ajaffarali
Help me chose the best router/wireless
I would like to get a router/wifi system that can work with the following requirements
1) Support AirVPN
2) Be able to create multiple wireless networks that can either go through VPN or direct or for my IoT devices
3) Support mesh so I can have multiple access points across the home
4) Allow controls to restrict particular devices at particular times from any of the networks
Would appreciate any help.
  1. All routers supporting OpenVPN will meet this, for example routers with OpenWRT.
  2. I think any router with OpenWRT can do that. In extreme cases a small pfSense computer will definitely do, but it requires a bit of knowledge.
  3. OpenWRT can do that, I've heard.
  4. Erm... not sure.
