void75 0 Posted ... (edited) Hello.https://www.disneyplus.com/it-it/ is locked. I can't see anything except ***attached pic***. Netflix and Prime Video working fine. FYI I used https://www.disneyplus.com as starting link but, even beeing on an AirVPS's server located in Norway, it still redirect me on .../it-it. Edited ... by void75 Quote Share this post Link to post
Tech Jedi Alex 1514 Posted ... Are you sure it doesn't simply refer to your browser's language? I connected to a server in UK and removed German from the list of languages in my browser (en being the only one). When I view disneyplus.com I don't get redirected anywhere. Apart from that, thank you for your report. I was wondering when the first one will be posted. Can you try with another device on the same network? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
void75 0 Posted ... The it language is not the real problem, as I tested with gb language as you suggested. It's the screen I attached. I see nothing more than that. I can't login or see anything except that. Quote Share this post Link to post
Tech Jedi Alex 1514 Posted ... Can you test another browser, or a clean profile in your current browser? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
void75 0 Posted ... I changed server and now it's working. If I go back, still blacked page. Guess maybe that server is blacklisted from Disneyplus. Quote Share this post Link to post
Flx 77 Posted ... 1 hour ago, void75 said: The it language is not the real problem, as I tested with gb language as you suggested. It's the screen I attached. I see nothing more than that. I can't login or see anything except that. Correct it doesn't seem to be working. Seems to be a problem with the website. Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
Tech Jedi Alex 1514 Posted ... 21 minutes ago, void75 said: I changed server and now it's working. If I go back, still blacked page. Guess maybe that server is blacklisted from Disneyplus. You know, it certainly helps knowing which server doesn't work.. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Flx 77 Posted ... Tested on Iphone(Safari realIP) and Firefox.(Saiph, Aludra, Lesath, Avior, Gorgonea so far) Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
void75 0 Posted ... 24 minutes ago, giganerd said: You know, it certainly helps knowing which server doesn't work.. I was on Alphard, NL, whilst I got that black screen. So far I tested on two other than Alphard, 1 from Holland and 1 from Norway, and it's fine. Tested with android device on some belgique servers, and it's fine. I will avoid Alphard for some days 😅 Cheers. Quote Share this post Link to post
Flx 77 Posted ... On 5/2/2020 at 8:13 AM, Flx said: Seems to be a problem with the website. It does work if Assigned IP and DNS assigned comes from the same AirVPN Server. when you use AirDNS exclusively. Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
crluch 0 Posted ... I tried the different things you propose but no one works for me. I use eddie under Windows to connect with default settings. I have seen using google chrome that the address "https://global.edge.bamgrid.com/token" is unreachable when I am under VPN. This service is used to obtain the country of the client, without its reply the scripts of the site are blocked. I tried a plethora of the different server but with no one of this, the address is reachable. Naturally, without vpn the site works very well. So I ask the community to ask to the admins of airvpn to unlock this address or to give us a shortcut. Quote Share this post Link to post
