Wg99Cx2h
Question about using OpenVPN app
If I wanted to use the OpenVPN app to connect to AirVPN's VPN servers, downloaded the config files I want and made sure nobody that is not me can physically access my device, would that be significantly less safe than just using Eddie? (not considering the fact that obviously I would not be able to use the network lock)
What makes you think that?
No, NetLock is just a bunch of firewall rules, so the real obvious thing is that you can have a NetLock with whatever firewall you are using.
Also, it's a bit ambiguous: Are we talking Android or PC here?
Is there somewhere that i can view the extra firewall rules?
I can add them manually to the software firewall i use.
thanks
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety". Benjamin Franklin
PC. I'm not an expert here, but based on what I know, in the config files there is (necessarily) everything needed to connect to the servers, keys included, and the config files are in plain text. Doesn't that  mean that anyone/thing that can read them can decrypt my encrypted traffic?
No. Think of them as the key to an AirVPN server connection. Someone using this config will create a second connection to AirVPN, nothing more.
Ok, thank you a lot for the info!
