Staff 10723 Posted ... Hello! We're glad to inform you that Hummingbird 1.0.1 has just been released. Hummingbird is a free and open source software by AirVPN for: Linux x86-64 Linux ARM 32 (example: Raspbian for Raspberry PI) Linux ARM 64 macOS (Mojave or higher version required) based on OpenVPN3-AirVPN 3.6 library supporting CHACHA20-POLY1305 cipher on OpenVPN Data Channel and Control Channel. Hummingbird is very fast and has a tiny RAM footprint. AES-CBC and AES-GCM are supported as well. Version 1.0.1 uses new OpenVPN3-AirVPN 3.6.2 library which features various improving minor changes and fixes an annoying bug which caused "ncp-disable" directive to be ignored in profiles. Note: command line options --ncp-disable and --cipher, when specified, override profile directives. Please consult the following page for details, changelog, instructions and download links.https://airvpn.org/hummingbird/readme/ Hummingbird source code is available here:https://gitlab.com/AirVPN/hummingbird OpenVPN3-AirVPN library source code is available here:https://github.com/AirVPN/openvpn3-airvpnImportant: Hummingbird is not aimed to Android. To have CHACHA20-POLY1305 on Android, please run our software Eddie Android edition, which uses our OpenVPN3-AirVPN library. Kind regards 1 nexsteppe reacted to this Quote Share this post Link to post
Tech Jedi Alex 1586 Posted ... Brand new development of the IPv6 problem. I have probably identified the bug. But here goes the story first. $ sudo ./hummingbird -N off -i tls-crypt.ovpn Hummingbird - AirVPN OpenVPN 3 Client 1.0.1 - 24 January 2020 Fri Jan 24 19:10:21.913 2020 Starting thread Fri Jan 24 19:10:21.913 2020 OpenVPN core 3.6.2 AirVPN linux x86_64 64-bit Fri Jan 24 19:10:21.925 2020 Frame=512/2048/512 mssfix-ctrl=1250 Fri Jan 24 19:10:21.931 2020 UNUSED OPTIONS 2 [resolv-retry] [infinite] 3 [nobind] 4 [persist-key] 5 [persist-tun] 6 [auth-nocache] 7 [route-delay] [5] 8 [verb] [3] 9 [explicit-exit-notify] [5] 17 [pull-filter] [ignore] [dhcp-option DNS] Fri Jan 24 19:10:21.931 2020 EVENT: RESOLVE Fri Jan 24 19:10:21.931 2020 WARNING: Network filter and lock is disabled Fri Jan 24 19:10:21.931 2020 Contacting [2a00:c98:2050:a007:ba5e:c9f1:828f:291c]:443 via UDP Fri Jan 24 19:10:21.931 2020 EVENT: WAIT Fri Jan 24 19:10:21.932 2020 net_route_best_gw query IPv6: 2a00:c98:2050:a007:ba5e:c9f1:828f:291c/128 Fri Jan 24 19:10:21.932 2020 sitnl_route_best_gw result: via UNSPEC dev Fri Jan 24 19:10:21.932 2020 Fri Jan 24 19:10:21.932 2020 Connecting to [2a00:c98:2050:a007:ba5e:c9f1:828f:291c]:443 (2a00:c98:2050:a007:ba5e:c9f1:828f:291c) via UDPv6 Fri Jan 24 19:10:21.956 2020 EVENT: CONNECTING Fri Jan 24 19:10:21.956 2020 Tunnel Options:V4,dev-type tun,link-mtu 1602,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-256-CBC,auth SHA512,keysize 256,key-method 2,tls-client Fri Jan 24 19:10:21.956 2020 Peer Info: IV_VER=3.6.2 AirVPN IV_PLAT=linux IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.0.1 IV_SSL=mbed TLS 2.16.3 Fri Jan 24 19:10:22.014 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Fri Jan 24 19:10:22.014 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 4F issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Serpens, emailAddress=info@airvpn.org issued on : 2016-12-02 16:51:13 expires on : 2026-11-30 16:51:13 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Fri Jan 24 19:10:22.306 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Fri Jan 24 19:10:22.307 2020 Session is ACTIVE Fri Jan 24 19:10:22.307 