mi90
Japan Servers Loss of MS?
Good evening.
I know that the Japanese VPN servers recently have had a few issues with packet loss, they have since come back up and well a much high MS since. I am experience around 80 MS to 100 MS since the problem as been rectified. I have also noticed that Hong Kong servers have now a better MS speed than the Japanese servers.
Here are my recent logs if this helps.
. 2020.05.18 17:41:28 - Eddie version: 2.18.9 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: Microsoft Windows NT 10.0.18363.0, Mono/.Net: v4.0.30319
. 2020.05.18 17:41:28 - Command line arguments (0):
. 2020.05.18 17:41:29 - Profile path: C:\Program Files\AirVPN\default.profile
. 2020.05.18 17:41:29 - Profile options not found, using defaults.
. 2020.05.18 17:41:29 - Tun Driver - 0901: Not found; wintun: Not found
. 2020.05.18 17:41:29 - OpenVPN - Version: 2.4.8 - OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2020.05.18 17:41:29 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2020.05.18 17:41:29 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2020.05.18 17:41:29 - curl - Version: 7.68.0 (C:\Program Files\AirVPN\curl.exe)
I 2020.05.18 17:41:30 - Ready
. 2020.05.18 17:41:32 - Collect information about AirVPN completed
I 2020.05.18 17:41:38 - Checking login ...
! 2020.05.18 17:41:41 - Logged in.
I 2020.05.18 17:42:01 - Session starting.
I 2020.05.18 17:42:01 - Checking authorization ...
! 2020.05.18 17:42:02 - Installing tunnel driver 0901
! 2020.05.18 17:42:03 - Connecting to Biham (Japan, Tokyo)
. 2020.05.18 17:42:03 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.05.18 17:42:03 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.05.18 17:42:03 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.05.18 17:42:03 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.05.18 17:42:03 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.05.18 17:42:03 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.05.18 17:42:03 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.05.18 17:42:03 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]37.120.210.213:443
. 2020.05.18 17:42:03 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.05.18 17:42:03 - OpenVPN > UDP link local: (not bound)
. 2020.05.18 17:42:03 - OpenVPN > UDP link remote: [AF_INET]37.120.210.213:443
. 2020.05.18 17:42:03 - OpenVPN > TLS: Initial packet from [AF_INET]37.120.210.213:443, sid=b575a508 4d9e8f49
. 2020.05.18 17:42:04 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.05.18 17:42:04 - OpenVPN > VERIFY KU OK
. 2020.05.18 17:42:04 - OpenVPN > Validating certificate extended key usage
. 2020.05.18 17:42:04 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.05.18 17:42:04 - OpenVPN > VERIFY EKU OK
. 2020.05.18 17:42:04 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Biham, emailAddress=info@airvpn.org
. 2020.05.18 17:42:04 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.05.18 17:42:04 - OpenVPN > [Biham] Peer Connection Initiated with [AF_INET]37.120.210.213:443
. 2020.05.18 17:42:05 - OpenVPN > SENT CONTROL [Biham]: 'PUSH_REQUEST' (status=1)
. 2020.05.18 17:42:05 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.6.154.1,dhcp-option DNS6 fde6:7a:7d20:29a::1,tun-ipv6,route-gateway 10.6.154.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:29a::10a2/64 fde6:7a:7d20:29a::1,ifconfig 10.6.154.164 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2020.05.18 17:42:05 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.05.18 17:42:05 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.05.18 17:42:05 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.05.18 17:42:05 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.05.18 17:42:05 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.05.18 17:42:05 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.05.18 17:42:05 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.05.18 17:42:05 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.05.18 17:42:05 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.05.18 17:42:05 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.05.18 17:42:05 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.05.18 17:42:05 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.05.18 17:42:05 - OpenVPN > interactive service msg_channel=0
