manuhbt67 0 Posted ... Hello, I cannot connect to any server with Eddie (I am on Windows 10). I used it 3 months ago and it worked well, but today it does not work anymore. It always fails with: . 2020.01.09 21:17:31 - OpenVPN > MANAGEMENT: Socket bind failed on local address [AF_INET]127.0.0.1:3162 . 2020.01.09 21:17:31 - OpenVPN > Exiting due to fatal error ! 2020.01.09 21:17:31 - Disconnecting Any idea ? Thanks Here are the full logs: I 2020.01.09 21:17:27 - Session starting. I 2020.01.09 21:17:29 - Checking authorization ... . 2020.01.09 21:17:29 - Tor Control authentication method: Cookie, from C:\Users\manup\Desktop\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie . 2020.01.09 21:17:29 - Sending request for a new circuit to Tor . 2020.01.09 21:17:29 - Tor Control authentication method: Cookie, from C:\Users\manup\Desktop\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie . 2020.01.09 21:17:29 - Tor Control Guard IP detected: 136.243.247.90 (circuit) ! 2020.01.09 21:17:29 - Connecting to Subra (Netherlands, Alblasserdam) . 2020.01.09 21:17:30 - Routes, added a new route, 136.243.247.90 for gateway 192.168.1.1 . 2020.01.09 21:17:31 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2020.01.09 21:17:31 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.01.09 21:17:31 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.01.09 21:17:31 - Auto retry with another port. . 2020.01.09 21:17:31 - OpenVPN > MANAGEMENT: Socket bind failed on local address [AF_INET]127.0.0.1:3162 . 2020.01.09 21:17:31 - OpenVPN > Exiting due to fatal error ! 2020.01.09 21:17:31 - Disconnecting . 2020.01.09 21:17:32 - Routes, removed a route previously added, 136.243.247.90 for gateway 192.168.1.1 . 2020.01.09 21:17:32 - Connection terminated. I 2020.01.09 21:17:32 - Checking authorization ... . 2020.01.09 21:17:33 - Tor Control authentication method: Cookie, from C:\Users\manup\Desktop\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie . 2020.01.09 21:17:33 - Sending request for a new circuit to Tor . 2020.01.09 21:17:33 - Tor Control authentication method: Cookie, from C:\Users\manup\Desktop\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie . 2020.01.09 21:17:33 - Tor Control Guard IP detected: 136.243.247.90 (circuit) ! 2020.01.09 21:17:33 - Connecting to Subra (Netherlands, Alblasserdam) . 2020.01.09 21:17:33 - Routes, added a new route, 136.243.247.90 for gateway 192.168.1.1 . 2020.01.09 21:17:34 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2020.01.09 21:17:34 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.01.09 21:17:34 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.01.09 21:17:34 - Auto retry with another port. . 2020.01.09 21:17:34 - OpenVPN > MANAGEMENT: Socket bind failed on local address [AF_INET]127.0.0.1:3163 . 2020.01.09 21:17:34 - OpenVPN > Exiting due to fatal error ! 2020.01.09 21:17:34 - Disconnecting . 2020.01.09 21:17:35 - Routes, removed a route previously added, 136.243.247.90 for gateway 192.168.1.1 . 2020.01.09 21:17:35 - Connection terminated. I 2020.01.09 21:17:35 - Checking authorization ... . 2020.01.09 21:17:37 - Tor Control authentication method: Cookie, from C:\Users\manup\Desktop\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie . 2020.01.09 21:17:37 - Sending request for a new circuit to Tor . 2020.01.09 21:17:37 - Tor Control authentication method: Cookie, from C:\Users\manup\Desktop\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie . 2020.01.09 21:17:37 - Tor Control Guard IP detected: 136.243.247.90 (circuit) ! 2020.01.09 21:17:37 - Connecting to Subra (Netherlands, Alblasserdam) . 2020.01.09 21:17:38 - Routes, added a new route, 136.243.247.90 for gateway 192.168.1.1 . 2020.01.09 21:17:38 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2020.01.09 21:17:38 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.01.09 21:17:38 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.01.09 21:17:38 - Auto retry with another port. . 2020.01.09 21:17:38 - OpenVPN > MANAGEMENT: Socket bind failed on local address [AF_INET]127.0.0.1:3164 . 2020.01.09 21:17:38 - OpenVPN > Exiting due to fatal error ! 2020.01.09 21:17:38 - Disconnecting . 2020.01.09 21:17:39 - Routes, removed a route previously added, 136.243.247.90 for gateway 192.168.1.1 . 2020.01.09 21:17:39 - Connection terminated. I 2020.01.09 21:17:39 - Checking authorization ... . 2020.01.09 21:17:41 - Tor Control authentication method: Cookie, from C:\Users\manup\Desktop\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie . 2020.01.09 21:17:41 - Sending request for a new circuit to Tor . 2020.01.09 21:17:41 - Tor Control authentication method: Cookie, from C:\Users\manup\Desktop\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie . 2020.01.09 21:17:41 - Tor Control Guard IP detected: 136.243.247.90 (circuit) ! 2020.01.09 21:17:41 - Connecting to Subra (Netherlands, Alblasserdam) . 2020.01.09 21:17:42 - Routes, added a new route, 136.243.247.90 for gateway 192.168.1.1 . 2020.01.09 21:17:42 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2020.01.09 21:17:42 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.01.09 21:17:42 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.01.09 21:17:42 - Auto retry with another port. . 2020.01.09 21:17:42 - OpenVPN > MANAGEMENT: Socket bind failed on local address [AF_INET]127.0.0.1:3165 . 2020.01.09 21:17:42 - OpenVPN > Exiting due to fatal error ! 2020.01.09 21:17:42 - Disconnecting . 2020.01.09 21:17:43 - Routes, removed a route previously added, 136.243.247.90 for gateway 192.168.1.1 . 2020.01.09 21:17:43 - Connection terminated. I 2020.01.09 21:17:43 - Cancel requested. ! 2020.01.09 21:17:43 - Session terminated. Share this post Link to post
Tech Jedi Alex 1528 Posted ... Is it possible for you to connect normally, as in, not using Tor? Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
manuhbt67 0 Posted ... I was not either, but everything is fine now. It seems my virtual network interfaces messed around. I disabled all the VM interfaces and then it worked. Problem solved. Thanks! Share this post Link to post