2020 EVENT: GET_CONFIG Fri Jan 24 19:10:22.307 2020 Sending PUSH_REQUEST to server... Fri Jan 24 19:10:22.633 2020 OPTIONS: 0 [route] [192.168.0.0] [255.255.0.0] [net_gateway] 1 [comp-lzo] [no] 2 [redirect-gateway] [ipv6] [def1] [bypass-dhcp] 3 [dhcp-option] [DNS] [10.11.250.1] 4 [dhcp-option] [DNS6] [fde6:7a:7d20:7fa::1] 5 [tun-ipv6] 6 [route-gateway] [10.11.250.1] 7 [topology] [subnet] 8 [ping] [10] 9 [ping-restart] [60] 10 [ifconfig-ipv6] [fde6:7a:7d20:7fa::1083/64] [fde6:7a:7d20:7fa::1] 11 [ifconfig] [10.11.250.133] [255.255.255.0] 12 [peer-id] [4] 13 [cipher] [AES-256-GCM] Fri Jan 24 19:10:22.633 2020 PROTOCOL OPTIONS: cipher: AES-256-GCM digest: NONE ncp enabled: yes compress: LZO_STUB peer ID: 4 Fri Jan 24 19:10:22.633 2020 EVENT: ASSIGN_IP Fri Jan 24 19:10:22.633 2020 exception parsing IPv4 route: [route] [192.168.0.0] [255.255.0.0] [net_gateway] : tun_prop_route_error: tun_builder_exclude_route failed Fri Jan 24 19:10:22.633 2020 Pushed DNS Server IPv4 10.11.250.1 ignored Fri Jan 24 19:10:22.633 2020 Pushed DNS Server IPv6 fde6:7a:7d20:7fa::1 ignored Fri Jan 24 19:10:22.633 2020 net_iface_mtu_set: mtu 1500 for tun1 Fri Jan 24 19:10:22.633 2020 net_iface_up: set tun1 up Fri Jan 24 19:10:22.633 2020 net_addr_add: 10.11.250.133/24 brd 10.11.250.255 dev tun1 Fri Jan 24 19:10:22.633 2020 net_addr_add: fde6:7a:7d20:7fa::1083/64 dev tun1 Fri Jan 24 19:10:22.633 2020 net_route_add: 0.0.0.0/1 via 10.11.250.1 dev tun1 table 0 metric 0 Fri Jan 24 19:10:22.634 2020 net_route_add: 128.0.0.0/1 via 10.11.250.1 dev tun1 table 0 metric 0 Fri Jan 24 19:10:22.634 2020 net_route_add: ::/1 via fde6:7a:7d20:7fa::1 dev tun1 table 0 metric 0 Fri Jan 24 19:10:22.634 2020 net_route_add: 8000::/1 via fde6:7a:7d20:7fa::1 dev tun1 table 0 metric 0 Fri Jan 24 19:10:22.634 2020 Connected via tun Fri Jan 24 19:10:22.634 2020 LZO-ASYM init swap=0 asym=1 Fri Jan 24 19:10:22.634 2020 Comp-stub init swap=0 Fri Jan 24 19:10:22.634 2020 EVENT: CONNECTED [2a00:c98:2050:a007:ba5e:c9f1:828f:291c]:443 (2a00:c98:2050:a007:ba5e:c9f1:828f:291c) via /UDPv6 on tun/10.11.250.133/fde6:7a:7d20:7fa::1083 gw=[10.11.250.1/fde6:7a:7d20:7fa::1] ^Creceived stop signal 2 Fri Jan 24 19:10:30.042 2020 net_route_del: 8000::/1 via fde6:7a:7d20:7fa::1 dev tun1 table 0 metric 0 Fri Jan 24 19:10:30.042 2020 net_route_del: ::/1 via fde6:7a:7d20:7fa::1 dev tun1 table 0 metric 0 Fri Jan 24 19:10:30.042 2020 net_route_del: 128.0.0.0/1 via 10.11.250.1 dev tun1 table 0 metric 0 Fri Jan 24 19:10:30.042 2020 net_route_del: 0.0.0.0/1 via 10.11.250.1 dev tun1 table 0 metric 0 Fri Jan 24 19:10:30.042 2020 net_addr_del: fde6:7a:7d20:7fa::1083/64 dev tun1 Fri Jan 24 19:10:30.042 2020 net_addr_del: 10.11.250.133/24 dev tun1 Fri Jan 24 19:10:30.042 2020 net_iface_mtu_set: mtu 1500 for tun1 Fri Jan 24 19:10:30.042 2020 net_iface_up: set tun1 down Fri Jan 24 19:10:30.043 2020 Fri Jan 24 19:10:30.074 2020 EVENT: DISCONNECTED Fri Jan 24 19:10:30.074 2020 Thread finished STATS: BYTES_IN : 5510 BYTES_OUT : 1070916 PACKETS_IN : 15 PACKETS_OUT : 1416 TUN_BYTES_IN : 1031504 TUN_BYTES_OUT : 548 TUN_PACKETS_IN : 1403 TUN_PACKETS_OUT : 3 First I was a bit euphoric. Then I noticed it used tun1. I forgot I'm already connected via OpenVPN: Fri Jan 24 19:10:21.932 2020 sitnl_route_best_gw result: via UNSPEC dev […] Fri Jan 24 19:10:22.633 2020 net_iface_up: set tun1 up When I disconnected with OpenVPN and tried to connect the same bug appeared to happen: $ sudo ./hummingbird -N off -i tls-crypt.ovpn Hummingbird - AirVPN OpenVPN 3 