onei 0 Posted ... Since 3-4 days ago whenever I try to connect to any server while using default settings or any other UDP protocol (tried quite few ports) progress gets stuck on IPv4 route check and eventually disconnects after 2nd try. Sometimes it rarely does connect but it is abnormally slow, I can't even load google homepage. TCP and SSH still works nominally. Pretty sure it has something to do with my ISP ( Turkey, TTNET ) as I can still use UDP with another ISP on the same computer. Trying to find out if anyone else reported the same issue on my ISP and if there is anything I can do to circumvent the problem on my end. Quote Share this post Link to post
Tech Jedi Alex 1499 Posted ... Sure it's not a router thing? How do you connect to the second ISP, is it a GSM provider? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
onei 0 Posted ... Second ISP is a GSM provider, connecting through wifi-hotspot from phone. Well its possible it's a router thing, but nothing has changed about my router/modem set-up in a long time, are there any settings widely known to be creating issues on routers? Quote Share this post Link to post
Tech Jedi Alex 1499 Posted ... Just now, onei said: are there any settings widely known to be creating issues on routers? Yeah. In the past few years the occasional mention of "QoS" or "UDP flood protection" in firewall settings was there. If your router is managed by your ISP, which is mostly the case with DOCSIS-based internet access but sometimes also xDSL, chances are settings were changed or the router got an upgrade overnight, perhaps even introducing these firewall settings or turning them on. Is this a possible scenario with TTNET? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
onei 0 Posted ... Connection is xDSL, router/modem (TP-LINK W8970) is something I bought myself and as far as I know is not managed by the ISP, I looked over the settings and there is no Bandwidth Control or Firewall settings enabled at the moment. I don't know if this has anything to do with ISP management of the router but CWMP is also disabled. I am pretty tech illiterate unfortunately, can ISP's push upgrades or modify settings for 3rd party routers? Quote Share this post Link to post
Tech Jedi Alex 1499 Posted ... 2 hours ago, onei said: I am pretty tech illiterate unfortunately, can ISP's push upgrades or modify settings for 3rd party routers? Usually no, unless the management interfaces used are standardized, but even then, an ISP cannot support all kinds of routers and usually only does so with routers they manufactured themselves. In Germany for example we have the Fritz!Box line of routers with TR-064 and TR-069 protocol support, both of which are used for remote router management. And because of its popularity, pretty much every ISP here at least supports autoconfiguration for the "flagship models" of these routers. So if you buy one yourself, there's a certain probability the router will autoconfigure itself in the ISP's network. Yes, that means even without entering any credentials. If it does so, the option to enable updates from the ISP will be enabled by default, but will usually only really happen with routers you rent from ISPs, not with your own. I just searched for CWMP and it's TP-Link's name for TR-069. Now that this is disabled, the ISP was not involved and we should look somewhere else. Do you happen to use a WLAN connection? If yes, 2.4 or 5 GHz? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
onei 0 Posted ... 39 minutes ago, giganerd said: Do you happen to use a WLAN connection? If yes, 2.4 or 5 GHz? Ethernet and WLAN 2.4GHz produce the same result. Quote Share this post Link to post
Tech Jedi Alex 1499 Posted ... Do you have another machine which you can test? Maybe it's also time for some logs. In the Logs tab of Eddie, click the lifebelt icon and paste whatever you find in there after you tried to connect once. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
onei 0 Posted ... On 3/24/2020 at 1:55 AM, giganerd said: Do you have another machine which you can test? Yes, same issue. I also had another router laying around, that also didn't change anything. Here is the log, it seems it just times out at route check. Eddie System/Environment Report - 3/25/2020 - 00:49 UTC Eddie version: 2.18.7 Eddie OS build: windows_x64 Eddie architecture: x64 OS type: Windows OS name: Windows 10 Pro OS version: Microsoft Windows NT 10.0.18363.0 OS architecture: x64 Mono /.Net Framework: v4.0.30319 TUN driver: TAP-Windows Adapter V9, version 9.24.2 OpenVPN: 2.4.8 - OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) Hummingbird: () SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe) SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) curl: 7.68.0 (C:\Program Files\AirVPN\curl.exe) Profile path: C:\Users\hilmi\AppData\Local\Eddie\default.profile Data path: C:\Users\hilmi\AppData\Local\Eddie Application path: C:\Program Files\AirVPN Executable path: C:\Program Files\AirVPN\Eddie-UI.exe Command line arguments: (1 args) path="home" Network Lock Active: No Connected to VPN: No Detected DNS: 8.8.4.4, 8.8.8.8 Test DNS IPv4: Ok Test DNS IPv6: Failed Test Ping IPv4: 65 ms Test Ping IPv6: -1 ms Test HTTP IPv4: Ok Test HTTP IPv6: Error:curl: (7) Failed to connect to 2a03:b0c0:2:d0::11b4:6001 port 80: Network unreachable Test HTTPS: Ok ---------------------------- Important options not at defaults: login: (omissis) password: (omissis) remember: True advanced.expert: True ui.unit: bytes ---------------------------- Logs: . 2020.03.25 03:47:08 - Eddie version: 2.18.7 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: Microsoft Windows NT 10.0.18363.0, Mono/.Net: v4.0.30319 . 2020.03.25 03:47:08 - Command line arguments (1): path="home" . 2020.03.25 03:47:08 - Profile path: C:\Users\hilmi\AppData\Local\Eddie\default.profile . 2020.03.25 03:47:09 - Reading options from C:\Users\hilmi\AppData\Local\Eddie\default.profile . 2020.03.25 03:47:11 - Tun Driver - TAP-Windows Adapter V9, version 9.24.2 . 2020.03.25 03:47:11 - OpenVPN - Version: 2.4.8 - OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2020.03.25 03:47:11 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe) . 2020.03.25 03:47:11 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) . 2020.03.25 03:47:11 - curl - Version: 7.68.0 (C:\Program Files\AirVPN\curl.exe) I 2020.03.25 03:47:12 - Ready . 2020.03.25 03:47:13 - Collect information about AirVPN completed I 2020.03.25 03:47:20 - Session starting. I 2020.03.25 03:47:28 - Checking authorization ... ! 2020.03.25 03:47:29 - Connecting to Aspidiske (Netherlands, Alblasserdam) . 2020.03.25 03:47:29 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019 . 2020.03.25 03:47:29 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.03.25 03:47:29 - OpenVPN > library versions: OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 . 2020.03.25 03:47:29 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.03.25 03:47:29 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.03.25 03:47:29 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.03.25 03:47:29 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.03.25 03:47:29 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]134.19.179.197:443 . 2020.03.25 03:47:29 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2020.03.25 03:47:29 - OpenVPN > UDP link local: (not bound) . 2020.03.25 03:47:29 - OpenVPN > UDP link remote: [AF_INET]134.19.179.197:443 . 2020.03.25 03:47:29 - OpenVPN > TLS: Initial packet from [AF_INET]134.19.179.197:443, sid=52c52caa 1e3557d1 . 2020.03.25 03:47:30 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.03.25 03:47:30 - OpenVPN > VERIFY KU OK . 2020.03.25 03:47:30 - OpenVPN > Validating certificate extended key usage . 2020.03.25 03:47:30 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.03.25 03:47:30 - OpenVPN > VERIFY EKU OK . 2020.03.25 03:47:30 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Aspidiske, emailAddress=info@airvpn.org . 2020.03.25 03:47:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2020.03.25 03:47:38 - OpenVPN > [Aspidiske] Peer Connection Initiated with [AF_INET]134.19.179.197:443 . 2020.03.25 03:47:39 - OpenVPN > SENT CONTROL [Aspidiske]: 'PUSH_REQUEST' (status=1) . 2020.03.25 03:47:40 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.33.130.1,dhcp-option DNS6 fde6:7a:7d20:1d82::1,tun-ipv6,route-gateway 10.33.130.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1d82::10af/64 fde6:7a:7d20:1d82::1,ifconfig 10.33.130.177 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2020.03.25 03:47:40 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2020.03.25 03:47:40 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2020.03.25 03:47:40 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2020.03.25 03:47:40 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2020.03.25 03:47:40 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2020.03.25 03:47:40 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2020.03.25 03:47:40 - OpenVPN > OPTIONS IMPORT: peer-id set . 2020.03.25 03:47:40 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2020.03.25 03:47:40 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2020.03.25 03:47:40 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2020.03.25 03:47:40 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.03.25 03:47:40 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.03.25 03:47:40 - OpenVPN > interactive service msg_channel=0 . 