Not connected, Your IP: 216.73.216.63
cqs
Hummingbird doesn't work on musl libc
ldd result from Void Linux musl
	/lib64/ld-linux-x86-64.so.2 (0x7effc856e000)
	libstdc++.so.6 => /lib/libstdc++.so.6 (0x7effc80e0000)
	libm.so.6 => /lib64/ld-linux-x86-64.so.2 (0x7effc856e000)
	libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x7effc80c7000)
	libpthread.so.0 => /lib64/ld-linux-x86-64.so.2 (0x7effc856e000)
	libc.so.6 => /lib64/ld-linux-x86-64.so.2 (0x7effc856e000)
Error relocating hummingbird: __res_ninit: symbol not found
ldd result from Void Linux glibc
	linux-vdso.so.1 (0x00007ffe8df6b000)
	libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00007fdf68645000)
	libm.so.6 => /usr/lib/libm.so.6 (0x00007fdf68500000)
	libgcc_s.so.1 => /usr/lib/libgcc_s.so.1 (0x00007fdf684e6000)
	libpthread.so.0 => /usr/lib/libpthread.so.0 (0x00007fdf684c5000)
	libc.so.6 => /usr/lib/libc.so.6 (0x00007fdf68302000)
	/lib64/ld-linux-x86-64.so.2 => /lib/ld-linux-x86-64.so.2 (0x00007fdf68ab4000)
ldd result from Alpine Linux
	/lib64/ld-linux-x86-64.so.2 (0x7f6c1ff2e000)
	libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x7f6c1fb9d000)
	libm.so.6 => /lib64/ld-linux-x86-64.so.2 (0x7f6c1ff2e000)
	libgcc_s.so.1 => /usr/lib/libgcc_s.so.1 (0x7f6c1fb89000)
	libpthread.so.0 => /lib64/ld-linux-x86-64.so.2 (0x7f6c1ff2e000)
	libc.so.6 => /lib64/ld-linux-x86-64.so.2 (0x7f6c1ff2e000)
Workaround
You can use chroots, or the more elegant solution, Bedrock Linux, to pull in a distro that does use glibc and run Hummingbird from there. This is not a good fix if you are trying to keep the system minimalist and less complex.
