> Distro is Void Linux glibc.
* sitnl_send: rtnl: generic error: No such process (-3)
* Error while executing NetlinkRoute4(add: 0) eth0: -3
* TUN Error: tun_open_error: error opening tun device /dev/net/tun: No such file or directory
* EVENT: TUN_SETUP_FAILED tun_open_error: error opening tun device /dev/net/tun: No such file or directory [FATAL-ERR]
* ERROR: TUN_SETUP_FAILED
* EVENT: DISCONNECTED
* Successfully restored DNS settings
* Network filter successfully restored
* Client exception in transport_recv: tun_exception: not connected
* Thread finished
The fix is to create the TUN device node.
mkdir -p /dev/net
mknod /dev/net/tun c 10 200
Can this be integrated into Hummingbird by default in some fashion?
Wouldn't a pre-up script suffice? I'm reading it the first time ever that /dev/net/tun does not exist, so I believe it's a niche problem.