2020.03.25 03:47:40 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=17 HWADDR=68:17:29:ab:38:df . 2020.03.25 03:47:40 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2020.03.25 03:47:40 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2020.03.25 03:47:40 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2020.03.25 03:47:40 - OpenVPN > open_tun . 2020.03.25 03:47:40 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{C3E4E7D1-3C25-4B67-83EF-1C40F2133A83}.tap . 2020.03.25 03:47:40 - OpenVPN > TAP-Windows Driver Version 9.24 . 2020.03.25 03:47:40 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.33.130.0/10.33.130.177/255.255.255.0 [SUCCEEDED] . 2020.03.25 03:47:40 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.33.130.177/255.255.255.0 on interface {C3E4E7D1-3C25-4B67-83EF-1C40F2133A83} [DHCP-serv: 10.33.130.254, lease-time: 31536000] . 2020.03.25 03:47:40 - OpenVPN > Successful ARP Flush on interface [18] {C3E4E7D1-3C25-4B67-83EF-1C40F2133A83} . 2020.03.25 03:47:41 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=18 fde6:7a:7d20:1d82::10af store=active . 2020.03.25 03:47:42 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Local Area Connection static fde6:7a:7d20:1d82::1 validate=no . 2020.03.25 03:47:42 - Detected an OpenVPN bug (On-Link route on VPN range), autofix. . 2020.03.25 03:47:42 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1d82::/64 -> fde6:7a:7d20:1d82::10af metric 0) dev Local Area Connection . 2020.03.25 03:47:42 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1d82::/64 interface=18 fe80::8 store=active . 2020.03.25 03:47:42 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.03.25 03:47:47 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2020.03.25 03:47:47 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 134.19.179.197 MASK 255.255.255.255 192.168.1.1 . 2020.03.25 03:47:47 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4 . 2020.03.25 03:47:47 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.03.25 03:47:47 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.33.130.1 . 2020.03.25 03:47:47 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.03.25 03:47:47 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.03.25 03:47:47 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.33.130.1 . 2020.03.25 03:47:47 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.03.25 03:47:47 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.03.25 03:47:47 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1d82::1 metric -1) dev Local Area Connection . 2020.03.25 03:47:47 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=18 fe80::8 store=active . 2020.03.25 03:47:47 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.03.25 03:47:47 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1d82::1 metric -1) dev Local Area Connection . 2020.03.25 03:47:47 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=18 fe80::8 store=active . 2020.03.25 03:47:47 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.03.25 03:47:47 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1d82::1 metric -1) dev Local Area Connection . 2020.03.25 03:47:47 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=18 fe80::8 store=active . 2020.03.25 03:47:47 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.03.25 03:47:47 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1d82::1 metric -1) dev Local Area Connection . 2020.03.25 03:47:47 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=18 fe80::8 store=active . 2020.03.25 03:47:47 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.03.25 03:47:47 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4 . 2020.03.25 03:47:47 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6 . 2020.03.25 03:47:47 - DNS leak protection with packet filtering enabled. . 2020.03.25 03:47:48 - Routes, added a new route, 134.19.179.195 for gateway 10.33.130.1 . 2020.03.25 03:47:48 - Routes, added a new route, 2a00:1678:2470:1101:6c5a:e721:17c9:92f8 for gateway fde6:7a:7d20:1d82::1 . 2020.03.25 03:47:48 - Flushing DNS I 2020.03.25 03:47:51 - Checking route IPv4 . 2020.03.25 03:48:11 - curl: (28) Operation timed out after 20001 milliseconds with 0 out of 0 bytes received . 2020.03.25 03:48:11 - Checking route (2° try) . 2020.03.25 03:48:32 - curl: (28) Operation timed out after 20001 milliseconds with 0 out of 0 bytes received . 2020.03.25 03:48:32 - Checking route (3° try) . 2020.03.25 03:48:54 - curl: (28) Operation timed out after 20000 milliseconds with 0 out of 0 bytes received E 2020.03.25 03:48:54 - Checking route IPv4 failed. . 2020.03.25 03:48:54 - OpenVPN > Initialization Sequence Completed ! 2020.03.25 03:48:54 - Disconnecting . 2020.03.25 03:48:54 - Routes, removed a route previously added, 134.19.179.195 for gateway 10.33.130.1 . 