. 2020.05.18 17:42:05 - OpenVPN > ROUTE_GATEWAY 210.108.237.126/255.255.255.0 I=10 HWADDR=e0:d5:5e:d8:4a:98
. 2020.05.18 17:42:05 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.05.18 17:42:05 - OpenVPN > NOTE: GetBestInterfaceEx returned error: ��Ұ� �����ϴ�.   (code=1168)
. 2020.05.18 17:42:05 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2020.05.18 17:42:05 - OpenVPN > open_tun
. 2020.05.18 17:42:05 - OpenVPN > TAP-WIN32 device [로컬 영역 연결] opened: \\.\Global\{9C32C038-095C-4AC1-B3A6-BC61C3DD1C83}.tap
. 2020.05.18 17:42:05 - OpenVPN > TAP-Windows Driver Version 9.24
. 2020.05.18 17:42:05 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.6.154.0/10.6.154.164/255.255.255.0 [SUCCEEDED]
. 2020.05.18 17:42:05 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.6.154.164/255.255.255.0 on interface {9C32C038-095C-4AC1-B3A6-BC61C3DD1C83} [DHCP-serv: 10.6.154.254, lease-time: 31536000]
. 2020.05.18 17:42:05 - OpenVPN > Successful ARP Flush on interface [18] {9C32C038-095C-4AC1-B3A6-BC61C3DD1C83}
. 2020.05.18 17:42:06 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=18 fde6:7a:7d20:29a::10a2 store=active
. 2020.05.18 17:42:08 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns 로컬 영역 연결 static fde6:7a:7d20:29a::1 validate=no
. 2020.05.18 17:42:08 - OpenVPN > add_route_ipv6(fde6:7a:7d20:29a::/64 -> fde6:7a:7d20:29a::10a2 metric 0) dev 로컬 영역 연결
. 2020.05.18 17:42:08 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:29a::/64 interface=18 fe80::8 store=active
. 2020.05.18 17:42:08 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.05.18 17:42:13 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2020.05.18 17:42:13 - OpenVPN > C:\Windows\system32\route.exe ADD 37.120.210.213 MASK 255.255.255.255 210.108.237.126
. 2020.05.18 17:42:13 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2020.05.18 17:42:13 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2020.05.18 17:42:13 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.6.154.1
. 2020.05.18 17:42:13 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.6.154.1
. 2020.05.18 17:42:13 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:29a::1 metric -1) dev 로컬 영역 연결
. 2020.05.18 17:42:13 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=18 fe80::8 store=active
. 2020.05.18 17:42:13 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.05.18 17:42:13 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:29a::1 metric -1) dev 로컬 영역 연결
. 2020.05.18 17:42:13 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=18 fe80::8 store=active
. 2020.05.18 17:42:13 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:29a::1 metric -1) dev 로컬 영역 연결
. 2020.05.18 17:42:13 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=18 fe80::8 store=active
. 2020.05.18 17:42:13 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:29a::1 metric -1) dev 로컬 영역 연결
. 2020.05.18 17:42:13 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=18 fe80::8 store=active
. 2020.05.18 17:42:13 - Interface 로컬 영역 연결 metric changed from Automatic to 3, layer IPv4
. 2020.05.18 17:42:13 - Interface 로컬 영역 연결 metric changed from Automatic to 3, layer IPv6
. 2020.05.18 17:42:13 - DNS leak protection with packet filtering enabled.
W 2020.05.18 17:42:13 - Routes, add 37.120.210.211 for gateway 10.6.154.1 failed: Exception: exit:0; out: Ȯ��!
W 2020.05.18 17:42:13 -     ; err:
W 2020.05.18 17:42:13 - Routes, add 2001:ac8:40:47:41eb:a0c5:e8b2:dfbe for gateway fde6:7a:7d20:29a::1 failed: Exception: exit:0; out:Ȯ�ε�
. 2020.05.18 17:42:13 - Flushing DNS
I 2020.05.18 17:42:14 - Checking route IPv4
I 2020.05.18 17:42:14 - Checking route IPv6
I 2020.05.18 17:42:17 - Checking DNS
! 2020.05.18 17:42:18 - Connected.
