Paul Jackson 0 Posted ... I am trying to setup this router but it only allows 3 files and when generated I have 4, have tried a combination and can't get a connection. Thanks Paul Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... Then it seems to be outdated. That key is required if the server uses tls-auth, which is true for AirVPN's servers. Quote tls-auth The tls-auth directive adds an additional HMAC signature to all SSL/TLS handshake packets for integrity verification. Any UDP packet not bearing the correct HMAC signature can be dropped without further processing. The tls-auth HMAC signature provides an additional level of security above and beyond that provided by SSL/TLS. It can protect against: DoS attacks or port flooding on the OpenVPN UDP port. Port scanning to determine which server UDP ports are in a listening state. Buffer overflow vulnerabilities in the SSL/TLS implementation. SSL/TLS handshake initiations from unauthorized machines (while such handshakes would ultimately fail to authenticate, tls-auth can cut them off at a much earlier point). No combination will work because all four are needed. Sorry. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
urbanconcrete 14 Posted ... Have a look at https://www.asuswrt-merlin.net/ Maybe your router is supported. Anyways, its better to tell your hardware if you need support... Quote Share this post Link to post
