Checking Authorization
I haven't had problems with AirVPN and it's been running well. However, I've recently had a problem with connecting with the "checking authorization" message keep appearing on my Windows 7 32-bit computer. I still get to connect to the VPN but it's taking a longer time to connect to it. Here's the log of recent events. Hopefully, this problem can be solved. Thank you for reading this.
. 2019.08.16 19:08:45 - Eddie version: 2.16.3 / windows_x86, System: Windows, Name: Windows 7 Ultimate, Version: Microsoft Windows NT 6.1.7601 Service Pack 1, Mono/.Net: v2.0.50727
. 2019.08.16 19:08:45 - Reading options from C:\Users\UltimateLuck\AppData\Local\AirVPN\default.xml
. 2019.08.16 19:08:45 - Command line arguments (1): path="home"
. 2019.08.16 19:08:45 - Profile path: C:\Users\UltimateLuck\AppData\Local\AirVPN\default.xml
. 2019.08.16 19:08:47 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
. 2019.08.16 19:08:47 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2019.08.16 19:08:47 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2019.08.16 19:08:47 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2019.08.16 19:08:47 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe)
. 2019.08.16 19:08:47 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem
W 2019.08.16 19:08:48 - Recovery. Unexpected crash?
. 2019.08.16 19:08:48 - Routes, remove 184.75.223.219 for gateway 10.24.14.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:49 - Routes, remove 184.75.214.163 for gateway 10.13.110.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:49 - Routes, remove 104.254.90.195 for gateway 10.29.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:49 - Routes, remove 184.75.221.43 for gateway 10.30.206.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:49 - Routes, remove 199.19.94.62 for gateway 10.20.142.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:49 - Routes, remove 199.21.149.49 for gateway 10.15.142.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:49 - Routes, remove 104.254.90.243 for gateway 10.16.78.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:49 - Routes, remove 199.19.94.135 for gateway 10.27.206.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:49 - Routes, remove 184.75.221.59 for gateway 10.31.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:49 - Routes, remove 184.75.223.195 for gateway 10.29.46.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:49 - Routes, remove 87.101.92.171 for gateway 10.11.14.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:50 - Routes, remove 184.75.221.3 for gateway 10.20.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:50 - Routes, remove 184.75.221.43 for gateway 10.30.206.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:50 - Routes, remove 137.63.71.51 for gateway 10.31.78.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:50 - Routes, remove 184.75.223.227 for gateway 10.28.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:50 - Routes, remove 184.75.214.163 for gateway 10.13.110.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:50 - Routes, remove 199.19.94.16 for gateway 10.6.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:50 - Routes, remove 104.254.90.251 for gateway 10.18.14.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:50 - Routes, remove 184.75.221.203 for gateway 10.6.206.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:50 - Routes, remove 199.19.95.188 for gateway 10.18.46.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:51 - Routes, remove 199.19.95.188 for gateway 10.18.46.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:51 - Routes, remove 87.101.92.171 for gateway 10.11.14.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:51 - Routes, remove 199.19.94.16 for gateway 10.6.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:51 - Routes, remove 184.75.223.195 for gateway 10.29.46.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:51 - Routes, remove 199.19.94.62 for gateway 10.20.142.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:51 - Routes, remove 184.75.223.235 for gateway 10.10.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:51 - Routes, remove 184.75.223.227 for gateway 10.28.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:51 - Routes, remove 184.75.221.179 for gateway 10.28.174.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:51 - Routes, remove 199.19.94.135 for gateway 10.27.206.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:51 - Routes, remove 104.254.90.235 for gateway 10.14.46.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:51 - Routes, remove 199.19.94.193 for gateway 10.30.174.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:51 - Routes, remove 184.75.223.211 for gateway 10.4.206.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:52 - Routes, remove 199.19.94.193 for gateway 10.30.174.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:52 - Routes, remove 184.75.221.171 for gateway 10.8.174.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:52 - Routes, remove 199.19.94.16 for gateway 10.6.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:52 - Routes, remove 184.75.223.203 for gateway 10.31.206.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:52 - Routes, remove 199.19.94.135 for gateway 10.27.206.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:52 - Routes, remove 104.254.90.187 for gateway 10.28.78.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:52 - Routes, remove 87.101.92.171 for gateway 10.11.14.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:52 - Routes, remove 184.75.221.195 for gateway 10.31.110.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:52 - Above log line repeated 1 times more