2020.03.25 03:48:54 - Routes, removed a route previously added, 2a00:1678:2470:1101:6c5a:e721:17c9:92f8 for gateway fde6:7a:7d20:1d82::1 . 2020.03.25 03:48:54 - Sending soft termination signal . 2020.03.25 03:49:01 - Connection terminated. . 2020.03.25 03:49:02 - DNS leak protection with packet filtering disabled. . 2020.03.25 03:49:02 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4 . 2020.03.25 03:49:02 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv6 . 2020.03.25 03:49:02 - OpenVPN > SIGTERM received, sending exit notification to peer . 2020.03.25 03:49:02 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 134.19.179.197 MASK 255.255.255.255 192.168.1.1 . 2020.03.25 03:49:02 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2020.03.25 03:49:02 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.33.130.1 . 2020.03.25 03:49:02 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2020.03.25 03:49:02 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.33.130.1 . 2020.03.25 03:49:02 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2020.03.25 03:49:02 - OpenVPN > delete_route_ipv6(::/3) . 2020.03.25 03:49:02 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 interface=18 fe80::8 store=active . 2020.03.25 03:49:02 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.03.25 03:49:02 - OpenVPN > delete_route_ipv6(2000::/4) . 2020.03.25 03:49:02 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=18 fe80::8 store=active . 2020.03.25 03:49:02 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.03.25 03:49:02 - OpenVPN > delete_route_ipv6(3000::/4) . 2020.03.25 03:49:02 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=18 fe80::8 store=active . 2020.03.25 03:49:02 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.03.25 03:49:02 - OpenVPN > delete_route_ipv6(fc00::/7) . 2020.03.25 03:49:02 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=18 fe80::8 store=active . 2020.03.25 03:49:02 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.03.25 03:49:02 - OpenVPN > Closing TUN/TAP interface . 2020.03.25 03:49:02 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1d82::/64) . 2020.03.25 03:49:02 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1d82::/64 interface=18 fe80::8 store=active . 2020.03.25 03:49:02 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address Local Area Connection fde6:7a:7d20:1d82::10af store=active . 2020.03.25 03:49:02 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns Local Area Connection all . 2020.03.25 03:49:02 - OpenVPN > TAP: DHCP address released . 2020.03.25 03:49:02 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ---------------------------- Network Interfaces and Routes: { "support_ipv4": true, "support_ipv6": true, "routes": [ { "address": "0.0.0.0\/0", "interface": "{BF44FCC2-1D3C-42BA-9B01-087F8F19572F}", "gateway": "192.168.1.1", "metric": "55" }, { "address": "127.0.0.0\/8", "interface": "{FC7353A6-F7A3-11E7-B8B6-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.0.0.1", "interface": "{FC7353A6-F7A3-11E7-B8B6-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.255.255.255", "interface": "{FC7353A6-F7A3-11E7-B8B6-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "192.168.1.0\/24", "interface": "{BF44FCC2-1D3C-42BA-9B01-087F8F19572F}", "gateway": "link", "metric": "311" }, { "address": "192.168.1.100", "interface": "{BF44FCC2-1D3C-42BA-9B01-087F8F19572F}", "gateway": "link", "metric": "311" }, { "address": "192.168.1.255", "interface": "{BF44FCC2-1D3C-42BA-9B01-087F8F19572F}", "gateway": "link", "metric": "311" }, { "address": "224.0.0.0\/4", "interface": "{FC7353A6-F7A3-11E7-B8B6-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "224.0.0.0\/4", "interface": "{BF44FCC2-1D3C-42BA-9B01-087F8F19572F}", "gateway": "link", "metric": "311" }, { "address": "255.255.255.255", "interface": "{FC7353A6-F7A3-11E7-B8B6-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "255.255.255.255", "interface": "{BF44FCC2-1D3C-42BA-9B01-087F8F19572F}", "gateway": "link", "metric": "311" }, { "address": "::1", "interface": "{FC7353A6-F7A3-11E7-B8B6-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "fe80::\/64", "interface": "{BF44FCC2-1D3C-42BA-9B01-087F8F19572F}", "gateway": "link", "metric": "311" }, { "address": "fe80::34b5:2659:299f:820c", "interface": "{BF44FCC2-1D3C-42BA-9B01-087F8F19572F}", "gateway": "link", "metric": "311" }, { "address": "ff00::\/8", "interface": "{FC7353A6-F7A3-11E7-B8B6-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "ff00::\/8", "interface": "{BF44FCC2-1D3C-42BA-9B01-087F8F19572F}", "gateway": "link", "metric": "311" } ], "interfaces": [ { "friendly": "Ethernet", "id": "{513FA8BB-3BBD-473D-BEE0-59C188A95D67}", "name": "Ethernet", "description": "Realtek PCIe