Berlingo
Eddie suddenly stopped connecting
Week ago i notice issue connecting to VPN with Eddie, i am running default settings.
I tried playing around with disabling different features like "Check Airvpn DNS" and "Check if the tunnel works" as suggested in different topics with no luck.
I am using default settings (which was working great for couple month).
Here is the last part of the log when it fails ( I tried connecting to different servers)
. 2020.04.04 05:56:50 - Interface Ethernet metric changed from Automatic to 3, layer IPv4
. 2020.04.04 05:56:50 - Interface Ethernet metric changed from Automatic to 3, layer IPv6
. 2020.04.04 05:56:50 - DNS leak protection with packet filtering enabled.
. 2020.04.04 05:56:51 - DNS IPv4 of a network adapter forced (Ethernet, from automatic to 10.7.198.1)
. 2020.04.04 05:56:51 - DNS IPv6 of a network adapter forced (Ethernet, from automatic to *:7a:*:*::1)
. 2020.04.04 05:56:51 - Routes, added a new route, 217.151.*.* for gateway 10.7.198.1
. 2020.04.04 05:56:51 - Routes, added a new route, 2001:ac8:*:3:*:7fe8:*:812a for gateway *:7a:*:*::1
. 2020.04.04 05:56:51 - Flushing DNS
I 2020.04.04 05:56:54 - Checking route IPv4
. 2020.04.04 05:57:15 - curl: (28) Operation timed out after 20019 milliseconds with 0 out of 0 bytes received
. 2020.04.04 05:57:15 - Checking route (2° try)
. 2020.04.04 05:57:36 - curl: (28) Operation timed out after 20017 milliseconds with 0 out of 0 bytes received
. 2020.04.04 05:57:36 - Checking route (3° try)
. 2020.04.04 05:57:58 - curl: (28) Operation timed out after 20004 milliseconds with 0 out of 0 bytes received
. 2020.04.04 05:57:58 - OpenVPN > Initialization Sequence Completed
! 2020.04.04 05:57:58 - Disconnecting
@Berlingo
Can you please check your Eddie version? If it's older than 2.18.9 please upgrade and test again.
You can download Eddie latest stable release (currently 2.18.9) for Windows here:
https://airvpn.org/windows
You can download Eddie latest stable release (currently 2.18.9) for Linux here:
https://airvpn.org/linux
You can download Eddie latest stable release (currently 2.18.9) for Mac here:
https://airvpn.org/macos
6 minutes ago, Staff said:
@Berlingo
Thank you for the suggest, I downloaded the new version, yet still doesn't work with the (same?) log output:
. 2020.04.04 06:35:10 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4
. 2020.04.04 06:35:10 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6
. 2020.04.04 06:35:11 - DNS leak protection with packet filtering enabled.
. 2020.04.04 06:35:11 - Routes, added a new route, 2.58.*.* for gateway 10.15.38.1
. 2020.04.04 06:35:11 - Routes, added a new route, 2001:*:31:67:*:*:*:a9f0 for gateway *:7a:*:*::1
. 2020.04.04 06:35:11 - Flushing DNS
I 2020.04.04 06:35:12 - Checking route IPv4
. 2020.04.04 06:35:32 - curl: (28) Operation timed out after 20000 milliseconds with 0 out of 0 bytes received
. 2020.04.04 06:35:32 - Checking route (2° try)
. 2020.04.04 06:35:53 - curl: (28) Operation timed out after 20023 milliseconds with 0 out of 0 bytes received
. 2020.04.04 06:35:53 - Checking route (3° try)
. 2020.04.04 06:36:15 - curl: (28) Operation timed out after 20009 milliseconds with 0 out of 0 bytes received
E 2020.04.04 06:36:15 - Checking route IPv4 failed.
. 2020.04.04 06:36:15 - OpenVPN > Initialization Sequence Completed
! 2020.04.04 06:36:15 - Disconnecting