Client 1.0.1 - 24 January 2020 Fri Jan 24 19:11:33.274 2020 Starting thread Fri Jan 24 19:11:33.275 2020 OpenVPN core 3.6.2 AirVPN linux x86_64 64-bit Fri Jan 24 19:11:33.287 2020 Frame=512/2048/512 mssfix-ctrl=1250 Fri Jan 24 19:11:33.292 2020 UNUSED OPTIONS 2 [resolv-retry] [infinite] 3 [nobind] 4 [persist-key] 5 [persist-tun] 6 [auth-nocache] 7 [route-delay] [5] 8 [verb] [3] 9 [explicit-exit-notify] [5] 17 [pull-filter] [ignore] [dhcp-option DNS] Fri Jan 24 19:11:33.292 2020 EVENT: RESOLVE Fri Jan 24 19:11:33.292 2020 WARNING: Network filter and lock is disabled Fri Jan 24 19:11:33.293 2020 Contacting [2001:ac8:20:99:fbf6:b62a:86df:b560]:443 via UDP Fri Jan 24 19:11:33.293 2020 EVENT: WAIT Fri Jan 24 19:11:33.293 2020 net_route_best_gw query IPv6: 2001:ac8:20:99:fbf6:b62a:86df:b560/128 Fri Jan 24 19:11:33.293 2020 sitnl_route_best_gw result: via fe80::9a9b:cbff:fe6d:a378 dev enp35s0 Fri Jan 24 19:11:33.293 2020 Fri Jan 24 19:11:33.293 2020 EVENT: DISCONNECTED Fri Jan 24 19:11:33.293 2020 OpenVPN3 CONNECT ERROR: ipv4_exception: error parsing IPv4 address '2001:ac8:20:99:fbf6:b62a:86df:b560' : Invalid argument Fri Jan 24 19:11:33.293 2020 Thread finished STATS: And now the funny part: I reconnected to reproduce the thing, hummingbird used a different server it seems and: $ sudo ./hummingbird -N off -i tls-crypt.ovpn [sudo] Passwort für gigan3rd: Hummingbird - AirVPN OpenVPN 3 Client 1.0.1 - 24 January 2020 Fri Jan 24 19:29:04.665 2020 Starting thread Fri Jan 24 19:29:04.665 2020 OpenVPN core 3.6.2 AirVPN linux x86_64 64-bit Fri Jan 24 19:29:04.674 2020 Frame=512/2048/512 mssfix-ctrl=1250 Fri Jan 24 19:29:04.680 2020 UNUSED OPTIONS 2 [resolv-retry] [infinite] 3 [nobind] 4 [persist-key] 5 [persist-tun] 6 [auth-nocache] 7 [route-delay] [5] 8 [verb] [3] 9 [explicit-exit-notify] [5] 17 [pull-filter] [ignore] [dhcp-option DNS] Fri Jan 24 19:29:04.680 2020 EVENT: RESOLVE Fri Jan 24 19:29:04.680 2020 WARNING: Network filter and lock is disabled Fri Jan 24 19:29:04.681 2020 Contacting [2001:ac8:20:96:226a:3a84:c3d8:dba8]:443 via UDP Fri Jan 24 19:29:04.681 2020 EVENT: WAIT Fri Jan 24 19:29:04.681 2020 net_route_best_gw query IPv6: 2001:ac8:20:96:226a:3a84:c3d8:dba8/128 Fri Jan 24 19:29:04.681 2020 sitnl_route_best_gw result: via fe80::9a9b:cbff:fe6d:a378 dev enp35s0 Fri Jan 24 19:29:04.681 2020 Fri Jan 24 19:29:04.681 2020 EVENT: DISCONNECTED Fri Jan 24 19:29:04.681 2020 OpenVPN3 CONNECT ERROR: ipv4_exception: error parsing IPv4 address '2001:ac8:20:96:226a:3a84:c3d8:dba8' : Invalid argument Fri Jan 24 19:29:04.681 2020 Thread finished STATS: Want it even funnier? Here ya go: $ sudo ./hummingbird -N off -i tls-crypt.ovpn Hummingbird - AirVPN OpenVPN 3 Client 1.0.1 - 24 January 2020 Fri Jan 24 19:31:09.398 2020 Starting thread Fri Jan 24 19:31:09.399 2020 OpenVPN core 3.6.2 AirVPN linux x86_64 64-bit Fri Jan 24 19:31:09.410 2020 Frame=512/2048/512 mssfix-ctrl=1250 Fri Jan 24 19:31:09.416 2020 UNUSED OPTIONS 2 [resolv-retry] [infinite] 3 [nobind] 4 [persist-key] 5 [persist-tun] 6 [auth-nocache] 7 [route-delay] [5] 8 [verb] [3] 9 [explicit-exit-notify] [5] 17 [pull-filter] [ignore] [dhcp-option DNS] Fri Jan 24 19:31:09.416 2020 EVENT: RESOLVE Fri Jan 24 19:31:09.416 2020 WARNING: Network filter and lock is disabled Fri Jan 24 19:31:09.416 2020 Contacting [2a00:c98:2050:a02f:da70:5acb:fd13:14a0]:443 via UDP Fri Jan 24 19:31:09.416 2020 EVENT: WAIT Fri Jan 24 19:31:09.416 2020 net_route_best_gw query IPv6: 2a00:c98:2050:a02f:da70:5acb:fd13:14a0/128 Fri Jan 24 