. 2019.08.16 19:08:52 - Routes, remove 184.75.223.235 for gateway 10.10.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:52 - Routes, remove 184.75.221.179 for gateway 10.28.174.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:53 - Routes, remove 199.19.94.135 for gateway 10.27.206.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:53 - Routes, remove 137.63.71.51 for gateway 10.31.78.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:53 - Routes, remove 87.101.92.171 for gateway 10.11.14.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:53 - Routes, remove 184.75.223.203 for gateway 10.31.206.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:53 - Routes, remove 184.75.221.171 for gateway 10.8.174.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:53 - Routes, remove 184.75.223.195 for gateway 10.29.46.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:53 - Routes, remove 184.75.221.179 for gateway 10.28.174.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:53 - Routes, remove 184.75.223.235 for gateway 10.10.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:53 - Routes, remove 184.75.221.59 for gateway 10.31.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:54 - Routes, remove 184.75.223.195 for gateway 10.29.46.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:54 - Routes, remove 184.75.221.195 for gateway 10.31.110.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:54 - Routes, remove 137.63.71.51 for gateway 10.31.78.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:54 - Routes, remove 184.75.221.3 for gateway 10.20.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:54 - Routes, remove 87.101.92.171 for gateway 10.11.14.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:54 - Routes, remove 184.75.221.35 for gateway 10.28.14.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:54 - Routes, remove 104.254.90.243 for gateway 10.16.78.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:54 - Routes, remove 184.75.221.163 for gateway 10.9.46.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:54 - Routes, remove 184.75.221.171 for gateway 10.8.174.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:54 - Routes, remove 184.75.223.227 for gateway 10.28.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:54 - Routes, remove 104.254.90.251 for gateway 10.18.14.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:55 - Routes, remove 87.101.92.171 for gateway 10.11.14.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:55 - Routes, remove 184.75.223.227 for gateway 10.28.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:55 - Routes, remove 184.75.221.179 for gateway 10.28.174.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:55 - Routes, remove 184.75.221.211 for gateway 10.9.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:55 - Routes, remove 104.254.90.243 for gateway 10.16.78.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:55 - Routes, remove 184.75.221.3 for gateway 10.20.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:55 - Routes, remove 184.75.223.219 for gateway 10.24.14.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:55 - Routes, remove 162.219.176.3 for gateway 10.6.110.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:55 - Routes, remove 184.75.221.195 for gateway 10.31.110.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:55 - Routes, remove 184.75.221.59 for gateway 10.31.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:55 - Routes, remove 184.75.223.235 for gateway 10.10.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:56 - Routes, remove 184.75.221.195 for gateway 10.31.110.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:56 - Routes, remove 184.75.223.211 for gateway 10.4.206.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:56 - Routes, remove 162.219.176.3 for gateway 10.6.110.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:56 - Routes, remove 184.75.221.3 for gateway 10.20.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:56 - Routes, remove 184.75.221.35 for gateway 10.28.14.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:56 - Routes, remove 104.254.90.187 for gateway 10.28.78.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:56 - Routes, remove 184.75.223.203 for gateway 10.31.206.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:56 - Routes, remove 184.75.223.235 for gateway 10.10.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:56 - Routes, remove 104.254.90.243 for gateway 10.16.78.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:56 - Routes, remove 104.254.90.235 for gateway 10.14.46.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:56 - Routes, remove 184.75.221.179 for gateway 10.28.174.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:57 - Routes, remove 137.63.71.51 for gateway 10.31.78.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:57 - Routes, remove 213.152.161.138 for gateway 10.31.14.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:57 - Routes, remove 184.75.221.211 for gateway 10.9.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:57 - Above log line repeated 1 times more
. 2019.08.16 19:08:57 - Routes, remove 104.254.90.243 for gateway 10.16.78.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:57 - Routes, remove 184.75.221.195 for gateway 10.31.110.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:57 - Routes, remove 184.75.221.171 for gateway 10.8.174.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:57 - Routes, remove 184.75.221.59 for gateway 10.31.238.1 failed: The route deletion failed: Element not found
. 2019.08.16 19:08:57 - Routes, removed a route previously added, 2606:6080:1001:10:3c5b:63ff:df18:8486 for gateway fde6:7a:7d20:1bee::1
. 2019.08.16 19:08:57 - Updating systems & servers data ...
