Not connected, Your IP: 216.73.216.177
Phoenix3
Network lock expected behaviour
On Linux, I see on the Netspeed applet packets sent and received when Eddie is disconnected while the Network lock is active.
Is this expected behaviour?
I took a look at the packets coming in and I see
xxx-xxx-xxx-xxx-xxx.compute-1.amazonaws.com.https > username.48656
What method can I use to verify Network lock is working as expected?
the issue about the Amazon Web Services has been adressed in this thread:
With Network Lock enabled, you should have no Internet Connection. You can, for example, open a terminal and enter:
ping 8.8.8.8
and the output should be something like "Operation not permitted".
Or you open your browser and you should not be able to reach any web sites.
Regards
BB.
AMD Ryzen 3950X @ 105W PPL
Gigabyte X570 Aorus Elite
Nvidia RTX 4070 Ti Super
Corsair DDR4-3200 32GB
Thanks for the link.
Remains the question: why does my system send and receive packets, according to tcpdump, while network lock is on and disconnected from AirVPN.
Should I not be receiving zero packets in that instance? If yes, what steps to undertake to remedy.