19:31:09.416 2020 sitnl_route_best_gw result: via UNSPEC dev Fri Jan 24 19:31:09.416 2020 Fri Jan 24 19:31:09.416 2020 Connecting to [2a00:c98:2050:a02f:da70:5acb:fd13:14a0]:443 (2a00:c98:2050:a02f:da70:5acb:fd13:14a0) via UDPv6 Fri Jan 24 19:31:09.428 2020 EVENT: CONNECTING Fri Jan 24 19:31:09.429 2020 Tunnel Options:V4,dev-type tun,link-mtu 1602,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-256-CBC,auth SHA512,keysize 256,key-method 2,tls-client Fri Jan 24 19:31:09.429 2020 Peer Info: IV_VER=3.6.2 AirVPN IV_PLAT=linux IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.0.1 IV_SSL=mbed TLS 2.16.3 Fri Jan 24 19:31:09.481 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Fri Jan 24 19:31:09.481 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 58 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Veritate, emailAddress=info@airvpn.org issued on : 2016-12-02 16:51:45 expires on : 2026-11-30 16:51:45 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Fri Jan 24 19:31:09.718 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Fri Jan 24 19:31:09.718 2020 Session is ACTIVE Fri Jan 24 19:31:09.718 2020 EVENT: GET_CONFIG Fri Jan 24 19:31:09.718 2020 Sending PUSH_REQUEST to server... Fri Jan 24 19:31:09.844 2020 OPTIONS: 0 [route] [192.168.0.0] [255.255.0.0] [net_gateway] 1 [comp-lzo] [no] 2 [redirect-gateway] [ipv6] [def1] [bypass-dhcp] 3 [dhcp-option] [DNS] [10.22.198.1] 4 [dhcp-option] [DNS6] [fde6:7a:7d20:12c6::1] 5 [tun-ipv6] 6 [route-gateway] [10.22.198.1] 7 [topology] [subnet] 8 [ping] [10] 9 [ping-restart] [60] 10 [ifconfig-ipv6] [fde6:7a:7d20:12c6::10bc/64] [fde6:7a:7d20:12c6::1] 11 [ifconfig] [10.22.198.190] [255.255.255.0] 12 [peer-id] [2] 13 [cipher] [AES-256-GCM] Fri Jan 24 19:31:09.844 2020 PROTOCOL OPTIONS: cipher: AES-256-GCM digest: NONE ncp enabled: yes compress: LZO_STUB peer ID: 2 Fri Jan 24 19:31:09.844 2020 EVENT: ASSIGN_IP Fri Jan 24 19:31:09.844 2020 exception parsing IPv4 route: [route] [192.168.0.0] [255.255.0.0] [net_gateway] : tun_prop_route_error: tun_builder_exclude_route failed Fri Jan 24 19:31:09.844 2020 Pushed DNS Server IPv4 10.22.198.1 ignored Fri Jan 24 19:31:09.844 2020 Pushed DNS Server IPv6 fde6:7a:7d20:12c6::1 ignored Fri Jan 24 19:31:09.844 2020 net_iface_mtu_set: mtu 1500 for tun1 Fri Jan 24 19:31:09.844 2020 net_iface_up: set tun1 up Fri Jan 24 19:31:09.845 2020 net_addr_add: 10.22.198.190/24 brd 10.22.198.255 dev tun1 Fri Jan 24 19:31:09.845 2020 net_addr_add: fde6:7a:7d20:12c6::10bc/64 dev tun1 Fri Jan 24 19:31:09.845 2020 net_route_add: 0.0.0.0/1 via 10.22.198.1 dev tun1 table 0 metric 0 Fri Jan 24 19:31:09.845 2020 net_route_add: 128.0.0.0/1 via 10.22.198.1 dev tun1 table 0 metric 0 Fri Jan 24 19:31:09.845 2020 net_route_add: ::/1 via fde6:7a:7d20:12c6::1 dev tun1 table 0 metric 0 Fri Jan 24 19:31:09.845 2020 net_route_add: 8000::/1 via fde6:7a:7d20:12c6::1 dev tun1 table 0 metric 0 Fri Jan 24 19:31:09.845 2020 Connected via tun Fri Jan 24 19:31:09.845 2020 LZO-ASYM init swap=0 asym=1 Fri Jan 24 19:31:09.846 2020 Comp-stub init swap=0 Fri Jan 24 19:31:09.846 2020 EVENT: CONNECTED [2a00:c98:2050:a02f:da70:5acb:fd13:14a0]:443 (2a00:c98:2050:a02f:da70:5acb:fd13:14a0) via /UDPv6 on tun/10.22.198.190/fde6:7a:7d20:12c6::10bc gw=[10.22.198.1/fde6:7a:7d20:12c6::1] ^Creceived stop signal 2 Fri Jan 24 19:31:16.114 2020 net_route_del: 8000::/1 via fde6:7a:7d20:12c6::1 dev tun1 table 0 metric 0 Fri Jan 24 19:31:16.114 2020 net_route_del: ::/1 via fde6:7a:7d20:12c6::1 dev tun1 table 0 metric 0 Fri