mdoverl 2 Posted ... AirVPN is suddenly starting to fail at checking IPv6. I don't have much experience troubleshooting VPN, so this will be a learning experience for me. I've pasted my log below. In the log is two connection attempts. The first attempt started at 23:10:58 and the second attempt is at 23:13:24. . 2019.10.03 23:10:58 - Eddie version: 2.16.3 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.18362.0, Mono/.Net: v4.0.30319 . 2019.10.03 23:10:58 - Reading options from C:\Users\mdove\AppData\Local\AirVPN\default.xml . 2019.10.03 23:10:59 - Command line arguments (1): path="home" . 2019.10.03 23:10:59 - Profile path: C:\Users\mdove\AppData\Local\AirVPN\default.xml . 2019.10.03 23:11:06 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2 . 2019.10.03 23:11:06 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2019.10.03 23:11:06 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe) . 2019.10.03 23:11:06 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) . 2019.10.03 23:11:06 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe) . 2019.10.03 23:11:06 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem W 2019.10.03 23:11:06 - Recovery. Unexpected crash? . 2019.10.03 23:11:08 - Routes, remove 184.75.223.219 for gateway 10.24.14.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:08 - Routes, remove 184.75.221.3 for gateway 10.20.238.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:09 - Routes, remove 199.19.94.62 for gateway 10.20.142.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:10 - Routes, remove 104.254.90.243 for gateway 10.16.70.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:10 - Routes, remove 199.21.149.49 for gateway 10.15.142.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:11 - Routes, remove 213.152.161.133 for gateway 10.31.46.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:11 - Routes, remove 104.254.90.251 for gateway 10.18.6.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:12 - Routes, remove 184.75.221.3 for gateway 10.20.238.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:12 - Routes, remove 104.254.90.203 for gateway 10.8.78.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:13 - Routes, remove 199.19.94.193 for gateway 10.30.174.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:13 - Routes, remove 199.19.94.16 for gateway 10.6.238.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:14 - Routes, remove 199.21.149.49 for gateway 10.15.142.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:14 - Routes, remove 184.75.221.171 for gateway 10.8.174.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:15 - Routes, remove 137.63.71.51 for gateway 10.31.78.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:15 - Routes, remove 184.75.223.195 for gateway 10.29.46.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:16 - Routes, remove 184.75.221.211 for gateway 10.9.238.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:16 - Routes, remove 104.254.90.243 for gateway 10.16.78.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:17 - Routes, remove 184.75.221.203 for gateway 10.6.206.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:17 - Routes, remove 184.75.223.211 for gateway 10.4.206.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:18 - Routes, remove 184.75.221.211 for gateway 10.9.238.1 failed: The route deletion failed: Element not found . 2019.10.03 23:11:18 - Above log line repeated 1 times more . 2019.10.03 23:11:18 - Updating systems & servers data ... I 2019.10.03 23:11:19 - Ready . 2019.10.03 23:11:20 - Systems & servers data update completed ! 2019.10.03 23:11:21 - Activation of Network Lock - Windows Filtering Platform I 2019.10.03 23:11:22 - Session starting. I 2019.10.03 23:11:30 - Checking authorization ... ! 2019.10.03 23:11:31 - Connecting to Enif (Canada, Toronto, Ontario) . 2019.10.03 23:11:31 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2019.10.03 23:11:31 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2019.10.03 23:11:31 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2019.10.03 23:11:31 - Connection to OpenVPN Management Interface . 2019.10.03 23:11:31 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2019.10.03 23:11:31 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.10.03 23:11:31 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.10.03 23:11:31 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.10.03 23:11:31 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.10.03 23:11:31 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.245:443 . 2019.10.03 23:11:31 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2019.10.03 23:11:31 - OpenVPN > UDP link local: (not bound) . 2019.10.03 23:11:31 - OpenVPN > UDP link remote: [AF_INET]104.254.90.245:443 . 