pridemanx 0 Posted ... Hi from couple of days my dns leaks...eddie worked great before. I have no idea what happened. Dns are tick in eddie to check "AirVpn DNS" and "Dns switch mode" >automatically #nano /etc/resolv.conf nameserver 10.24.50.1 nameserver fde6:7a:7d20:1432::1 I would be grateful if someones could help me. Thanks. Quote Share this post Link to post
Staff 10427 Posted ... Hello! What is your exact distribution name and version? Do you run systemd-resolved? Can you check whether your /etc/resolv.conf file is a symbolic link or not, both when Eddie is connected and when Eddie is not running? What Eddie version are you running? Kind regards Quote Share this post Link to post
pridemanx 0 Posted ... (edited) Thank you for reply. My system is: 5.2.0-2parrot1-amd64 eddie-ui_2.16.3_linux_x64_debian.deb >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> cat /etc/resolv.conf # Generated by Eddie v2.16.3 | https://eddie.website nameserver 10.9.18.1 nameserver fde6:7a:7d20:512::1 >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>. #resolvectl status Global LLMNR setting: yes MulticastDNS setting: yes DNSOverTLS setting: no DNSSEC setting: allow-downgrade DNSSEC supported: no Current DNS Server: 10.9.18.1 DNS Servers: 10.9.18.1 fde6:7a:7d20:512::1 DNSSEC NTA: 10.in-addr.arpa 16.172.in-addr.arpa 168.192.in-addr.arpa 17.172.in-addr.arpa 18.172.in-addr.arpa 19.172.in-addr.arpa 20.172.in-addr.arpa 21.172.in-addr.arpa 22.172.in-addr.arpa 23.172.in-addr.arpa 24.172.in-addr.arpa 25.172.in-addr.arpa 26.172.in-addr.arpa 27.172.in-addr.arpa lines 1-23 Thank you for help. Edited ... by giganerd Took the liberty to format it into LOG formatting. Don't hit me please. Quote Share this post Link to post
pridemanx 0 Posted ... They are not symbolic link. Can someone help me please. Quote Share this post Link to post
Staff 10427 Posted ... Hello! If you run systemd-resolved try to stop it and check again. sudo systemctl stop systemd-resolved If that's the source of the issue, you need to understand how systemd-resolved works to find a compatibility between it and Eddie (or just keep it disabled):https://wiki.archlinux.org/index.php/Systemd-resolved#Automatically Kind regards Quote Share this post Link to post
