Guest Posted ... Hello, I am having technical problems with my current IPv6 setup. Specifically, when I try to access websites that report my IP (such as whatismyipaddress.com), they report only detecting an IPv4 address (specifically 185.9.19.107, which is an AirVPN server I believe) from my browser's request when I'm connected with my airvpn configuration, no IPv6 address visible to them. This is strange, specifically because my airvpn configuration is setup to use both IPv6 as the outbound address as well as the inbound one. So my question is, why is this happening? I'm assuming this is a configuration issue on my side. Further context below: 1) All the devices in my house are connected in a LAN that has a single gateway to the public internet: a wireless router with OpenWrt 18.06.2 2) The OpenWrt router is the one maintaining an open connection to the AirVPN server. Basically, the devices in my LAN should have all their network traffic routed through AirVPN servers before reaching their intended destinations. 3) OpenVPN has the airvpn.conf file generated using this website's config generator after selecting the "Linux" category (maybe "Router" would have been a better choice for the configuration file?). The conf file is attached to this thread (the same conf file also contains the certificates, openvpn static key and my private key but I omitted them since I don't believe they are relevant here). airvpn.conf 4) Here are other configurations from my OpenWRT setup: networkfirewall 5) I should probably point out that my internet didn't work at all when using the VPN with the initial airvpn config file (not even pinging the remote server by its Ipv6 address). After digging a lot through the internet I eventually came up with a script called remote_host_route6.sh which I reference in my airvpn config file and which gets executed every time openvpn tries to start the said configuration (it's referenced in the "route-up" directive in the airvpn.conf file attached). It was only after I added this script to the configuration that I began having internet at all when the VPN connection was up, albeit with the problem I'm describing in this post. The contents of this remote_host_route6 script are the following: remote_host_route6.sh 6) OpenVPN version is OpenVPN 2.4.5 7) Finally, although I am unsure how relevant this is, my "gateway" router that all my LAN devices connect to and which connects to the VPN server is itself behind an OTN device from my ISP which converts all traffic to fiber optic signal. This device is set into bridge mode and should be transparent to the network though, I believe (hence why my OpenVPN router handles the pppoe configuration). Sorry for the long post :( Quote Share this post Link to post
Tech Jedi Alex 1501 Posted ... I sense a slight XY problem. You can't reach the internet after connection (X), so you write a script and have only half the solution (Y). Then you come here with the question of how to make problem Y whole while the actual problem is X. Soo, let's go back one step and provide everything you can for the situation where you don't use that script and let's troubleshoot that first. You already provided many things, but the logs are missing. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Guest Posted ... (edited) OK. Yes, I think that would be the best approach, especially since I'm not a fan of adhoc scripts to begin with. I'm not entirely sure though where to find the opnwrt logs. Maybe this system log is helpful?log.txt Edit: oh, forgot to mention. This log was after I commented out the "route-up" directive from my openvpn.conf file and did a clean reboot afterwards). So this is how the log would look like with that remote_host_route6 script disabled Edited ... by I am nobody Forgot to mention me disabling that script Quote Share this post Link to post
