Staff 10436 Posted ... Hello! We're very glad to inform you that a new Eddie Air client version has been released: 2.19beta. It is ready for public beta testing. How to test our experimental release: Go to download page of your OS Click on Other versions Click on Experimental Look at the changelog if you wish Download and install Please see the changelog: https://eddie.website/changelog/?software=client&format=html PLEASE CONSIDER THIS AS A BETA VERSION. Don't use it for real connection, it's only for those who want to collaborate to the project as beta-tester. 1 1 colorman and adreampuppet reacted to this Quote Share this post Link to post
Staff 10436 Posted ... This version contains some bug fixes (in Windows and some OS X and macOS versions) we discovered after 2.18.9 stable version had been released. You don't need to download it if you don't have any issue with the latest stable release. Version 2.19.0 (Tue, 07 Apr 2020 13:11:42 +0000) [bugfix] - Windows, Custom DNS [change] - Windows, DNS, switch only UP network adapter [bugfix] - MacOS, fix PKG package (relocation disabled) [bugfix] - MacOS, fix signature issue with older Yosemite Quote Share this post Link to post
zsam288 39 Posted ... Installer hanged for me when installing the CLI elevated, had to stop it in task manager before running installer again (win10) Quote Share this post Link to post
puccettone 0 Posted ... Thanks a lot for this update! Now Eddie works like a charm with wintun drivers 😉 I had issues with other sw (e.g. NextDNS) because of TAP drivers, now everything is fine. Just a question (maybe very stupid, but I don't want to be again in a mess with TAP drivers...). I use portable version of Eddie UI, which I set up to use the wintun drivers. In the Eddie folder I see there is also the CLI version, Eddie-CLI.exe. Does the CLI version share the same settings of UI? I suppose yes, but I'd like to be 100% sure about this before I try it: I don't want to unistall/install again all TAP drivers, network interfaces and sw everytime I want to use Eddie or NextDNS... Quote Share this post Link to post
zsam288 39 Posted ... I risk sounding stupid, but here it goes is SSH/SSL tunnel TCP or UDP? If UDP, any chance to make it TCP? My connections drops often on UDP Quote Share this post Link to post
Clodo 177 Posted ... Version 2.19.1 (Sat, 18 Apr 2020 11:14:36 +0000) [bugfix] Linux - Fix issue with Network Lock IPv6-only incoming whitelist [bugfix] - http-100-continue issue [bugfix] - Special condition elevation checks (may resolve "Unable to start (no-socket)" issues). [change] - Removed curl binary dependencies [new] Linux - New Network Lock with nftables (if nft is present, it is used by default in "Automatic" mode) [new] Windows - New option "Use wintun driver (OpenVPN>=2.5)" under "Preferences -> Advanced" automates ovpn directive Quote Share this post Link to post
Grindle222 1 Posted ... Seeing your notice of the 2.19.1 beta, I downloaded it and attempted to install it. On my system (the Ubuntu 20.04 release candidate, running Wayland), which had been running Eddie 2.19.0 (as well as previous versions before), the installation process seemed to go well, but then I was unable to open Eddie. I got a quick flash telling me it was opening, but then nothing. I tried rebooting, still no luck. I uninstalled it, then reinstalled 2.19.0, and it is working fine again. Quote Share this post Link to post
BlueBanana 39 Posted ... 9 minutes ago, Grindle222 said: Seeing your notice of the 2.19.1 beta, I downloaded it and attempted to install it. On my system (the Ubuntu 20.04 release candidate, running Wayland), which had been running Eddie 2.19.0 (as well as previous versions before), the installation process seemed to go well, but then I was unable to open Eddie. I got a quick flash telling me it was opening, but then nothing. I tried rebooting, still no luck. I uninstalled it, then reinstalled 2.19.0, and it is working fine again. Same for me here; also running Ubuntu 20.04. Installation went fine, but then upon opening, the splash window appears and then disappears again. EDIT: Tried to open eddie-ui in a root-terminal; this is the output of the CLI: Unable to initialize native library. Maybe a CPU architecture issue. . 2020.04.18 17:47:49 - Shutdown in progress . 2020.04.18 17:47:49 - Shutdown complete Hope this helps. Quote Hide BlueBanana's signature Hide all signatures AMD Ryzen 3950X @ 105W PPL Gigabyte X570 Aorus Elite Nvidia RTX 4070 Ti Super Corsair DDR4-3200 32GB Share this post Link to post
Tech Jedi Alex 1524 Posted ... 17 minutes ago, Grindle222 said: Seeing your notice of the 2.19.1 beta, I downloaded it and attempted to install it. On my system (the Ubuntu 20.04 release candidate, running Wayland), which had been running Eddie 2.19.0 (as well as previous versions before), the installation process seemed to go well, but then I was unable to open Eddie. I got a quick flash telling me it was opening, but then nothing. I tried rebooting, still no luck. I uninstalled it, then reinstalled 2.19.0, and it is working fine again. 8 minutes ago, BlueBanana said: EDIT: Tried to open eddie-ui in a root-terminal; this is the output of the CLI: Unable to initialize native library. Maybe a CPU architecture issue. . 2020.04.18 17:47:49 - Shutdown in progress . 2020.04.18 17:47:49 - Shutdown complete Can reproduce on $ uname -a Linux hostname 5.5.0-1-amd64 #1 SMP Debian 5.5.13-2 (2020-03-30) x86_64 GNU/Linux Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
