yeehi 2 Posted ... Most of the time, the client launches but struggles to connect to a server. The speed tests go OK but then it just goes into a loop trying to reconnect. If you restart the client, that sometimes helps, or if you reboot the system. What is the problem? How can it be fixed? There is some bug listed in the logs. Two log files are attached. The first is when it failed, the second is when it worked. 2.18.5beta.txt 2.18.5betaWorked.txt Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... It seems that something interferes with the TAP adapter when something is exchanged. Maybe an internet security suite? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