2019.10.03 23:11:31 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2019.10.03 23:11:31 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.245:443, sid=5a7f868a 9bbde96b . 2019.10.03 23:11:31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2019.10.03 23:11:31 - OpenVPN > VERIFY KU OK . 2019.10.03 23:11:31 - OpenVPN > Validating certificate extended key usage . 2019.10.03 23:11:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2019.10.03 23:11:31 - OpenVPN > VERIFY EKU OK . 2019.10.03 23:11:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2019.10.03 23:11:31 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2019.10.03 23:11:31 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.254.90.245:443 . 2019.10.03 23:11:32 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2019.10.03 23:11:32 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.16.78.1,dhcp-option DNS6 fde6:7a:7d20:c4e::1,tun-ipv6,route-gateway 10.16.78.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:c4e::1014/64 fde6:7a:7d20:c4e::1,ifconfig 10.16.78.22 255.255.255.0,peer-id 3,cipher AES-256-GCM' . 2019.10.03 23:11:32 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2019.10.03 23:11:32 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2019.10.03 23:11:32 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2019.10.03 23:11:32 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2019.10.03 23:11:32 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2019.10.03 23:11:32 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2019.10.03 23:11:32 - OpenVPN > OPTIONS IMPORT: peer-id set . 2019.10.03 23:11:32 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2019.10.03 23:11:32 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2019.10.03 23:11:32 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2019.10.03 23:11:32 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.10.03 23:11:32 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.10.03 23:11:32 - OpenVPN > interactive service msg_channel=0 . 2019.10.03 23:11:32 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=16 HWADDR=70:8b:cd:42:38:4d . 2019.10.03 23:11:32 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2019.10.03 23:11:32 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2019.10.03 23:11:32 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2019.10.03 23:11:32 - OpenVPN > open_tun . 2019.10.03 23:11:33 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{43E0B7FA-6671-4D69-A47C-83E1B6785CAA}.tap . 2019.10.03 23:11:33 - OpenVPN > TAP-Windows Driver Version 9.21 . 2019.10.03 23:11:33 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.16.78.0/10.16.78.22/255.255.255.0 [SUCCEEDED] . 2019.10.03 23:11:33 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.16.78.22/255.255.255.0 on interface {43E0B7FA-6671-4D69-A47C-83E1B6785CAA} [DHCP-serv: 10.16.78.254, lease-time: 31536000] . 2019.10.03 23:11:33 - OpenVPN > Successful ARP Flush on interface [10] {43E0B7FA-6671-4D69-A47C-83E1B6785CAA} . 2019.10.03 23:11:33 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2019.10.03 23:11:33 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=10 fde6:7a:7d20:c4e::1014 store=active . 2019.10.03 23:11:35 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Ethernet 3 static fde6:7a:7d20:c4e::1 validate=no . 2019.10.03 23:11:36 - Detected an OpenVPN bug (On-Link route on VPN range), autofix. . 2019.10.03 23:11:36 - OpenVPN > add_route_ipv6(fde6:7a:7d20:c4e::/64 -> fde6:7a:7d20:c4e::1014 metric 0) dev Ethernet 3 . 2019.10.03 23:11:36 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:c4e::/64 interface=10 fe80::8 store=active . 2019.10.03 23:11:36 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.10.03 23:11:41 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2019.10.03 23:11:41 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 104.254.90.245 MASK 255.255.255.255 192.168.1.1 . 2019.10.03 23:11:41 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2019.10.03 23:11:41 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.10.03 23:11:41 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.16.78.1 . 2019.10.03 23:11:41 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.10.03 23:11:41 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.10.03 23:11:41 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.16.78.1 . 2019.10.03 23:11:41 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.10.03 23:11:41 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.10.03 23:11:41 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:c4e::1 metric -1) dev Ethernet 3 . 2019.10.03 23:11:41 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=10 fe80::8 store=active . 