. 2020.05.18 17:42:18 - OpenVPN > Initialization Sequence Completed
! 2020.05.18 17:55:00 - Disconnecting
. 2020.05.18 17:55:00 - Sending soft termination signal
. 2020.05.18 17:55:03 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2020.05.18 17:55:05 - OpenVPN > C:\Windows\system32\route.exe DELETE 37.120.210.213 MASK 255.255.255.255 210.108.237.126
. 2020.05.18 17:55:05 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2020.05.18 17:55:05 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.6.154.1
. 2020.05.18 17:55:05 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.6.154.1
. 2020.05.18 17:55:05 - OpenVPN > delete_route_ipv6(::/3)
. 2020.05.18 17:55:05 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=18 fe80::8 store=active
. 2020.05.18 17:55:05 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.05.18 17:55:05 - OpenVPN > delete_route_ipv6(2000::/4)
. 2020.05.18 17:55:05 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=18 fe80::8 store=active
. 2020.05.18 17:55:05 - OpenVPN > delete_route_ipv6(3000::/4)
. 2020.05.18 17:55:05 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=18 fe80::8 store=active
. 2020.05.18 17:55:05 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2020.05.18 17:55:05 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=18 fe80::8 store=active
. 2020.05.18 17:55:05 - OpenVPN > Closing TUN/TAP interface
. 2020.05.18 17:55:05 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:29a::/64)
. 2020.05.18 17:55:05 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:29a::/64 interface=18 fe80::8 store=active
. 2020.05.18 17:55:06 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address 로컬 영역 연결 fde6:7a:7d20:29a::10a2 store=active
. 2020.05.18 17:55:07 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns 로컬 영역 연결 all
. 2020.05.18 17:55:07 - OpenVPN > TAP: DHCP address released
. 2020.05.18 17:55:07 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2020.05.18 17:55:07 - Connection terminated.
. 2020.05.18 17:55:07 - DNS leak protection with packet filtering disabled.
. 2020.05.18 17:55:07 - Interface 로컬 영역 연결 metric restored from 3 to Automatic, layer IPv4
. 2020.05.18 17:55:07 - Interface 로컬 영역 연결 metric restored from 3 to Automatic, layer IPv6
. 2020.05.18 17:55:07 - Flushing DNS
! 2020.05.18 17:55:07 - Session terminated.
I 2020.05.18 18:01:25 - Session starting.
I 2020.05.18 18:01:26 - Checking authorization ...
! 2020.05.18 18:01:27 - Connecting to Iskandar (Japan, Tokyo)
. 2020.05.18 18:01:27 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.05.18 18:01:27 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.05.18 18:01:27 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.05.18 18:01:27 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.05.18 18:01:27 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.05.18 18:01:27 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.05.18 18:01:27 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.05.18 18:01:27 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]82.102.28.109:443
. 2020.05.18 18:01:27 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.05.18 18:01:27 - OpenVPN > UDP link local: (not bound)
. 2020.05.18 18:01:27 - OpenVPN > UDP link remote: [AF_INET]82.102.28.109:443
. 2020.05.18 18:01:27 - OpenVPN > TLS: Initial packet from [AF_INET]82.102.28.109:443, sid=da90d6f5 2785f7b2
. 2020.05.18 18:01:27 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.05.18 18:01:27 - OpenVPN > VERIFY KU OK
. 2020.05.18 18:01:27 - OpenVPN > Validating certificate extended key usage
. 2020.05.18 18:01:27 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.05.18 18:01:27 - OpenVPN > VERIFY EKU OK
. 2020.05.18 18:01:27 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Iskandar, emailAddress=info@airvpn.org
. 2020.05.18 18:01:36 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.05.18 18:01:36 - OpenVPN > [Iskandar] Peer Connection Initiated with [AF_INET]82.102.28.109:443
. 2020.05.18 18:01:37 - OpenVPN > SENT CONTROL [Iskandar]: 'PUSH_REQUEST' (status=1)
