Air4141841 30 Posted ... Good Day, with newer versions of pfsense the option is there to set the option to: direction 1 direction 0 both use default direction. going forward what does Staff suggest we set this option too? Quote Share this post Link to post
Staff 10494 Posted ... @Air4141841 Hello!key-direction 1 when you use TLS Auth key (i.e. you connect to entry-IP addresses 1 and 2). Omit it when you use TLS Crypt (i.e. you connect to entry-IP addresses 3 and 4), because it's not pertaining to TLS Crypt. For an explanation, look for secret file [direction] and –key-direction in the manual https://openvpn.net/community-resources/reference-manual-for-openvpn-2-4/ If you run OpenVPN 2.4 or higher version, TLS Crypt is recommended because it encrypts the whole Control Channel, with the important side effect to make OpenVPN "fingerprint" not detectable by Deep Packet Inspection (some ISPs, when they detect OpenVPN "fingerprint", enforce traffic shaping). Kind regards 1 2 nexsteppe, Air4141841 and stupid are cocksure reacted to this Quote Share this post Link to post
Air4141841 30 Posted ... that explained this perfect thank you so much Quote Share this post Link to post
