNS queries through the openvpn tunnel through airVPN to openDNS?   or is my understanding wrong there somehow?
My brain is a little bent around the axle because my Linux box is also connected to that router, so the path then becomes:  client -> wifiAP/Router -> LinuxPiHole -> (tunnel) -> Router again? -> AirVPN -> openDNS...  is that right?  Will that work?
Not now. All devices first must get the new DNS server from the router (reconnect to the router, or wait for a DHCP release).
Yes – all traffic is routed through AirVPN, DNS as well.
Host > Pi-Hole > tunnel/AirVPN server > OpenDNS. Remember that the devices get Pi-Hole as their DNS server from the router. All queries go to the Pi from then on, and from there to whatever you configure. You can also configure the router there.
Also, don't use OpenDNS. They block and log. Try OpenNIC.
I've had exactly this set up working for months. The way I set it up is as follows:
1) run the openvpn with your config file
2) run the pi-hole installer and select the tun0 interface - select default options for the ip address of the pi-hole server
3) open the pi-hole web on localhost/admin and set its DNS addresses to those of the internal vpn servers (10.4.0.1)
4) check that it works (open the pi-hole web on localhost/admin) - you will note you're not getting all your local traffic
5) to get your local traffic, run the pi-hole installer again but this time chose the interface with your lan traffic on it, not the tun0
6) when you open the pi-hole web again, you'll see it all working
The finished setup looks like this on my machine:
note the IPv4 address is the address of the airvpn server on tun0 generated by pi-hole with its default settings, but the ethernet interface is enp3s0, the interface of my lan. This reflects the 'double installation'
10.4.0.1 and 10.5.0.1 are the addresses of airvpn's dns servers on tun0 - these are the addresses the clients on your lan should be using.