. 2020.05.18 18:01:37 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.19.186.1,dhcp-option DNS6 fde6:7a:7d20:fba::1,tun-ipv6,route-gateway 10.19.186.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:fba::10c0/64 fde6:7a:7d20:fba::1,ifconfig 10.19.186.194 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2020.05.18 18:01:37 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.05.18 18:01:37 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.05.18 18:01:37 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.05.18 18:01:37 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.05.18 18:01:37 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.05.18 18:01:37 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.05.18 18:01:37 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.05.18 18:01:37 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.05.18 18:01:37 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.05.18 18:01:37 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.05.18 18:01:37 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.05.18 18:01:37 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.05.18 18:01:37 - OpenVPN > interactive service msg_channel=0
. 2020.05.18 18:01:37 - OpenVPN > ROUTE_GATEWAY 210.108.237.126/255.255.255.0 I=10 HWADDR=e0:d5:5e:d8:4a:98
. 2020.05.18 18:01:37 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.05.18 18:01:37 - OpenVPN > NOTE: GetBestInterfaceEx returned error: ��Ұ� �����ϴ�.   (code=1168)
. 2020.05.18 18:01:37 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2020.05.18 18:01:37 - OpenVPN > open_tun
. 2020.05.18 18:01:37 - OpenVPN > TAP-WIN32 device [로컬 영역 연결] opened: \\.\Global\{9C32C038-095C-4AC1-B3A6-BC61C3DD1C83}.tap
. 2020.05.18 18:01:37 - OpenVPN > TAP-Windows Driver Version 9.24
. 2020.05.18 18:01:37 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.19.186.0/10.19.186.194/255.255.255.0 [SUCCEEDED]
. 2020.05.18 18:01:37 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.19.186.194/255.255.255.0 on interface {9C32C038-095C-4AC1-B3A6-BC61C3DD1C83} [DHCP-serv: 10.19.186.254, lease-time: 31536000]
. 2020.05.18 18:01:37 - OpenVPN > Successful ARP Flush on interface [18] {9C32C038-095C-4AC1-B3A6-BC61C3DD1C83}
. 2020.05.18 18:01:38 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=18 fde6:7a:7d20:fba::10c0 store=active
. 2020.05.18 18:01:39 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns 로컬 영역 연결 static fde6:7a:7d20:fba::1 validate=no
. 2020.05.18 18:01:39 - OpenVPN > add_route_ipv6(fde6:7a:7d20:fba::/64 -> fde6:7a:7d20:fba::10c0 metric 0) dev 로컬 영역 연결
. 2020.05.18 18:01:39 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:fba::/64 interface=18 fe80::8 store=active
. 2020.05.18 18:01:39 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.05.18 18:01:44 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2020.05.18 18:01:44 - OpenVPN > C:\Windows\system32\route.exe ADD 82.102.28.109 MASK 255.255.255.255 210.108.237.126
. 2020.05.18 18:01:44 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2020.05.18 18:01:44 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2020.05.18 18:01:44 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.19.186.1
. 2020.05.18 18:01:44 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.19.186.1
. 2020.05.18 18:01:44 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:fba::1 metric -1) dev 로컬 영역 연결
. 2020.05.18 18:01:44 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=18 fe80::8 store=active
. 2020.05.18 18:01:44 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.05.18 18:01:44 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:fba::1 metric -1) dev 로컬 영역 연결
. 2020.05.18 18:01:44 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=18 fe80::8 store=active
. 2020.05.18 18:01:44 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:fba::1 metric -1) dev 로컬 영역 연결
. 2020.05.18 18:01:44 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=18 fe80::8 store=active
. 2020.05.18 18:01:44 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:fba::1 metric -1) dev 로컬 영역 연결
. 2020.05.18 18:01:44 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=18 fe80::8 store=active
. 2020.05.18 18:01:44 - Interface 로컬 영역 연결 metric changed from Automatic to 3, layer IPv4
. 2020.05.18 18:01:44 - Interface 로컬 영역 연결 metric changed from Automatic to 3, layer IPv6
. 2020.05.18 18:01:44 - DNS leak protection with packet filtering enabled.
W 2020.05.18 18:01:44 - Routes, add 82.102.28.107 for gateway 10.19.186.1 failed: Exception: exit:0; out: Ȯ��!
W 2020.05.18 18:01:44 -     ; err:
W 2020.05.18 18:01:44 - Routes, add 2001:ac8:40:8:ff92:53b9:316d:b8a7 for gateway fde6:7a:7d20:fba::1 failed: Exception: exit:0; out:Ȯ�ε�
. 2020.05.18 18:01:44 - Flushing DNS
I 2020.05.18 18:01:45 - Checking route IPv4
I 2020.05.18 18:01:48 - Checking route IPv6
I 2020.05.18 18:01:52 - Checking DNS
! 2020.05.18 18:01:54 - Connected.
