ghostp
Killswitch?
what will happen if I'm connected with Eddie to AirVPN and meanwhile my internet connection brakes or my router resynchs. Will my real IP get leaked somehow? Does Eddie has a "killswitch" ? If so, where to find it and how to use it?
Hi, Eddie client provides you with Network Lock feature. It should prevent your machine from sending any data outside the VPN tunnel.
There's more info in the "client software" section of the FAQ. You can turn it on with a big button in the main screen of Eddie-ui just below the login section.
As I'm understanding Eddie do not turn it on automatically and it has to be activated before connecting the VPN? How about if I want Eddie to turn it on automatically everytime I connect to a server?
Yo can set eddie to turn it on automatically at startup.
There is a checkbox in the general tab of the settings which says "Activate Network Lock as startup" check it and you are done. ;)
