Not connected, Your IP: 216.73.216.19
hoffli
Eddie is not working on Mac OS Mojave
I'm not running any firewalls. The connection initiates successfully, and if I watch the connection data, there will be both download and upload data as if the computer were normally connected to the internet. I can even use ping from the command line. But I cannot load any website nor use anything in the terminal that requires SSL. That is regardless of which protocol and port I select in Eddie.
It's not anything with the ISP, everything works well from my Android.
What am I doing wrong?
ping goo.gl
PING goo.gl (216.58.211.110): 56 data bytes
64 bytes from 216.58.211.110: icmp_seq=0 ttl=54 time=306.956 ms
64 bytes from 216.58.211.110: icmp_seq=1 ttl=54 time=329.628 ms
64 bytes from 216.58.211.110: icmp_seq=2 ttl=54 time=351.262 ms
64 bytes from 216.58.211.110: icmp_seq=3 ttl=54 time=373.488 ms
^C
--- goo.gl ping statistics ---
4 packets transmitted, 4 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 306.956/340.334/373.488/24.735 ms
➜  ~ speedtest-cli
Retrieving speedtest.net configuration...
Cannot retrieve speedtest configuration
ERROR: <urlopen error ('_ssl.c:574: The handshake operation timed out',)>
Omitting critical information, to say the least. Clients? Versions? Which server tried? Give us the logs first.