2019.10.03 23:11:41 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.10.03 23:11:41 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:c4e::1 metric -1) dev Ethernet 3 . 2019.10.03 23:11:41 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=10 fe80::8 store=active . 2019.10.03 23:11:41 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.10.03 23:11:41 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:c4e::1 metric -1) dev Ethernet 3 . 2019.10.03 23:11:41 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=10 fe80::8 store=active . 2019.10.03 23:11:41 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.10.03 23:11:41 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:c4e::1 metric -1) dev Ethernet 3 . 2019.10.03 23:11:41 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=10 fe80::8 store=active . 2019.10.03 23:11:41 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.10.03 23:11:42 - Interface Ethernet 3 metric changed from Automatic to 3, layer IPv4 . 2019.10.03 23:11:42 - Interface Ethernet 3 metric changed from Automatic to 3, layer IPv6 . 2019.10.03 23:11:42 - DNS leak protection with packet filtering enabled. . 2019.10.03 23:11:44 - DNS IPv4 of a network adapter forced (Ethernet 3, from automatic to 10.16.78.1) . 2019.10.03 23:11:44 - DNS IPv6 of a network adapter forced (Ethernet 3, from automatic to fde6:7a:7d20:c4e::1) . 2019.10.03 23:11:44 - Routes, added a new route, 104.254.90.243 for gateway 10.16.78.1 . 2019.10.03 23:11:45 - Routes, added a new route, 2606:6080:2001:9:2679:addd:655:8142 for gateway fde6:7a:7d20:c4e::1 . 2019.10.03 23:11:45 - Flushing DNS I 2019.10.03 23:11:49 - Checking route IPv4 I 2019.10.03 23:11:49 - Checking route IPv6 . 2019.10.03 23:12:09 - curl: (28) Connection timed out after 20000 milliseconds . 2019.10.03 23:12:09 - Checking route (2° try) . 2019.10.03 23:12:30 - curl: (28) Connection timed out after 20000 milliseconds . 2019.10.03 23:12:30 - Checking route (3° try) . 2019.10.03 23:12:52 - curl: (28) Connection timed out after 20000 milliseconds E 2019.10.03 23:12:52 - Checking route IPv6 failed. . 2019.10.03 23:12:52 - OpenVPN > Initialization Sequence Completed ! 2019.10.03 23:12:52 - Disconnecting . 2019.10.03 23:12:52 - Routes, removed a route previously added, 104.254.90.243 for gateway 10.16.78.1 . 2019.10.03 23:12:53 - Routes, removed a route previously added, 2606:6080:2001:9:2679:addd:655:8142 for gateway fde6:7a:7d20:c4e::1 . 2019.10.03 23:12:53 - Sending management termination signal . 2019.10.03 23:12:53 - Management - Send 'signal SIGTERM' . 2019.10.03 23:12:53 - OpenVPN > MANAGEMENT: CMD '072b51df2737fbba904e5901abb228cd058da2fe77233810968e0c193ff47585' . 2019.10.03 23:13:02 - Sending management termination signal . 2019.10.03 23:13:02 - Management - Send 'signal SIGTERM' . 2019.10.03 23:13:02 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2019.10.03 23:13:02 - OpenVPN > SIGTERM received, sending exit notification to peer . 2019.10.03 23:13:07 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 104.254.90.245 MASK 255.255.255.255 192.168.1.1 . 2019.10.03 23:13:07 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.10.03 23:13:07 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.16.78.1 . 2019.10.03 23:13:07 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.10.03 23:13:07 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.16.78.1 . 2019.10.03 23:13:07 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.10.03 23:13:07 - OpenVPN > delete_route_ipv6(::/3) . 2019.10.03 23:13:07 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 interface=10 fe80::8 store=active . 2019.10.03 23:13:07 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.10.03 23:13:07 - OpenVPN > delete_route_ipv6(2000::/4) . 2019.10.03 23:13:07 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=10 fe80::8 store=active . 2019.10.03 23:13:07 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.10.03 23:13:07 - OpenVPN > delete_route_ipv6(3000::/4) . 2019.10.03 23:13:07 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=10 fe80::8 store=active . 2019.10.03 23:13:07 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.10.03 23:13:07 - OpenVPN > delete_route_ipv6(fc00::/7) . 2019.10.03 23:13:07 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=10 fe80::8 store=active . 2019.10.03 23:13:07 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.10.03 23:13:07 - OpenVPN > Closing TUN/TAP interface . 2019.10.03 23:13:07 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:c4e::/64) . 2019.10.03 23:13:07 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:c4e::/64 interface=10 fe80::8 store=active . 2019.10.03 23:13:07 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address Ethernet 3 fde6:7a:7d20:c4e::1014 store=active . 2019.10.03 23:13:07 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns Ethernet 3 all . 