display6745
double hop connections?
Does the eddie client on ubuntu support double hop vpn connections?
Also if the above is no it it possible to have two seperate connections such as air vpn and mullvad vpn work at the same time?
Refer to the following post.Two really separate connections based on Linux cgroups can be done with corrado's inofficial qomui client.
