Not connected, Your IP: 216.73.216.47
dnrg
Eddie left broken network connection after restart
I restarted my Ubuntu server because of some updates.
Now Eddie refuses to start with "Authorization check failed", also I cannot connect to anything anymore, even without Eddie no network connection despite local network is possible anymore.
My ifconfig shows a tun0 interface that probably should not exist without an Eddie connection:
ifconfig
enp0s25: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.0.40  netmask 255.255.0.0  broadcast 192.168.255.255
        inet6 fe80::ffac:d06b:a823:da02  prefixlen 64  scopeid 0x20<link>
        ether 00:01:2e:2f:ff:35  txqueuelen 1000  (Ethernet)
        RX packets 33559  bytes 5480357 (5.4 MB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 148236  bytes 196641395 (196.6 MB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 20  memory 0xfbdc0000-fbde0000
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 41636  bytes 189082766 (189.0 MB)
        TX packets 41636  bytes 189082766 (189.0 MB)
tun0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1500
        inet 10.40.20.12  netmask 255.255.255.0  destination 10.40.20.12
        inet6 fe80::828:40d1:c7ad:ae9b  prefixlen 64  scopeid 0x20<link>
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 100  (UNSPEC)
        RX packets 566  bytes 593801 (593.8 KB)
        TX packets 481  bytes 45690 (45.6 KB)
        TX errors 0  dropped 8267 overruns 0  carrier 0  collisions 0
netstat -rn
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
0.0.0.0         10.40.20.1      128.0.0.0       UG        0 0          0 tun0
0.0.0.0         10.40.20.1      0.0.0.0         UG        0 0          0 tun0
0.0.0.0         192.168.0.1     0.0.0.0         UG        0 0          0 enp0s25
10.40.20.0      0.0.0.0         255.255.255.0   U         0 0          0 tun0
128.0.0.0       10.40.20.1      128.0.0.0       UG        0 0          0 tun0
169.254.0.0     0.0.0.0         255.255.0.0     U         0 0          0 enp0s25
192.168.0.0     0.0.0.0         255.255.0.0     U         0 0          0 enp0s25
How can I reset everything to a default, plain net connection, or does Eddie have some kind of backup feature and can reset all network settings?
sudo pkill -15 openvpn && sudo systemctl restart networking