. 2020.05.18 18:01:54 - OpenVPN > Initialization Sequence Completed
! 2020.05.18 18:09:45 - Disconnecting
. 2020.05.18 18:09:45 - Sending soft termination signal
. 2020.05.18 18:09:48 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2020.05.18 18:09:50 - OpenVPN > C:\Windows\system32\route.exe DELETE 82.102.28.109 MASK 255.255.255.255 210.108.237.126
. 2020.05.18 18:09:50 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2020.05.18 18:09:50 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.19.186.1
. 2020.05.18 18:09:50 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.19.186.1
. 2020.05.18 18:09:50 - OpenVPN > delete_route_ipv6(::/3)
. 2020.05.18 18:09:50 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=18 fe80::8 store=active
. 2020.05.18 18:09:50 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.05.18 18:09:50 - OpenVPN > delete_route_ipv6(2000::/4)
. 2020.05.18 18:09:50 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=18 fe80::8 store=active
. 2020.05.18 18:09:50 - OpenVPN > delete_route_ipv6(3000::/4)
. 2020.05.18 18:09:50 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=18 fe80::8 store=active
. 2020.05.18 18:09:50 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2020.05.18 18:09:50 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=18 fe80::8 store=active
. 2020.05.18 18:09:50 - OpenVPN > Closing TUN/TAP interface
. 2020.05.18 18:09:50 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:fba::/64)
. 2020.05.18 18:09:50 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:fba::/64 interface=18 fe80::8 store=active
. 2020.05.18 18:09:51 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address 로컬 영역 연결 fde6:7a:7d20:fba::10c0 store=active
. 2020.05.18 18:09:52 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns 로컬 영역 연결 all
. 2020.05.18 18:09:52 - OpenVPN > TAP: DHCP address released
. 2020.05.18 18:09:52 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2020.05.18 18:09:52 - Connection terminated.
. 2020.05.18 18:09:52 - DNS leak protection with packet filtering disabled.
. 2020.05.18 18:09:52 - Interface 로컬 영역 연결 metric restored from 3 to Automatic, layer IPv4
. 2020.05.18 18:09:52 - Interface 로컬 영역 연결 metric restored from 3 to Automatic, layer IPv6
I 2020.05.18 18:09:52 - Checking authorization ...
! 2020.05.18 18:09:53 - Connecting to Taphao (Japan, Tokyo)
. 2020.05.18 18:09:53 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.05.18 18:09:53 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.05.18 18:09:53 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.05.18 18:09:53 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.05.18 18:09:53 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.05.18 18:09:53 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.05.18 18:09:53 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.05.18 18:09:53 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.148.16.213:443
. 2020.05.18 18:09:53 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.05.18 18:09:53 - OpenVPN > UDP link local: (not bound)
. 2020.05.18 18:09:53 - OpenVPN > UDP link remote: [AF_INET]193.148.16.213:443
. 2020.05.18 18:09:53 - OpenVPN > TLS: Initial packet from [AF_INET]193.148.16.213:443, sid=37344e39 ce58f6ee
. 2020.05.18 18:09:53 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.05.18 18:09:53 - OpenVPN > VERIFY KU OK
. 2020.05.18 18:09:53 - OpenVPN > Validating certificate extended key usage
. 2020.05.18 18:09:53 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.05.18 18:09:53 - OpenVPN > VERIFY EKU OK
. 2020.05.18 18:09:53 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Taphao, emailAddress=info@airvpn.org
. 2020.05.18 18:09:54 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.05.18 18:09:54 - OpenVPN > [Taphao] Peer Connection Initiated with [AF_INET]193.148.16.213:443
. 2020.05.18 18:09:55 - OpenVPN > SENT CONTROL [Taphao]: 'PUSH_REQUEST' (status=1)
. 2020.05.18 18:09:57 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.23.218.1,dhcp-option DNS6 fde6:7a:7d20:13da::1,tun-ipv6,route-gateway 10.23.218.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:13da::1091/64 fde6:7a:7d20:13da::1,ifconfig 10.23.218.147 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2020.05.18 18:09:57 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.05.18 18:09:57 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.05.18 18:09:57 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.05.18 18:09:57 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.05.18 18:09:57 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.05.18 18:09:57 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.05.18 18:09:57 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.05.18 18:09:57 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.05.18 18:09:57 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.05.18 18:09:57 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.05.18 18:09:57 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.05.18 18:09:57 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.05.18 18:09:57 - OpenVPN > interactive service msg_channel=0
