MarleyMouse
Fail to Start or Already Connected errorr
Hi, Everytime I try and connect I either get a failed to start or a already connected error.
Here are my logs, if any one could offer some help i would be very grateful.
30/09/2012 - 16:51 AirVPN client version: 1.7
30/09/2012 - 16:51 Reading options from C:\Users\Pink\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
30/09/2012 - 16:51 OpenVPN bundle version: OpenVPN 2.2.2
30/09/2012 - 16:51 OpenVPN current version: OpenVPN 2.2.2
30/09/2012 - 16:51 Login...
30/09/2012 - 16:51 Login success.
30/09/2012 - 16:51 Contacting service...
30/09/2012 - 16:51 Connecting...
30/09/2012 - 16:51 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011
30/09/2012 - 16:51 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
30/09/2012 - 16:51 LZO compression initialized
30/09/2012 - 16:51 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
30/09/2012 - 16:51 Socket Buffers: R=[8192->8192] S=[8192->8192]
30/09/2012 - 16:51 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
30/09/2012 - 16:51 Local Options hash (VER=V4): '22188c5b'
30/09/2012 - 16:51 Expected Remote Options hash (VER=V4): 'a8f55717'
30/09/2012 - 16:51 UDPv4 link local: [undef]
30/09/2012 - 16:51 UDPv4 link remote: 95.211.191.33:443
30/09/2012 - 16:51 TLS: Initial packet from 95.211.191.33:443, sid=3fc6ee83 ac190eb6
30/09/2012 - 16:51 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
30/09/2012 - 16:51 VERIFY OK: nsCertType=SERVER
30/09/2012 - 16:51 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
30/09/2012 - 16:51 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
30/09/2012 - 16:51 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
30/09/2012 - 16:51 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
30/09/2012 - 16:51 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
30/09/2012 - 16:51 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
30/09/2012 - 16:51 [server] Peer Connection Initiated with 95.211.191.33:443
30/09/2012 - 16:51 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
30/09/2012 - 16:51 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.4.0.210 10.4.0.209'
30/09/2012 - 16:51 OPTIONS IMPORT: timers and/or timeouts modified
30/09/2012 - 16:51 OPTIONS IMPORT: LZO parms modified
30/09/2012 - 16:51 OPTIONS IMPORT: --ifconfig/up options modified
30/09/2012 - 16:51 OPTIONS IMPORT: route options modified
30/09/2012 - 16:51 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
30/09/2012 - 16:51 ROUTE default_gateway=192.168.1.254
30/09/2012 - 16:51 CreateFile failed on TAP device: \\.\Global\{D068D703-FDBC-4E88-9DC7-4A4C8110D6AC}.tap
30/09/2012 - 16:51 All TAP-Win32 adapters on this system are currently in use.
30/09/2012 - 16:51 Exiting
30/09/2012 - 16:51 Failed to start.
30/09/2012 - 16:52 Login...
30/09/2012 - 16:52 Already connected.
OpenVPN can't access the TAP-Win32 adapter. Please make sure that it is enabled:
On Windows XP: Open Control Panel-->Network and Internet connections-->Network Connections. Right-click on "TAP-Win32 Adapter V9" and select "Enable".
Windows Vista: Open Control Panel-->Network and Internet-->Network and Sharing Center-->Manage network connections. Right-click "TAP-Win32 Adapter V9" and select Enable.
Windows 7: Open Control Panel-->Network and Internet-->Network and Sharing Center-->Change Adapter Settings. Right-click on "TAP-Win32 Adapter V9" and select Enable.
If you find that the TAP adapter is already enabled, select "Disable", apply the change, then select "Enable".
Please feel free to let us know whether the above solves the problem.
doesnt work
doesnt work
Please uninstall OpenVPN completely and re-install it. Make sure to authorize the installation of any driver.