2019.10.03 23:13:07 - OpenVPN > TAP: DHCP address released . 2019.10.03 23:13:07 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2019.10.03 23:13:07 - Connection terminated. . 2019.10.03 23:13:08 - DNS IPv4 of a network adapter restored to original settings (Ethernet 3, to automatic) . 2019.10.03 23:13:08 - DNS IPv6 of a network adapter restored to original settings (Ethernet 3, to automatic) . 2019.10.03 23:13:08 - DNS leak protection with packet filtering disabled. . 2019.10.03 23:13:08 - Interface Ethernet 3 metric restored from 3 to Automatic, layer IPv4 . 2019.10.03 23:13:08 - Interface Ethernet 3 metric restored from 3 to Automatic, layer IPv6 I 2019.10.03 23:13:11 - Cancel requested. ! 2019.10.03 23:13:11 - Session terminated. I 2019.10.03 23:13:24 - Session starting. I 2019.10.03 23:13:24 - Checking authorization ... ! 2019.10.03 23:13:25 - Connecting to Agena (Canada, Toronto, Ontario) . 2019.10.03 23:13:25 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2019.10.03 23:13:25 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2019.10.03 23:13:25 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2019.10.03 23:13:25 - Connection to OpenVPN Management Interface . 2019.10.03 23:13:25 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2019.10.03 23:13:25 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.10.03 23:13:25 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.10.03 23:13:25 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.10.03 23:13:25 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.10.03 23:13:25 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.213:443 . 2019.10.03 23:13:25 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2019.10.03 23:13:25 - OpenVPN > UDP link local: (not bound) . 2019.10.03 23:13:25 - OpenVPN > UDP link remote: [AF_INET]184.75.223.213:443 . 2019.10.03 23:13:25 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.213:443, sid=5ae60d27 0fc45433 . 2019.10.03 23:13:25 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2019.10.03 23:13:25 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2019.10.03 23:13:25 - OpenVPN > VERIFY KU OK . 2019.10.03 23:13:25 - OpenVPN > Validating certificate extended key usage . 2019.10.03 23:13:25 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2019.10.03 23:13:25 - OpenVPN > VERIFY EKU OK . 2019.10.03 23:13:25 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2019.10.03 23:13:25 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2019.10.03 23:13:25 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.213:443 . 2019.10.03 23:13:26 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2019.10.03 23:13:26 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.4.206.1,dhcp-option DNS6 fde6:7a:7d20:ce::1,tun-ipv6,route-gateway 10.4.206.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:ce::1021/64 fde6:7a:7d20:ce::1,ifconfig 10.4.206.35 255.255.255.0,peer-id 6,cipher AES-256-GCM' . 2019.10.03 23:13:26 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2019.10.03 23:13:26 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2019.10.03 23:13:26 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2019.10.03 23:13:26 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2019.10.03 23:13:26 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2019.10.03 23:13:26 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2019.10.03 23:13:26 - OpenVPN > OPTIONS IMPORT: peer-id set . 2019.10.03 23:13:26 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2019.10.03 23:13:26 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2019.10.03 23:13:26 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2019.10.03 23:13:26 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.10.03 23:13:26 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.10.03 23:13:26 - OpenVPN > interactive service msg_channel=0 . 2019.10.03 23:13:26 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=16 HWADDR=70:8b:cd:42:38:4d . 2019.10.03 23:13:26 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2019.10.03 23:13:26 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2019.10.03 23:13:26 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2019.10.03 23:13:26 - OpenVPN > open_tun . 2019.10.03 23:13:27 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{43E0B7FA-6671-4D69-A47C-83E1B6785CAA}.tap . 2019.10.03 23:13:27 - OpenVPN > TAP-Windows Driver Version 9.21 . 2019.10.03 23:13:27 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.206.0/10.4.206.35/255.255.255.0 [SUCCEEDED] . 2019.10.03 23:13:27 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.206.35/255.255.255.0 on interface {43E0B7FA-6671-4D69-A47C-83E1B6785CAA} [DHCP-serv: 10.4.206.254, lease-time: 31536000] . 2019.10.03 23:13:27 - OpenVPN > Successful ARP Flush on interface [10] {43E0B7FA-6671-4D69-A47C-83E1B6785CAA} . 