I 2019.08.16 19:08:58 - Ready
I 2019.08.16 19:08:59 - Session starting.
I 2019.08.16 19:09:03 - Checking authorization ...
. 2019.08.16 19:10:18 - Cannot retrieve systems & servers data. (curl: (28) Connection timed out after 20015 milliseconds)
W 2019.08.16 19:10:23 - Authorization check failed, continue anyway (curl: (28) Connection timed out after 20015 milliseconds)
! 2019.08.16 19:10:23 - Connecting to Alwaid (Canada, Toronto, Ontario)
. 2019.08.16 19:10:23 - OpenVPN > OpenVPN 2.4.6 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.08.16 19:10:23 - OpenVPN > Windows version 6.1 (Windows 7) 32bit
. 2019.08.16 19:10:23 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.08.16 19:10:23 - Connection to OpenVPN Management Interface
. 2019.08.16 19:10:23 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.08.16 19:10:23 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.08.16 19:10:23 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.08.16 19:10:23 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.08.16 19:10:23 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.08.16 19:10:23 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.117:443
. 2019.08.16 19:10:23 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2019.08.16 19:10:23 - OpenVPN > UDP link local: (not bound)
. 2019.08.16 19:10:23 - OpenVPN > UDP link remote: [AF_INET]184.75.221.117:443
. 2019.08.16 19:10:23 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.08.16 19:10:23 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.117:443, sid=15607831 1f4a90ce
. 2019.08.16 19:10:23 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.08.16 19:10:23 - OpenVPN > VERIFY KU OK
. 2019.08.16 19:10:23 - OpenVPN > Validating certificate extended key usage
. 2019.08.16 19:10:23 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.08.16 19:10:23 - OpenVPN > VERIFY EKU OK
. 2019.08.16 19:10:23 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.08.16 19:10:24 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.08.16 19:10:24 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.117:443
. 2019.08.16 19:10:25 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.08.16 19:10:25 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.8.142.1,dhcp-option DNS6 fde6:7a:7d20:48e::1,tun-ipv6,route-gateway 10.8.142.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:48e::10ac/64 fde6:7a:7d20:48e::1,ifconfig 10.8.142.174 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2019.08.16 19:10:25 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.08.16 19:10:25 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.08.16 19:10:25 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.08.16 19:10:25 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.08.16 19:10:25 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.08.16 19:10:25 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.08.16 19:10:25 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.08.16 19:10:25 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.08.16 19:10:25 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.08.16 19:10:25 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.08.16 19:10:25 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.08.16 19:10:25 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.08.16 19:10:25 - OpenVPN > interactive service msg_channel=0
. 2019.08.16 19:10:25 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=14 HWADDR=b0:39:56:8f:3a:87
. 2019.08.16 19:10:25 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2019.08.16 19:10:25 - OpenVPN > GetBestInterfaceEx() returned if=13
. 2019.08.16 19:10:25 - OpenVPN > GDG6: II=13 DP=::/0 NH=::
. 2019.08.16 19:10:25 - OpenVPN > GDG6: Metric=8, Loopback=0, AA=1, I=0
. 2019.08.16 19:10:25 - OpenVPN > ROUTE6_GATEWAY :: ON_LINK I=13
. 2019.08.16 19:10:25 - OpenVPN > open_tun
. 2019.08.16 19:10:25 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{E52DFCFF-A81A-4542-AA2D-01CCD3449986}.tap
. 2019.08.16 19:10:25 - OpenVPN > TAP-Windows Driver Version 9.21
. 2019.08.16 19:10:25 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.8.142.0/10.8.142.174/255.255.255.0 [SUCCEEDED]
. 2019.08.16 19:10:25 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.8.142.174/255.255.255.0 on interface {E52DFCFF-A81A-4542-AA2D-01CCD3449986} [DHCP-serv: 10.8.142.254, lease-time: 31536000]
. 2019.08.16 19:10:25 - OpenVPN > Successful ARP Flush on interface [16] {E52DFCFF-A81A-4542-AA2D-01CCD3449986}
. 2019.08.16 19:10:25 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2019.08.16 19:10:26 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=16 fde6:7a:7d20:48e::10ac store=active
. 2019.08.16 19:10:27 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Local Area Connection 2 static fde6:7a:7d20:48e::1 validate=no
. 2019.08.16 19:10:27 - OpenVPN > add_route_ipv6(fde6:7a:7d20:48e::/64 -> fde6:7a:7d20:48e::10ac metric 0) dev Local Area Connection 2
. 2019.08.16 19:10:27 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:48e::/64 interface=16 fe80::8 store=active
