Not connected, Your IP: 216.73.217.73
VPNuser123456
OpenVpn and Safari
Hi all I have downloaded OpenVpn on my ipad running version 13.3,1, Openvpn seems run fine.
The next instruction is to Launch safari browser connect to the airvpn website,login.
But when I attempt do this i get message "Sorry, this website requires Javascript" and I am not able to login in. To enable me to go to the config generator page so that I can get .ovpn files to be able to use Open vpn.
When will this be fixed so s safari is able to be used to download the necessary .ovpn files
Also as suggestion. Would be good idea to update your instructions on how to add .ovpn files to OpenVpn because the suggested method and the screen shots shown on your website are no longer current or useable.
Since ios13 upgrade it is necessary to import .ovpn files completely differently than the methods listed in your instuction guides.
Regards
