Mrd0708
ANSWERED How to connect to my mediaserver when IP keeps changing?
Disclaimer: I am new to this
I am running Jellyfin mediaplayer through airvpn. Accessing via internet works perfectly with port forwarding. Since there is no static IP with vpn whats the best way to keep connecting to my mediaserver via internet when the IP keeps changing?
Thanks in advance
@Mrd0708
Each VPN server has ONE exit-IPv4 address which normally never changes (it might change only under exceptional circumstances).
As long as you connect to the same VPN server you can reach your service on the same IP address.
We also provide a DDNS included in any AirVPN plan which might come handy for your needs:
https://airvpn.org/faq/ddns/
Thank you for your reaction. I allways connected to a country instead of a specific server. This is perfect.