. 2019.08.16 19:10:27 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2019.08.16 19:10:32 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2019.08.16 19:10:32 - OpenVPN > C:\Windows\system32\route.exe ADD 184.75.221.117 MASK 255.255.255.255 192.168.1.1
. 2019.08.16 19:10:32 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2019.08.16 19:10:32 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2019.08.16 19:10:32 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.8.142.1
. 2019.08.16 19:10:32 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.8.142.1
. 2019.08.16 19:10:32 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:48e::1 metric -1) dev Local Area Connection 2
. 2019.08.16 19:10:32 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=16 fe80::8 store=active
. 2019.08.16 19:10:32 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2019.08.16 19:10:32 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:48e::1 metric -1) dev Local Area Connection 2
. 2019.08.16 19:10:32 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=16 fe80::8 store=active
. 2019.08.16 19:10:32 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:48e::1 metric -1) dev Local Area Connection 2
. 2019.08.16 19:10:32 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=16 fe80::8 store=active
. 2019.08.16 19:10:32 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:48e::1 metric -1) dev Local Area Connection 2
. 2019.08.16 19:10:32 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=16 fe80::8 store=active
. 2019.08.16 19:10:32 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2019.08.16 19:10:32 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2019.08.16 19:10:32 - DNS leak protection with packet filtering enabled.
. 2019.08.16 19:10:33 - DNS IPv4 of a network adapter forced (Local Area Connection 2, from automatic to 10.8.142.1)
. 2019.08.16 19:10:33 - DNS IPv6 of a network adapter forced (Local Area Connection 2, from automatic to fde6:7a:7d20:48e::1)
. 2019.08.16 19:10:33 - Routes, added a new route, 184.75.221.115 for gateway 10.8.142.1
. 2019.08.16 19:10:33 - Routes, added a new route, 2606:6080:1001:11:60bc:461c:1305:bb4b for gateway fde6:7a:7d20:48e::1
. 2019.08.16 19:10:33 - Flushing DNS
I 2019.08.16 19:10:36 - Checking route IPv4
I 2019.08.16 19:10:37 - Checking route IPv6
I 2019.08.16 19:10:40 - Checking DNS
! 2019.08.16 19:10:51 - Connected.
. 2019.08.16 19:10:51 - OpenVPN > Initialization Sequence Completed
. 2019.08.16 19:11:49 - Updating systems & servers data ...
. 2019.08.16 19:11:50 - Systems & servers data update completed
! 2019.08.16 19:15:16 - Disconnecting
. 2019.08.16 19:15:16 - Routes, removed a route previously added, 184.75.221.115 for gateway 10.8.142.1
. 2019.08.16 19:15:16 - Routes, removed a route previously added, 2606:6080:1001:11:60bc:461c:1305:bb4b for gateway fde6:7a:7d20:48e::1
. 2019.08.16 19:15:16 - Sending management termination signal
. 2019.08.16 19:15:16 - Management - Send 'signal SIGTERM'
. 2019.08.16 19:15:17 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.08.16 19:15:17 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.08.16 19:15:21 - OpenVPN > C:\Windows\system32\route.exe DELETE 184.75.221.117 MASK 255.255.255.255 192.168.1.1
. 2019.08.16 19:15:21 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2019.08.16 19:15:21 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.8.142.1
. 2019.08.16 19:15:21 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.8.142.1
. 2019.08.16 19:15:21 - OpenVPN > delete_route_ipv6(::/3)
. 2019.08.16 19:15:21 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=16 fe80::8 store=active
. 2019.08.16 19:15:21 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2019.08.16 19:15:21 - OpenVPN > delete_route_ipv6(2000::/4)
. 2019.08.16 19:15:21 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=16 fe80::8 store=active
. 2019.08.16 19:15:21 - OpenVPN > delete_route_ipv6(3000::/4)
. 2019.08.16 19:15:21 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=16 fe80::8 store=active
. 2019.08.16 19:15:22 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2019.08.16 19:15:22 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=16 fe80::8 store=active
. 2019.08.16 19:15:22 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2019.08.16 19:15:22 - OpenVPN > Closing TUN/TAP interface
. 2019.08.16 19:15:22 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:48e::/64)
. 2019.08.16 19:15:22 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:48e::/64 interface=16 fe80::8 store=active
. 2019.08.16 19:15:22 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Local Area Connection 2 fde6:7a:7d20:48e::10ac store=active
. 2019.08.16 19:15:22 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Local Area Connection 2 all
. 2019.08.16 19:15:22 - OpenVPN > TAP: DHCP address released
. 2019.08.16 19:15:22 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.08.16 19:15:22 - Connection terminated.
