pentraitor 2 Posted ... Hi there. I'm using Eddie 2.4 on Android 7.1.1. I'm quite happy here with AirVPN but a friend of mine uses another VPN provider and I suggested he try the Eddie client on Android as an alternative. So then I wanted to show him how it works and while trying to import his custom .ovpn files into Eddie we ran into a problem.Eddie just wouldn't accept his .ovpn files. Whenever I selected one of them Eddie just kept on displaying "OpenVPN Profiles (0) - No OpenVPN Profile available". These profiles work just fine with the OpenVPN app by Arne Schwabe, for example. But Eddie doesn't seem to like them. Any idea why that is? Do his config files contain something that's simply not compatible with Eddie? Here's a "redacted" copy of one of the config files: auth-user-pass client dev tun hand-window 120 inactive 604800 mute-replay-warnings nobind persist-key persist-remote-ip persist-tun ping 5 ping-restart 120 redirect-gateway def1 remote-random reneg-sec 3600 resolv-retry 60 route-delay 2 route-method exe script-security 2 tls-cipher TLS-DHE-RSA-WITH-AES-256-GCM-SHA384:TLS-DHE-RSA-WITH-AES-256-CBC-SHA256:TLS-DHE-RSA-WITH-CAMELLIA-256-CBC-SHA:TLS-DHE-RSA-WITH-AES-256-CBC-SHA:TLS-RSA-WITH-CAMELLIA-256-CBC-SHA:TLS-RSA-WITH-AES-256-CBC-SHA tls-timeout 5 verb 4 tun-ipv6 tun-mtu 1500 tun-mtu-extra 32 mssfix 1450 proto tcp remote XX.XXX.XXX.XX 44 remote XX.XXX.XXX.XX 443 remote XX.XXX.XXX.XX 4433 remote XX.XXX.XXX.XX 44 remote XX.XXX.XXX.XX 443 remote XX.XXX.XXX.XX 4433 remote XX.XXX.XXX.XX 44 remote XX.XXX.XXX.XX 443 remote XX.XXX.XXX.XX 4433 remote XX.XXX.XXX.XX 44 remote XX.XXX.XXX.XX 443 remote XX.XXX.XXX.XX 4433 remote XX.XXX.XXX.XX 44 remote XX.XXX.XXX.XX 443 remote XX.XXX.XXX.XX 4433 cipher AES-256-GCM auth SHA512 ignore-unknown-option ncp-disable ncp-disable remote-cert-tls server <ca> -----BEGIN CERTIFICATE----- [...] -----END CERTIFICATE----- </ca> <cert> -----BEGIN CERTIFICATE----- [...] -----END CERTIFICATE----- </cert> <key> -----BEGIN PRIVATE KEY----- [...] -----END PRIVATE KEY----- </key> <tls-crypt> -----BEGIN OpenVPN Static key V1----- [...] -----END OpenVPN Static key V1----- </tls-crypt> Share this post Link to post
pentraitor 2 Posted ... Here's a "redacted" AirVPN config file for comparison: client dev tun remote at.vpn.airdns.org 443 resolv-retry infinite nobind persist-key persist-tun auth-nocache verb 3 push-peer-info setenv UV_IPV6 yes remote-cert-tls server cipher AES-256-CBC comp-lzo no proto tcp key-direction 1 <ca> -----BEGIN CERTIFICATE----- [...] -----END CERTIFICATE----- </ca> <cert> -----BEGIN CERTIFICATE----- [...] -----END CERTIFICATE----- </cert> <key> -----BEGIN PRIVATE KEY----- [...] -----END PRIVATE KEY----- </key> <tls-auth> # # 2048 bit OpenVPN static key # -----BEGIN OpenVPN Static key V1----- [...] -----END OpenVPN Static key V1----- </tls-auth> Share this post Link to post
Tech Jedi Alex 1527 Posted ... Nah, it's Eddie. Have you tried importing a profile from the generator into Eddie? If I try to do that, it throws an "invalid profile" message. It's not about the profile. Apart from some superfluous and effectless directives in the profile of the other VPN provider it's quite fine, I might say. 1 pentraitor reacted to this Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
pentraitor 2 Posted ... Huh, talk about the most obvious thing to try... and of course I haven't... yet But thanks for the suggestion. I just tried it and it definitely worked with a .ovpn I just generated from AirVPN. I had no issue adding the profile and no issue connecting to the server. So now it's pretty safe to assume it's because of the content inside the other .ovpn file, right? Share this post Link to post
pentraitor 2 Posted ... By the way which directives do you think are superfluous? Maybe I could try to remove them manually to see if that makes a difference. Share this post Link to post
Tech Jedi Alex 1527 Posted ... Tried a few things. I'm fairly certain that the only unsupported thing is multiple remote directives. I was able to import both the profile you provided and a freshly generated .ovpn config file when it contains only one remote. 9 minutes ago, pentraitor said: By the way which directives do you think are superfluous? Maybe I could try to remove them manually to see if that makes a difference. Doesn't matter much now. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
pentraitor 2 Posted ... Thanks for taking the time, giganerd. I really appreciate it!The "redacted" config file I posted above contained the IPs of multiple servers for each city the provider has servers in. And each server also had three ports to choose from. So then I generated config files for each single server, but each of these config files still had three "remote" directives, one for each port. Eddie still wouldn't accept it. Then I removed all but one "remote" directive with one single port, and suddenly Eddie accepted the config file The only other thing I had to do was enter the credentials under the "Authentication" tab inside the settings. Now it seems to be working without any issue. At least so far.Again, thank you so much for your input, giganerd! 1 Tech Jedi Alex reacted to this Share this post Link to post