GBE Family Controller", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::81bc:876:5036:8014", "169.254.128.20" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Ethernet 3", "id": "{38C7E723-A779-4FA8-AA28-370778807BE7}", "name": "Ethernet 3", "description": "TAP-NordVPN Windows Adapter V9", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::3c49:bffa:d855:a988", "169.254.169.136" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Local Area Connection", "id": "{C3E4E7D1-3C25-4B67-83EF-1C40F2133A83}", "name": "Local Area Connection", "description": "TAP-Windows Adapter V9", "type": "53", "status": "Down", "bytes_received": "1955242", "bytes_sent": "1476403", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::3939:6343:4265:3bb5", "169.254.59.181" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Local Area Connection* 2", "id": "{7E139474-F57C-439B-B984-372EA542F601}", "name": "Local Area Connection* 2", "description": "Microsoft Wi-Fi Direct Virtual Adapter #4", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::86b:8a84:ea9c:9c74", "169.254.156.116" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Local Area Connection* 3", "id": "{EE963DEF-D958-437D-BAA3-E9BE5146FD34}", "name": "Local Area Connection* 3", "description": "Microsoft Wi-Fi Direct Virtual Adapter #5", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::b8f3:90eb:4d1d:96d4", "169.254.150.212" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Wi-Fi 2", "id": "{BF44FCC2-1D3C-42BA-9B01-087F8F19572F}", "name": "Wi-Fi 2", "description": "Intel(R) Centrino(R) Wireless-N 2230", "type": "Wireless80211", "status": "Up", "bytes_received": "162351952", "bytes_sent": "176529088", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::34b5:2659:299f:820c", "192.168.1.100" ], "gateways": [ "192.168.1.1" ], "bind": true, "dns4": "8.8.8.8,8.8.4.4", "dns6": null }, { "friendly": "Loopback Pseudo-Interface 1", "id": "{FC7353A6-F7A3-11E7-B8B6-806E6F6E6963}", "name": "Loopback Pseudo-Interface 1", "description": "Software Loopback Interface 1", "type": "Loopback", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "::1", "127.0.0.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null } ], "ipv4-default-gateway": "192.168.1.1", "ipv4-default-interface": "{BF44FCC2-1D3C-42BA-9B01-087F8F19572F}" } ---------------------------- ipconfig /all: Windows IP Configuration Host Name . . . . . . . . . . . . : DESKTOP-GLHQ65I Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No Ethernet adapter Ethernet: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller Physical Address. . . . . . . . . : 00-90-F5-D4-F3-77 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Ethernet adapter Ethernet 3: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : TAP-NordVPN Windows Adapter V9 Physical Address. . . . . . . . . : 00-FF-38-C7-E7-23 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Unknown adapter Local Area Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : TAP-Windows Adapter V9 Physical Address. . . . . . . . . : 00-FF-C3-E4-E7-D1 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Local Area Connection* 2: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #4 Physical Address. . . . . . . . . : 68-17-29-AB-38-E0 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Local Area Connection* 3: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #5 Physical Address. . . . . . . . . : 6A-17-29-AB-38-DF DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Wi-Fi 2: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) Centrino(R) Wireless-N 2230 Physical Address. . . . . . . . . : 68-17-29-AB-38-DF DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::34b5:2659:299f:820c%17(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.1.100(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Wednesday, March 25, 2020 2:19:24 AM Lease Expires . . . . . . . . . . : Thursday, March 26, 2020 2:19:23 AM Default Gateway . . . . . . . . . : 192.168.1.1 DHCP Server . . . . . . . . . . . : 192.168.1.1 DHCPv6 IAID . . . . . . . . . . . : 292034345 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-20-C8-07-73-00-90-F5-D4-F3-77 DNS Servers . . . . . . . . . . . : 8.8.8.8 8.8.4.4 NetBIOS over Tcpip. . . . . . . . : Enabled Quote Share this post Link to post
Tech Jedi Alex 1499 Posted ... In Preferences > Advanced, disable Check if the tunnel works. Then connect and check your IPs with IPLeak or any other tool. Maybe also post another support file, because in this one I'm not sure whether routes are set at all. We need to check on that. By the way, you could also disable IPv6 while you're at it. Your network doesn't seem to support it, anyway. Preferences > Networking > Layer IPv6: Block. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