Jan 24 19:31:16.114 2020 net_route_del: 128.0.0.0/1 via 10.22.198.1 dev tun1 table 0 metric 0 Fri Jan 24 19:31:16.114 2020 net_route_del: 0.0.0.0/1 via 10.22.198.1 dev tun1 table 0 metric 0 Fri Jan 24 19:31:16.114 2020 net_addr_del: fde6:7a:7d20:12c6::10bc/64 dev tun1 Fri Jan 24 19:31:16.114 2020 net_addr_del: 10.22.198.190/24 dev tun1 Fri Jan 24 19:31:16.114 2020 net_iface_mtu_set: mtu 1500 for tun1 Fri Jan 24 19:31:16.114 2020 net_iface_up: set tun1 down Fri Jan 24 19:31:16.115 2020 Fri Jan 24 19:31:16.150 2020 EVENT: DISCONNECTED Fri Jan 24 19:31:16.150 2020 Thread finished STATS: BYTES_IN : 6575 BYTES_OUT : 10912 PACKETS_IN : 25 PACKETS_OUT : 62 TUN_BYTES_IN : 5350 TUN_BYTES_OUT : 1359 TUN_PACKETS_IN : 49 TUN_PACKETS_OUT : 13 Now to summarize the IPs it connected to: 2a00:c98:2050:a007:ba5e:c9f1:828f:291c – SUCCESS 2001:ac8:20:99:fbf6:b62a:86df:b560 – FAIL 2001:ac8:20:96:226a:3a84:c3d8:dba8 – FAIL 2a00:c98:2050:a02f:da70:5acb:fd13:14a0 – SUCCESS You think you see a pattern? Let's put it to the test. I queried AirDNS for all the servers and searched for one with specific characteristics in the first three nibbles: One with at least one letter, one with a number outside v4 range and then one inside it. 2a0a:b640:1:4:bc8c:6f80:9d39:d338 – FAIL 2804:5364:3100:8:8ea6:d3e3:5cb5:c248 – FAIL 2001:df0:465:1085:49e:ce88:be89:43a9 – FAIL Huh. I reconnected with OpenVPN and they ALL worked! Well, in part, because now something was wrong with the routes or so, but at least it correctly identified the address as v6! The v6detecttest.ovpn is the same as tls-crypt.ovpn from previous tests, only all remote* directives are replaced with the one I wanted to test. $ sudo ./hummingbird -N off -i v6detecttest.ovpn Hummingbird - AirVPN OpenVPN 3 Client 1.0.1 - 24 January 2020 Fri Jan 24 19:47:34.844 2020 Starting thread Fri Jan 24 19:47:34.844 2020 OpenVPN core 3.6.2 AirVPN linux x86_64 64-bit Fri Jan 24 19:47:34.853 2020 Frame=512/2048/512 mssfix-ctrl=1250 Fri Jan 24 19:47:34.859 2020 UNUSED OPTIONS 2 [resolv-retry] [infinite] 3 [nobind] 4 [persist-key] 5 [persist-tun] 6 [auth-nocache] 7 [route-delay] [5] 8 [verb] [3] 9 [explicit-exit-notify] [5] 17 [pull-filter] [ignore] [dhcp-option DNS] Fri Jan 24 19:47:34.860 2020 EVENT: RESOLVE Fri Jan 24 19:47:34.860 2020 WARNING: Network filter and lock is disabled Fri Jan 24 19:47:34.860 2020 Contacting [2001:df0:465:1085:49e:ce88:be89:43a9]:443 via UDP Fri Jan 24 19:47:34.860 2020 EVENT: WAIT Fri Jan 24 19:47:34.860 2020 net_route_best_gw query IPv6: 2001:df0:465:1085:49e:ce88:be89:43a9/128 Fri Jan 24 19:47:34.860 2020 sitnl_route_best_gw result: via UNSPEC dev Fri Jan 24 19:47:34.860 2020 Fri Jan 24 19:47:34.860 2020 Connecting to [2001:df0:465:1085:49e:ce88:be89:43a9]:443 (2001:df0:465:1085:49e:ce88:be89:43a9) via UDPv6 Fri Jan 24 19:47:44.860 2020 Server poll timeout, trying next remote entry... Fri Jan 24 19:47:44.860 2020 EVENT: RECONNECTING Fri Jan 24 19:47:44.860 2020 ERROR: N_RECONNECT Fri Jan 24 19:47:44.860 2020 EVENT: RESOLVE Fri Jan 24 19:47:44.860 2020 WARNING: Network filter and lock is disabled Fri Jan 24 19:47:44.860 2020 Contacting [2001:df0:465:1085:49e:ce88:be89:43a9]:443 via UDP Fri Jan 24 19:47:44.860 2020 EVENT: WAIT Fri Jan 24 19:47:44.860 2020 net_route_best_gw query IPv6: 2001:df0:465:1085:49e:ce88:be89:43a9/128 Fri Jan 24 19:47:44.860 2020 sitnl_route_best_gw result: via UNSPEC dev Fri Jan 24 19:47:44.860 2020 Fri Jan 24 19:47:44.860 2020 Connecting to [2001:df0:465:1085:49e:ce88:be89:43a9]:443 (2001:df0:465:1085:49e:ce88:be89:43a9) via UDPv6 ^Creceived stop signal 2 Fri Jan 24 19:47:47.374 2020 EVENT: DISCONNECTED Fri Jan 24 19:47:47.374 2020 Thread finished STATS: BYTES_OUT : 702 PACKETS_OUT : 13 N_RECONNECT : 1 I'm not entirely sure what to make of it all. If it really is something with my configuration, I must test other machines… Apart from that, it couldn't create custom routes via route directive, it seems, but that might be because it doesn't know the special keywork net_gateway yet: Fri Jan 24 19:10:22.633 2020 exception parsing IPv4 route: [route] [192.168.0.0] [255.255.0.0] [net_gateway] : tun_prop_route_error: tun_builder_exclude_route failed I overlooked the ::/1 via fde6… route.Then there's this line: Fri Jan 24 19:10:22.634 2020 net_route_add: 8000::/1 via fde6:7a:7d20:7fa::1 dev tun1 table 0 metric 0 According to subnetcalc that's… 8000:: to FFFF:FFFF:…? $ subnetcalc 8000::/1 Address = 8000:: 8000 = 10000000 00000000 0000 = 00000000 00000000 0000 = 00000000 00000000 0000 = 00000000 00000000 0000 = 00000000 00000000 0000 = 00000000 00000000 0000 = 00000000 00000000 0000 = 00000000 00000000 Network = 8000:: / 1 Netmask = 8000:: Wildcard Mask = 7fff:ffff:ffff:ffff:ffff:ffff:ffff:ffff Hosts Bits = 127 Max. Hosts = 2^127 - 1 Host Range = { 8000::1 - ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff } Properties = - 8000:: is a NETWORK address GeoIP Country = Unknown (??) It also seems to not set the v6 routes for all currently assigned UGAs like OpenVPN does. v4 is done right: $ ip r 0.0.0.0/1 via 10.25.166.1 dev tun1 0.0.0.0/1 via 10.13.178.1 dev tun0 default via 192.168.110.1 dev enp35s0 proto dhcp metric 100 10.13.178.0/24 dev tun0 proto kernel scope link src 10.13.178.172 10.25.166.0/24 dev tun1 proto kernel scope link src 10.25.166.41 128.0.0.0/1 via 10.25.166.1 dev tun1 128.0.0.0/1 via 10.13.178.1 dev tun0 192.168.0.0/16 via 192.168.110.1 dev enp35s0 192.168.110.0/24 dev enp35s0 proto kernel scope link src 192.168.110.11 metric 100 v6 is.. "neglected"? $ ip -6 r ::1 dev lo proto kernel metric 256 pref medium ::/3 dev tun0 metric 1024 pref medium 2001:ac8:20:2c:8efe:ed7:7e97:6f97 via fe80::xxxx:xxff:fexx:xxxx dev enp35s0 metric 1 pref medium 2003:xxxx:xxxx:xxxx::/64 dev enp35s0 proto ra metric 100 pref medium 2003:xxxx:xxxx:xxxx::/56 via fe80::xxxx:xxff:fexx:xxxx dev enp35s0 proto ra metric 100 pref medium 2000::/4 dev tun0 metric 1024 pref medium 3000::/4 dev tun0 metric 1024 pref medium ::/1 via fde6:7a:7d20:15a6::1 dev tun1 metric 1024 pref medium fde6:7a:7d20:9b2::/64 dev tun0 proto kernel metric 256 pref medium fde6:7a:7d20:15a6::/64 dev tun1 proto kernel metric 256 pref medium fc00::/7 dev tun0 metric 1024 pref medium fe80::/64 dev enp35s0 proto kernel metric 100 pref medium fe80::/64 dev tun0 proto kernel metric 256 pref medium fe80::/64 dev tun1 proto kernel metric 256 pref medium 8000::/1 via fde6:7a:7d20:15a6::1 dev tun1 metric 1024 pref medium default via fe80::xxxx:xxff:fexx:xxxx dev enp35s0 proto ra metric 100 pref medium Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
monstrocity 39 Posted ... On Linux Mint 19.3 I'm still getting TCP_OVERFLOW errors on both stand alone Hummingbird and in Eddie 2.18.6 beta. Like with Hummingbird 1.0.0, this error appears while torrenting; the client cannot keep pace with the number of requests and throws the error - not sure if there's a fix for it. I'm unable to use the UDP protocol, as all UDP ports are closed by default where I have internet access. eddie.log Quote Share this post Link to post