go558a83nk 383 Posted ... 2 hours ago, Clodo said: Version 2.19.1 (Sat, 18 Apr 2020 11:14:36 +0000) [bugfix] Linux - Fix issue with Network Lock IPv6-only incoming whitelist [bugfix] - http-100-continue issue [bugfix] - Special condition elevation checks (may resolve "Unable to start (no-socket)" issues). [change] - Removed curl binary dependencies [new] Linux - New Network Lock with nftables (if nft is present, it is used by default in "Automatic" mode) [new] Windows - New option "Use wintun driver (OpenVPN>=2.5)" under "Preferences -> Advanced" automates ovpn directive For the wintun option do I need to install openvpn 2.5 (thus the wintun driver) manually or does this version of eddie install it automatically? Quote Share this post Link to post
iwih2gk 98 Posted ... Quote Installation went fine, but then upon opening, the splash window appears and then disappears again. Same here on Buster. 2.19.0 was running perfectly on this end. Quote Share this post Link to post
iwih2gk 98 Posted ... Quote Clodo ----[new] Linux - New Network Lock with nftables (if nft is present, it is used by default in "Automatic" mode) Does this mean that I could add nft to a Buster system and then block all incoming and outgoing during boot of my system? Proceeding: My wish list ---------------- > After booting the system ONLY Eddie could gain a connection leaving no chance for an accidental connection outside of the tunnel. Before upgrading to Buster I could do that on Stretch using UFW (IP tables frontend). Just asking! ps - I want to use Eddie and not have to enter individual IP's for the servers I use while creating the firewall. Just a general closed system where Eddie creates the way out and then writes back my firewall upon exit. Quote Share this post Link to post
encrypted 13 Posted ... Skipped 2.19.0 (because Linux) but trying to run 2.19.1 crashed at start. Running *buntu 18.04. Luckily I keep old versions for local sneakernetting and installing the previous 2.18.9 with "dpkg -i" got Eddie up and running again. FWIW I have also installed the latest Openvpn 2.4.9 from https://build.openvpn.net/debian/openvpn/release/2.4/pool/bionic/main/o/openvpn/ Quote Share this post Link to post
nlbRxwy 2 Posted ... Same here, on Debian. Upgraded and got the error . Quote Share this post Link to post
monstrocity 37 Posted ... Eddie 2.19.1 beta immediately crashes on Linux Mint 19.3. Sorry. Unable to post logs because the UI just force closes - reverted back to 2.18.9 stable. Quote Share this post Link to post
zsam288 39 Posted ... 22 hours ago, go558a83nk said: For the wintun option do I need to install openvpn 2.5 (thus the wintun driver) manually or does this version of eddie install it automatically? good point, everything should be automated Quote Share this post Link to post
Clodo 177 Posted ... We cleaned the above post on Linux build crash for simplicity's sake. We have detected the issue and we are working to resolve it. Quote Share this post Link to post
scooby0786 6 Posted ... Guys, on the new version on the log-in page of Eddie, that nice padlock symbol that shadow reflects behind it has disappeared. Can we have that back please? It looked nice as a design. Also, I'm unable to resize the Eddie window, on Eddie 2.16.3 this was easily done by going to the edge and just dragging the side closer or wider. These should be easy to implement. Now the difficult bit. In Eddie, under "Microsoft Windows Only", there are two boxes. "Uninstall standard driver" and the wintun driver box that is shaded grey at the moment. For the future updates, if feasible, can we install both drivers in the installation stage and from that part in Eddie we can select which driver it should use? That way we can check with which driver it performs best. If I should post this somewhere, please let me know. All the best with the design and thanks for the hard-work behind the scenes. Quote Share this post Link to post
pfolk 6 Posted ... issues I encountered w/ this beta on Win 10 LTSC: (1) cannot resize GUI other than making it larger (2) the auto TAP driver upgrade from 2.23.x to 2.24.x failed - GUI froze/hung for 2 mins (disabled that option in prefs then, once GUI was responsive again) I was going to use wintun driver anyways, which I successfully did - DL speed doubled. Quote Share this post Link to post
Staff 10436 Posted ... Version 2.19.2 (Tue, 21 Apr 2020 12:42:14 +0000) [bugfix] - Linux - Fixed crash at startup [bugfix] - Windows - Fixed an issue about detection of wintun driver Other feedbacks are under investigation. Thx. Quote Share this post Link to post
BlueBanana 39 Posted ... Hmm, when i go to Ubunu/Debian -> Other Versions -> Experimental, nothing happens when i click the download button... 1 encrypted reacted to this Quote Hide BlueBanana's signature Hide all signatures AMD Ryzen 3950X @ 105W PPL Gigabyte X570 Aorus Elite Nvidia RTX 4070 Ti Super Corsair DDR4-3200 32GB Share this post Link to post
funkoholic 1 Posted ... Looks like CLI version is there, but no GUI. Quote Share this post Link to post
Grindle222 1 Posted ... 6 hours ago, BlueBanana said: Hmm, when i go to Ubunu/Debian -> Other Versions -> Experimental, nothing happens when i click the download button... Yep, I got exactly the same: nothing happens when I click the download button. I, too, am using - or trying to use - the Debian/Ubuntu version. (Just to check things out further, I checked and found that the download button works with the OpenSUSE and Fedora versions, and so I suspect for the rest of the Linux OSes, too. That's no help for those of us using Debian/Ubuntu, of course.) Quote Share this post Link to post
Clodo 177 Posted ... linux .deb x64 resolved, thx, my apologies, an issue in deployment system. Quote Share this post Link to post
Grindle222 1 Posted ... 2 hours ago, Clodo said: linux .deb x64 resolved, thx, my apologies, an issue in deployment system. I just downloaded it and installed it. Thanks! So far, so good. Quote Share this post Link to post
