605467297@qq.com 0 Posted ... Hi, i'm trying to set the proxy with http or socks, but both fail to login when using the proxy, the error message is "Cannot login, (Curl: (7)) Failed to connect to 127.0.0.1 port 8080: Connection refused - with 'http' (always) proxy and 'none' auth" Plus: 1. i also try different ports, but it fails too. 2. the platform is window 10. 3. i can use the vpn service successfully without proxy Quote Share this post Link to post
Staff 10386 Posted ... Hello! It looks like your proxy is refusing connections: Quote Failed to connect to 127.0.0.1 port 8080: Connection refused Please make sure that your proxy really runs (obviously) and listens to port 8080 and that no firewall blocks local connections to it (no blocks to/from localhost 127.0.0.1 and/or port 8080). Quote i'm trying to set the proxy with http or socks SOCKS or HTTP? They are not equivalent. Please make sure that Eddie is configured to connect to the correct proxy type. Kind regards Quote Share this post Link to post
Tech Jedi Alex 1515 Posted ... 14 hours ago, 605467297@qq.com said: 3. i can use the vpn service successfully without proxy This suggests that.. you are needlessly configuring a proxy. Why use it if you can connect anyway? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