. 2019.08.16 19:15:22 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2019.08.16 19:15:22 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2019.08.16 19:15:22 - DNS leak protection with packet filtering disabled.
. 2019.08.16 19:15:22 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv4
. 2019.08.16 19:15:22 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv6
. 2019.08.16 19:15:22 - Flushing DNS
! 2019.08.16 19:15:25 - Session terminated.
I 2019.08.16 19:15:45 - Session starting.
I 2019.08.16 19:15:45 - Checking authorization ...
W 2019.08.16 19:17:05 - Authorization check failed, continue anyway (curl: (28) Connection timed out after 20015 milliseconds)
! 2019.08.16 19:17:05 - Connecting to Saiph (Canada, Toronto, Ontario)
. 2019.08.16 19:17:05 - OpenVPN > OpenVPN 2.4.6 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.08.16 19:17:05 - OpenVPN > Windows version 6.1 (Windows 7) 32bit
. 2019.08.16 19:17:05 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.08.16 19:17:05 - Connection to OpenVPN Management Interface
. 2019.08.16 19:17:05 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.08.16 19:17:05 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.08.16 19:17:05 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.08.16 19:17:05 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.08.16 19:17:05 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.08.16 19:17:05 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.229:443
. 2019.08.16 19:17:05 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2019.08.16 19:17:05 - OpenVPN > UDP link local: (not bound)
. 2019.08.16 19:17:05 - OpenVPN > UDP link remote: [AF_INET]184.75.223.229:443
. 2019.08.16 19:17:05 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.08.16 19:17:05 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.229:443, sid=756ddb21 4c0bb582
. 2019.08.16 19:17:05 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.08.16 19:17:05 - OpenVPN > VERIFY KU OK
. 2019.08.16 19:17:05 - OpenVPN > Validating certificate extended key usage
. 2019.08.16 19:17:05 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.08.16 19:17:05 - OpenVPN > VERIFY EKU OK
. 2019.08.16 19:17:05 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Saiph, emailAddress=info@airvpn.org
. 2019.08.16 19:17:06 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.08.16 19:17:06 - OpenVPN > [Saiph] Peer Connection Initiated with [AF_INET]184.75.223.229:443
. 2019.08.16 19:17:07 - OpenVPN > SENT CONTROL [Saiph]: 'PUSH_REQUEST' (status=1)
. 2019.08.16 19:17:07 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.238.1,dhcp-option DNS6 fde6:7a:7d20:18ee::1,tun-ipv6,route-gateway 10.28.238.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:18ee::102c/64 fde6:7a:7d20:18ee::1,ifconfig 10.28.238.46 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2019.08.16 19:17:07 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.08.16 19:17:07 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.08.16 19:17:07 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.08.16 19:17:07 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.08.16 19:17:07 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.08.16 19:17:07 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.08.16 19:17:07 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.08.16 19:17:07 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.08.16 19:17:07 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.08.16 19:17:07 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.08.16 19:17:07 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.08.16 19:17:07 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.08.16 19:17:07 - OpenVPN > interactive service msg_channel=0
. 2019.08.16 19:17:07 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=14 HWADDR=b0:39:56:8f:3a:87
. 2019.08.16 19:17:07 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2019.08.16 19:17:07 - OpenVPN > GetBestInterfaceEx() returned if=13
. 2019.08.16 19:17:07 - OpenVPN > GDG6: II=13 DP=::/0 NH=::
. 2019.08.16 19:17:07 - OpenVPN > GDG6: Metric=8, Loopback=0, AA=1, I=0
. 2019.08.16 19:17:07 - OpenVPN > ROUTE6_GATEWAY :: ON_LINK I=13
. 2019.08.16 19:17:07 - OpenVPN > open_tun