. 2020.05.18 18:09:57 - OpenVPN > ROUTE_GATEWAY 210.108.237.126/255.255.255.0 I=10 HWADDR=e0:d5:5e:d8:4a:98
. 2020.05.18 18:09:57 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.05.18 18:09:57 - OpenVPN > NOTE: GetBestInterfaceEx returned error: ��Ұ� �����ϴ�.   (code=1168)
. 2020.05.18 18:09:57 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2020.05.18 18:09:57 - OpenVPN > open_tun
. 2020.05.18 18:09:57 - OpenVPN > TAP-WIN32 device [로컬 영역 연결] opened: \\.\Global\{9C32C038-095C-4AC1-B3A6-BC61C3DD1C83}.tap
. 2020.05.18 18:09:57 - OpenVPN > TAP-Windows Driver Version 9.24
. 2020.05.18 18:09:57 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.23.218.0/10.23.218.147/255.255.255.0 [SUCCEEDED]
. 2020.05.18 18:09:57 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.23.218.147/255.255.255.0 on interface {9C32C038-095C-4AC1-B3A6-BC61C3DD1C83} [DHCP-serv: 10.23.218.254, lease-time: 31536000]
. 2020.05.18 18:09:57 - OpenVPN > Successful ARP Flush on interface [18] {9C32C038-095C-4AC1-B3A6-BC61C3DD1C83}
. 2020.05.18 18:09:58 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=18 fde6:7a:7d20:13da::1091 store=active
. 2020.05.18 18:09:59 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns 로컬 영역 연결 static fde6:7a:7d20:13da::1 validate=no
. 2020.05.18 18:09:59 - OpenVPN > add_route_ipv6(fde6:7a:7d20:13da::/64 -> fde6:7a:7d20:13da::1091 metric 0) dev 로컬 영역 연결
. 2020.05.18 18:09:59 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:13da::/64 interface=18 fe80::8 store=active
. 2020.05.18 18:09:59 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.05.18 18:10:04 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2020.05.18 18:10:04 - OpenVPN > C:\Windows\system32\route.exe ADD 193.148.16.213 MASK 255.255.255.255 210.108.237.126
. 2020.05.18 18:10:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2020.05.18 18:10:04 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2020.05.18 18:10:04 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.23.218.1
. 2020.05.18 18:10:04 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.23.218.1
. 2020.05.18 18:10:04 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:13da::1 metric -1) dev 로컬 영역 연결
. 2020.05.18 18:10:04 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=18 fe80::8 store=active
. 2020.05.18 18:10:04 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.05.18 18:10:04 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:13da::1 metric -1) dev 로컬 영역 연결
. 2020.05.18 18:10:04 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=18 fe80::8 store=active
. 2020.05.18 18:10:04 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:13da::1 metric -1) dev 로컬 영역 연결
. 2020.05.18 18:10:04 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=18 fe80::8 store=active
. 2020.05.18 18:10:04 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:13da::1 metric -1) dev 로컬 영역 연결
. 2020.05.18 18:10:04 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=18 fe80::8 store=active
. 2020.05.18 18:10:04 - Interface 로컬 영역 연결 metric changed from Automatic to 3, layer IPv4
. 2020.05.18 18:10:04 - Interface 로컬 영역 연결 metric changed from Automatic to 3, layer IPv6
. 2020.05.18 18:10:04 - DNS leak protection with packet filtering enabled.
W 2020.05.18 18:10:04 - Routes, add 193.148.16.211 for gateway 10.23.218.1 failed: Exception: exit:0; out: Ȯ��!
W 2020.05.18 18:10:04 -     ; err:
W 2020.05.18 18:10:04 - Routes, add 2001:ac8:40:1:2c84:746a:ea87:7e98 for gateway fde6:7a:7d20:13da::1 failed: Exception: exit:0; out:Ȯ�ε�
. 2020.05.18 18:10:04 - Flushing DNS
I 2020.05.18 18:10:04 - Checking route IPv4
I 2020.05.18 18:10:05 - Checking route IPv6
I 2020.05.18 18:10:06 - Checking DNS
! 2020.05.18 18:10:08 - Connected.
. 2020.05.18 18:10:08 - OpenVPN > Initialization Sequence Completed
Thanks in advance.
Edited ... by giganerd
Apply LOG formatting to logs
This problem has been over a week now and there seems to be no update. I have asked people from Japan to see if their ISP's have slowed down and one of the causes could be the bandwidth due to the state of emergency.
I am guessing there has been no solution to this issues. Despite the fact it comes up at 61 MS, i experience at least 120 MS to 180 from time to time. I have done a diagnostics on my end and it seems that my connection is fine.
I would appreciate if there is a solution to this problem.
Thanks in advance