2019.10.03 23:13:27 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2019.10.03 23:13:27 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=10 fde6:7a:7d20:ce::1021 store=active . 2019.10.03 23:13:28 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Ethernet 3 static fde6:7a:7d20:ce::1 validate=no . 2019.10.03 23:13:29 - OpenVPN > add_route_ipv6(fde6:7a:7d20:ce::/64 -> fde6:7a:7d20:ce::1021 metric 0) dev Ethernet 3 . 2019.10.03 23:13:29 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:ce::/64 interface=10 fe80::8 store=active . 2019.10.03 23:13:29 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.10.03 23:13:34 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2019.10.03 23:13:34 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.223.213 MASK 255.255.255.255 192.168.1.1 . 2019.10.03 23:13:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2019.10.03 23:13:34 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.10.03 23:13:34 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.206.1 . 2019.10.03 23:13:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.10.03 23:13:34 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.10.03 23:13:34 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.206.1 . 2019.10.03 23:13:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.10.03 23:13:34 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.10.03 23:13:34 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:ce::1 metric -1) dev Ethernet 3 . 2019.10.03 23:13:34 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=10 fe80::8 store=active . 2019.10.03 23:13:34 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.10.03 23:13:34 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:ce::1 metric -1) dev Ethernet 3 . 2019.10.03 23:13:34 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=10 fe80::8 store=active . 2019.10.03 23:13:34 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.10.03 23:13:34 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:ce::1 metric -1) dev Ethernet 3 . 2019.10.03 23:13:34 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=10 fe80::8 store=active . 2019.10.03 23:13:34 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.10.03 23:13:34 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:ce::1 metric -1) dev Ethernet 3 . 2019.10.03 23:13:34 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=10 fe80::8 store=active . 2019.10.03 23:13:34 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.10.03 23:13:35 - Interface Ethernet 3 metric changed from Automatic to 3, layer IPv4 . 2019.10.03 23:13:35 - Interface Ethernet 3 metric changed from Automatic to 3, layer IPv6 . 2019.10.03 23:13:35 - DNS leak protection with packet filtering enabled. . 2019.10.03 23:13:35 - DNS IPv4 of a network adapter forced (Ethernet 3, from automatic to 10.4.206.1) . 2019.10.03 23:13:35 - DNS IPv6 of a network adapter forced (Ethernet 3, from automatic to fde6:7a:7d20:ce::1) . 2019.10.03 23:13:35 - Routes, added a new route, 184.75.223.211 for gateway 10.4.206.1 . 2019.10.03 23:13:36 - Routes, added a new route, 2606:6080:1002:6:f780:efa6:f9d2:3459 for gateway fde6:7a:7d20:ce::1 . 2019.10.03 23:13:36 - Flushing DNS I 2019.10.03 23:13:39 - Checking route IPv4 I 2019.10.03 23:13:39 - Checking route IPv6 . 2019.10.03 23:13:59 - curl: (28) Connection timed out after 20000 milliseconds . 2019.10.03 23:13:59 - Checking route (2° try) . 2019.10.03 23:14:20 - curl: (28) Connection timed out after 20000 milliseconds . 2019.10.03 23:14:20 - Checking route (3° try) . 2019.10.03 23:14:42 - curl: (28) Connection timed out after 20000 milliseconds E 2019.10.03 23:14:42 - Checking route IPv6 failed. . 2019.10.03 23:14:42 - OpenVPN > Initialization Sequence Completed ! 2019.10.03 23:14:42 - Disconnecting . 2019.10.03 23:14:42 - Routes, removed a route previously added, 184.75.223.211 for gateway 10.4.206.1 . 2019.10.03 23:14:42 - Routes, removed a route previously added, 2606:6080:1002:6:f780:efa6:f9d2:3459 for gateway fde6:7a:7d20:ce::1 . 2019.10.03 23:14:42 - Sending management termination signal . 2019.10.03 23:14:42 - Management - Send 'signal SIGTERM' . 2019.10.03 23:14:43 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2019.10.03 23:14:43 - OpenVPN > SIGTERM received, sending exit notification to peer . 2019.10.03 23:14:47 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 184.75.223.213 MASK 255.255.255.255 192.168.1.1 . 2019.10.03 23:14:47 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.10.03 23:14:47 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.206.1 . 2019.10.03 23:14:47 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.10.03 23:14:47 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.206.1 . 