. 2019.08.16 19:17:07 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{E52DFCFF-A81A-4542-AA2D-01CCD3449986}.tap
. 2019.08.16 19:17:07 - OpenVPN > TAP-Windows Driver Version 9.21
. 2019.08.16 19:17:07 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.28.238.0/10.28.238.46/255.255.255.0 [SUCCEEDED]
. 2019.08.16 19:17:07 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.28.238.46/255.255.255.0 on interface {E52DFCFF-A81A-4542-AA2D-01CCD3449986} [DHCP-serv: 10.28.238.254, lease-time: 31536000]
. 2019.08.16 19:17:07 - OpenVPN > Successful ARP Flush on interface [16] {E52DFCFF-A81A-4542-AA2D-01CCD3449986}
. 2019.08.16 19:17:07 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2019.08.16 19:17:08 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=16 fde6:7a:7d20:18ee::102c store=active
. 2019.08.16 19:17:09 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Local Area Connection 2 static fde6:7a:7d20:18ee::1 validate=no
. 2019.08.16 19:17:09 - OpenVPN > add_route_ipv6(fde6:7a:7d20:18ee::/64 -> fde6:7a:7d20:18ee::102c metric 0) dev Local Area Connection 2
. 2019.08.16 19:17:09 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:18ee::/64 interface=16 fe80::8 store=active
. 2019.08.16 19:17:09 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2019.08.16 19:17:14 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2019.08.16 19:17:14 - OpenVPN > C:\Windows\system32\route.exe ADD 184.75.223.229 MASK 255.255.255.255 192.168.1.1
. 2019.08.16 19:17:14 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2019.08.16 19:17:14 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2019.08.16 19:17:14 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.28.238.1
. 2019.08.16 19:17:14 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2019.08.16 19:17:14 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.28.238.1
. 2019.08.16 19:17:14 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:18ee::1 metric -1) dev Local Area Connection 2
. 2019.08.16 19:17:14 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=16 fe80::8 store=active
. 2019.08.16 19:17:14 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2019.08.16 19:17:14 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:18ee::1 metric -1) dev Local Area Connection 2
. 2019.08.16 19:17:14 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=16 fe80::8 store=active
. 2019.08.16 19:17:14 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:18ee::1 metric -1) dev Local Area Connection 2
. 2019.08.16 19:17:14 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=16 fe80::8 store=active
. 2019.08.16 19:17:14 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:18ee::1 metric -1) dev Local Area Connection 2
. 2019.08.16 19:17:14 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=16 fe80::8 store=active
. 2019.08.16 19:17:14 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2019.08.16 19:17:14 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2019.08.16 19:17:14 - DNS leak protection with packet filtering enabled.
. 2019.08.16 19:17:15 - DNS IPv4 of a network adapter forced (Local Area Connection 2, from automatic to 10.28.238.1)
. 2019.08.16 19:17:15 - DNS IPv6 of a network adapter forced (Local Area Connection 2, from automatic to fde6:7a:7d20:18ee::1)
. 2019.08.16 19:17:15 - Routes, added a new route, 184.75.223.227 for gateway 10.28.238.1
. 2019.08.16 19:17:15 - Routes, added a new route, 2606:6080:1002:8:3285:30e:de43:8809 for gateway fde6:7a:7d20:18ee::1
. 2019.08.16 19:17:15 - Flushing DNS
I 2019.08.16 19:17:18 - Checking route IPv4
I 2019.08.16 19:17:18 - Checking route IPv6
I 2019.08.16 19:17:22 - Checking DNS
! 2019.08.16 19:17:33 - Connected.
. 2019.08.16 19:17:33 - OpenVPN > Initialization Sequence Completed
I have the same issue.
I can't connect with Eddie on my Windows 10, Linux machine, but is working using the app and access this site if use my cellphone with my data.
I use google DNS and cloudfare and with both I can't access airvpn and ipleaks.
I tried also the provider's DNS still nothing.
I'm confused why is working with no issue on the cellphone but not with my home connection, the only thing I can see, is the data connection use ipv6, so maybe this is the problem?
Just my 2 cents.
