Sanctioner 3 Posted ... How do you generally use this application? I checked the man pages for eddie-cli, but it's a bit lacking. I can't find any user guides or how tos that go into any depth. the man pages say you can add stuff to your default.profile, but it doesn't actually say how. the --remember switch doesn't add the username and pw that I used. I need to get my pw out of the command parameters and add some custom routes so i don't lose access to my servers the --connect switch doesn't actually connect to the server. no firewall logs indicating anything is blocked. it just hangs after the latency test at "3 to go". the --help switch is really just a copy of the man pages i used --server switch, but it said "Requested server 'True' not found". the man pages say, when empty, default is the publicly recommended server, not "True". pressing n says server switch requested, but no further updates are drawn indicating its status man pages has --connect switch labelled twice, one with a more verbose definition indicating it is for connecting automatically at startup, but this doesn't seem to connect automatically at startup as i have to type this command I am on Fedora. I prefer to use openvpn and make my own netlock but this may be easier to switch servers. Is there a more robust user guide on how to use this? I feel it may save me time if I can just use this as I'd have to write a bunch of stuff if I want to use openvpn Thanks, Sanc Quote Share this post Link to post
Staff 10398 Posted ... Hello! If you don't need a GUI check Hummingbird:https://airvpn.org/hummingbird/readme/ Kind regards Quote Share this post Link to post
Sanctioner 3 Posted ... Thanks, I will download this and try it out. Quote Share this post Link to post
