Not connected, Your IP: 216.73.216.33
filarakia
SSH for Android client
I would like to ask why there is the discrepancy between the Windows and Android clients, in that the Windows client supports SSH while the Android one doesn’t?
Any chance we will get SSH support on Android?
Same question here. Wondering if its a technical limitation or just a matter of time before SSH ( or SSL for that matter ) are natively supported in Eddie for android.
im specifically keen on SSH at the moment because it works best with my ISP.