2019.10.03 23:14:47 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.10.03 23:14:47 - OpenVPN > delete_route_ipv6(::/3) . 2019.10.03 23:14:47 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 interface=10 fe80::8 store=active . 2019.10.03 23:14:47 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.10.03 23:14:47 - OpenVPN > delete_route_ipv6(2000::/4) . 2019.10.03 23:14:47 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=10 fe80::8 store=active . 2019.10.03 23:14:47 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.10.03 23:14:47 - OpenVPN > delete_route_ipv6(3000::/4) . 2019.10.03 23:14:47 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=10 fe80::8 store=active . 2019.10.03 23:14:47 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.10.03 23:14:47 - OpenVPN > delete_route_ipv6(fc00::/7) . 2019.10.03 23:14:47 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=10 fe80::8 store=active . 2019.10.03 23:14:47 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.10.03 23:14:47 - OpenVPN > Closing TUN/TAP interface . 2019.10.03 23:14:47 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:ce::/64) . 2019.10.03 23:14:47 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:ce::/64 interface=10 fe80::8 store=active . 2019.10.03 23:14:47 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address Ethernet 3 fde6:7a:7d20:ce::1021 store=active . 2019.10.03 23:14:47 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns Ethernet 3 all . 2019.10.03 23:14:48 - OpenVPN > TAP: DHCP address released . 2019.10.03 23:14:48 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2019.10.03 23:14:48 - Connection terminated. . 2019.10.03 23:14:48 - DNS IPv4 of a network adapter restored to original settings (Ethernet 3, to automatic) . 2019.10.03 23:14:48 - DNS IPv6 of a network adapter restored to original settings (Ethernet 3, to automatic) . 2019.10.03 23:14:48 - DNS leak protection with packet filtering disabled. . 2019.10.03 23:14:48 - Interface Ethernet 3 metric restored from 3 to Automatic, layer IPv4 . 2019.10.03 23:14:48 - Interface Ethernet 3 metric restored from 3 to Automatic, layer IPv6 I 2019.10.03 23:14:49 - Cancel requested. ! 2019.10.03 23:14:49 - Session terminated. Quote Share this post Link to post
Tech Jedi Alex 1534 Posted ... Can you open PowerShell and paste the outputs of ipconfig /all, please? (Use the LOG formatting in the upper left corner of the editor window) Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
leftmypasswordbookathome 0 Posted ... Same/similar issue. (Looking at OP's log.) Working fine 1 hr ago. --> Windows update. --> Not working after KB4517389 and KB4524100. --> Drilled down into Control Panel and found these were installed (three not two): KB4515871 KB4524147 KB4521863 Unable to remove KB4521863 (Security Update) --> Removed KB4515871 KB4524147 Restart. --> No connectivity. --> Internet otherwise fine. Quote Share this post Link to post
EdGotham 0 Posted ... I posted this earlier under a temporary account: "Same/similar issue. (Looking at the log.) Working fine 1 hr ago. --> Windows update. --> Not working after KB4517389 and KB4524100. --> Drilled down into Control Panel and found these were installed (three not two): KB4515871 KB4524147 KB4521863 Unable to remove KB4521863 (Security Update) Restart. --> No connectivity." System is now running okay. Process: 1. Uninstall Eddie (& a residual TAP I found in programs) 2. Wind back W10 updates. Restart. 3. Reinstall W10 updates. Restart. 4. Reinstall Eddie. Restart. 5. F&^k about with passwords for 30 minutes. 6. Success. Quote Share this post Link to post
mdoverl 2 Posted ... On 10/9/2019 at 11:56 PM, leftmypasswordbookathome said: Same/similar issue. (Looking at OP's log.) Working fine 1 hr ago. --> Windows update. --> Not working after KB4517389 and KB4524100. --> Drilled down into Control Panel and found these were installed (three not two): KB4515871 KB4524147 KB4521863 Unable to remove KB4521863 (Security Update) --> Removed KB4515871 KB4524147 Restart. --> No connectivity. --> Internet otherwise fine. Oh God, two of those are the same KBs that have been wreaking havoc at work. I'm going to remove KB4524147 first, which has been disrupting network connections at work, among other things. Sorry to everyone else I haven't responded to yet. Been the only person in my department this week and had a funeral to go to. Quote Share this post Link to post
mdoverl 2 Posted ... Well, nevermind, Eddie connected without any additional troubleshooting. Thank you, everyone, for jumping in. I really appreciate the community! Quote Share this post Link to post
mdoverl 2 Posted ... Is there a way to mark this thread as closed? Or do I just stop responding? 1 Tech Jedi Alex reacted to this Quote Share this post Link to post
