jasonthemann
Port forwarding stops working
I am having an issue where my port forwards work for a few minutes after connecting to a server, but then SOME of them stop working. I have 3 ports forwarded, one for utorrent (this port always works consistently), SABnzbd, and VNC. I am running Windows 10 Enterprise x86 in a VM (VM is using Bridged Networking so the VM is getting an IP directly from the router), I am using Eddie 2.16.3. When I connect to a new server, the port forwards for SABNZbd and VNC will work for a short period of time, then stop working. The port I have forwarded for utorrent works consistently. I have tried turning off the Windows firewall to verify this isn't the issue and it doesn't seem to affect the results. I am admittedly not a power user, so if anyone has an idea what I am doing wrong or need to change to get it to work consistently, I would appreciate the help.