pjnsmb 13 Posted ... @Staff For the record after updating to hummingbird 1.01 : Still the same : ERROR: Cannot activate network filter and lock The first time the error appears it has dropped down a few lines in the log due to a reference to network manager and systemd-resolved . regards 1.0.1 1.0.0 Quote Hide pjnsmb's signature Hide all signatures regardspjnsmb Share this post Link to post
Staff 10723 Posted ... @pjnsmb Hello! Hummingbird tries to use in sequence the first available firewall between iptables, iptables-legacy, nftables and pf. In your case, Hummingbird finds iptables-legacy. With IPv4 no errors seems to arise, but the problem comes out with IPv6. ip[6]tables-legacy is a wrapper to nftables, so IPv6 support in nftables might be the problem, or maybe it's a bug in ip6tables legacy in your unstable distribution (or you just disabled IPv6 support in your system, but you told us that you keep getting the error even when you re-enable it, can you confirm?). Can you please re-test Humminbird without the --ipv6 no option you enforced, just in case, and check whether the problem is the same or not? Another possible test, but it's more problematic if you need iptables syntax somewhere in your system or applications, would be removing iptables and iptables-legacy packages. In this case Hummingbird will use nftables. We can not support unstable distributions (you're running Debian Sid according to your ticket) because we can't circumvent all the possible bugs which an unstable distribution may potentially come with: it would be a wrong approach and anyway it would be an overwhelming task. However, we will offer in a near future release the option to force Hummingbird to use a firewall chosen by the user. When the option is available you will be able to force usage of nftables, bypassing iptables-legacy, if it's causing the issue. Please keep us informed if you decide to perform any of the above tests. Kind regards Quote Share this post Link to post
Staff 10723 Posted ... @monstrocity Hello! Bug detected and under investigation. It involves all versions of OpenVPN 3 library (not only our fork unfortunately) so it must be something we have been dragging with us since the very beginning, OR (worst case scenario) something related to asio library (hopefully not). If you have the option to use UDP, please do it, otherwise stay tuned, we have given very high priority to the bug. Kind regards Quote Share this post Link to post
pjnsmb 13 Posted ... @Staff After doing a fair amount of investigation and research into iptables and nftables I found that my iptables in use only covered a default basic firewall setting without any additions that would hopefully not cause a problem to any programmes or system settings if removed. I read up on converting iptables to nftables, did so, deleted iptables, and started using nftables. I can now use hummingbird with network lock working correctly. As a result of these changes there are no entries in the log anymore showing any problems with IPv6 . I am grateful of your explanations and help p.s I would not have made these changes and alterations without a decent backup programme in place to use if all went 'pear-shaped' I recommend for linux :https://github.com/teejee2008/timeshift 1 1 Staff and Tech Jedi Alex reacted to this Quote Hide pjnsmb's signature Hide all signatures regardspjnsmb Share this post Link to post
