scgt1 4 Posted ... So went to go setup my hdhomerun quatro today. When I open the hdhr windows setup app it won't find the tuners. I've added the device's IP to Eddie as an allowed device (like I've had to do with our Canon printer) that didn't correct the problem. I've rebooted and since Eddie takes a bit to open and connect I quickly opened the hdhr setup program on Windows start. Low and behold it found 4 tuners and quickly went to crap as soon as Eddie started to connect. This is obviously an issue with the VPN dialer and not with the hdhr software since it was working just fine until Eddie opened and locked the network. Anyone else running hdhr software on the same computer as AirVPN? Quote Share this post Link to post
go558a83nk 383 Posted ... Allow local network in the settings. preferences>network lock>allow lan/private Quote Share this post Link to post
scgt1 4 Posted ... 7 minutes ago, go558a83nk said: Allow local network in the settings. preferences>network lock>allow lan/private It already is. Quote Share this post Link to post
go558a83nk 383 Posted ... it could be that some protocols are still blocked even if allow local is on. Staff will have to say for sure. I do know other people have had problems with blocked local assets even with allow local on and I've read of the same problem with other VPNs that also use the windows filtering platform. Quote Share this post Link to post