Staff 10723 Posted ... @monstrocity Please increase the maximum amount of packets allowed in the TCP queue with directive tcp-queue-limit n (n is the amount of packets) according to the amount of concurrent, global TCP connections your system needs when you run a BitTorrent software. OpenVPN 3 default limit is 64 packets. For example, add to your profile the following line: tcp-queue-limit 256 Please test again and check whether the problem is resolved. Of course consider to increase the amount of packets beyond 256 if you see the problem persisting. Your feedback is very much appreciated. Kind regards 1 monstrocity reacted to this Quote Share this post Link to post
monstrocity 39 Posted ... Added tcp-queue-limit 2048 in OPVN custom directives through Eddie using Hummingbird 1.01 and so far not seeing any TCP_OVERFLOW errors. Will report if the error returns. Thanks. Noting other Hummingbird errors through Eddie: ERROR: KEY_STATE_ERROR TCP recv error: Connection reset by peer ERROR: NETWORK_RECV_ERROR EVENT: TRANSPORT_ERROR Transport error on '37.120.210.221: NETWORK_RECV_ERROR [ERR] ERROR: TRANSPORT_ERROR Client terminated, restarting in 5000 ms... ERROR: N_RECONNECT log.txt 1 Staff reacted to this Quote Share this post Link to post
Staff 10723 Posted ... @monstrocity Hello, we're very glad to see that the problem is resolved. 2048 packets make the output queue huge, but actually it is proportional to the amount of concurrent connections limit you have set in your torrent software. qBittorrent comes with a limit of 500 by default. The other error you report pertains to a disconnection, unrelated to TCP_OVERFLOW. If you get such disconnections more often when you torrent, please warn us. For the readers: overflow in the TCP output queue is a problem that does not exist in UDP. Kind regards 1 monstrocity reacted to this Quote Share this post Link to post
monstrocity 39 Posted ... @Staff Thanks for the advice. Setting tcp-queue-limit to 500. Will report again about the disconnects if I still get them. Regarding UDP, I can get a connection for about 5 minutes before it gets shutdown; I'm behind a school firewall, so there's nothing I can do with UDP. TCP is my only viable option unfortunately. TCP_OVERFLOW error with limit set at 500, trying 1024 instead. On 1-2 active torrents, tcp-queue-limit 1024 still leads to the TCP_OVERFLOW error with the same errors noted earlier; at that point Eddie reconnects but doesn't crash - now on Eddie 2.18.7 beta. Setting tcp-queue-limit to 5000 or higher appears to work. Quote Share this post Link to post
nexsteppe 24 Posted ... I recently updated my local hummingbird and openvpn3-airvpn repos to the latest commits and rebuilt a dynamic binary under the latest Slackware x86_64 current. No problems with this. However, I'm still encountering the key errors I reported with hummingbird 1.0 with this updated version, now typically within a few hours of connecting. The difference from before is the tunnel not only remains up now, but will typically renegotiate the key successfully at the hour mark. But the key error usually happens again before too long. Should it be helpful for troubleshooting, here is the (slightly redacted) ovpn I use to connect to AirVPN Canada servers with hummingbird: client dev tun mssfix 1470 remote ca3.vpn.airdns.org 443 udp setenv UV_IPV6 yes push-peer-info cert keys/airvpn.crt key keys/airvpn.key cipher AES-256-CBC auth SHA512 comp-lzo no remote-cert-tls server <ca> ... redacted ... </ca> <tls-crypt> ... redacted ... </tls-crypt> Quote Share this post Link to post
