beholdbenefit
ANSWERED Newest version. Weird problems
There are two problems that usually happen frequently. I have a macbook air 10.13.2
1. When I open my computer the wifi has trouble connecting. Sometime it resolves itself and just needs time. Sometimes it doesnt and I need to do something. Ive noticed that toggling the network lock on and off helps but this might just be my imagination and i havent done it enough times to accept that theres a clear pattern
2. After the wifi is eventually established (usually takes about a minute or two), Eddie gets stuck in a loop. See logs for details. In either case I solve it by quitting and restarting Eddie
Any help would be greatly appreciated. Thank you
Heres a log when something goes wrong
. 2019.08.11 07:49:18 - OpenVPN > /sbin/route delete -net 104.254.90.205 10.0.0.1 255.255.255.255
. 2019.08.11 07:49:18 - OpenVPN > delete net 104.254.90.205: gateway 10.0.0.1
. 2019.08.11 07:49:18 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.8.94.1 128.0.0.0
. 2019.08.11 07:49:18 - OpenVPN > delete net 0.0.0.0: gateway 10.8.94.1
. 2019.08.11 07:49:18 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.8.94.1 128.0.0.0
. 2019.08.11 07:49:18 - OpenVPN > delete net 128.0.0.0: gateway 10.8.94.1
. 2019.08.11 07:49:18 - OpenVPN > delete_route_ipv6(::/3)
. 2019.08.11 07:49:18 - OpenVPN > /sbin/route delete -inet6 :: -prefixlen 3 -iface utun1
. 2019.08.11 07:49:18 - OpenVPN > delete net ::: gateway utun1
. 2019.08.11 07:49:18 - OpenVPN > delete_route_ipv6(2000::/4)
. 2019.08.11 07:49:18 - OpenVPN > /sbin/route delete -inet6 2000:: -prefixlen 4 -iface utun1
. 2019.08.11 07:49:18 - OpenVPN > delete net 2000::: gateway utun1
. 2019.08.11 07:49:18 - OpenVPN > delete_route_ipv6(3000::/4)
. 2019.08.11 07:49:18 - OpenVPN > /sbin/route delete -inet6 3000:: -prefixlen 4 -iface utun1
. 2019.08.11 07:49:18 - OpenVPN > delete net 3000::: gateway utun1
. 2019.08.11 07:49:18 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2019.08.11 07:49:18 - OpenVPN > /sbin/route delete -inet6 fc00:: -prefixlen 7 -iface utun1
. 2019.08.11 07:49:18 - OpenVPN > delete net fc00::: gateway utun1
. 2019.08.11 07:49:18 - OpenVPN > Closing TUN/TAP interface
. 2019.08.11 07:49:18 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:45e::10b4
. 2019.08.11 07:49:18 - OpenVPN > delete host fde6:7a:7d20:45e::10b4
. 2019.08.11 07:49:18 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.08.11 07:49:18 - Connection terminated.
. 2019.08.11 07:49:18 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic)
. 2019.08.11 07:49:18 - DNS of a network adapter restored to original settings (Bluetooth PAN, to Automatic)
. 2019.08.11 07:49:18 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
I 2019.08.11 07:49:20 - Cancel requested.
! 2019.08.11 07:49:20 - Session terminated.
! 2019.08.11 07:49:23 - Logged out.
I 2019.08.11 07:49:24 - Checking login ...
! 2019.08.11 07:49:25 - Logged in.
I 2019.08.11 07:49:26 - Session starting.
I 2019.08.11 07:49:26 - Checking authorization ...
! 2019.08.11 07:49:27 - Connecting to Angetenar (Canada, Toronto, Ontario)
. 2019.08.11 07:49:27 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.08.11 07:49:27 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.08.11 07:49:27 - Connection to OpenVPN Management Interface
. 2019.08.11 07:49:27 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3116
. 2019.08.11 07:49:27 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.08.11 07:49:27 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.08.11 07:49:27 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.08.11 07:49:27 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.08.11 07:49:27 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.165:443
. 2019.08.11 07:49:27 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2019.08.11 07:49:27 - OpenVPN > UDP link local: (not bound)
. 2019.08.11 07:49:27 - OpenVPN > UDP link remote: [AF_INET]184.75.221.165:443
. 2019.08.11 07:49:27 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.165:443, sid=7e800de7 a20e0d18
. 2019.08.11 07:49:27 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3116
. 2019.08.11 07:49:27 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.08.11 07:49:27 - OpenVPN > VERIFY KU OK
. 2019.08.11 07:49:27 - OpenVPN > Validating certificate extended key usage
. 2019.08.11 07:49:27 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.08.11 07:49:27 - OpenVPN > VERIFY EKU OK
. 2019.08.11 07:49:27 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.08.11 07:49:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.08.11 07:49:27 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.165:443
. 2019.08.11 07:49:28 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.08.11 07:49:28 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.9.62.1,dhcp-option DNS6 fde6:7a:7d20:53e::1,tun-ipv6,route-gateway 10.9.62.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:53e::10c6/64 fde6:7a:7d20:53e::1,ifconfig 10.9.62.200 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2019.08.11 07:49:28 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.08.11 07:49:28 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.08.11 07:49:28 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.08.11 07:49:28 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.08.11 07:49:28 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.08.11 07:49:28 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.08.11 07:49:28 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.08.11 07:49:28 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.08.11 07:49:28 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.08.11 07:49:28 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.08.11 07:49:28 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.08.11 07:49:28 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.08.11 07:49:28 - OpenVPN > ROUTE_GATEWAY 10.0.0.1/255.255.255.0 IFACE=en0 HWADDR=c4:b3:01:90:16:e2
. 2019.08.11 07:49:28 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2019.08.11 07:49:28 - OpenVPN > GDG6: problem writing to routing socket
. 2019.08.11 07:49:28 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2019.08.11 07:49:28 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.08.11 07:49:28 - OpenVPN > Opened utun device utun1
. 2019.08.11 07:49:28 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2019.08.11 07:49:28 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.08.11 07:49:28 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.08.11 07:49:28 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.08.11 07:49:28 - OpenVPN > /sbin/ifconfig utun1 10.9.62.200 10.9.62.200 netmask 255.255.255.0 mtu 1500 up
. 2019.08.11 07:49:28 - OpenVPN > /sbin/route add -net 10.9.62.0 10.9.62.200 255.255.255.0
. 2019.08.11 07:49:28 - OpenVPN > add net 10.9.62.0: gateway 10.9.62.200
. 2019.08.11 07:49:28 - OpenVPN > /sbin/ifconfig utun1 inet6 fde6:7a:7d20:53e::10c6/64
. 2019.08.11 07:49:28 - OpenVPN > add_route_ipv6(fde6:7a:7d20:53e::/64 -> fde6:7a:7d20:53e::10c6 metric 0) dev utun1
. 2019.08.11 07:49:28 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:53e:: -prefixlen 64 -iface utun1
. 2019.08.11 07:49:28 - OpenVPN > route: writing to routing socket: File exists
. 2019.08.11 07:49:28 - OpenVPN > add net fde6:7a:7d20:53e::: gateway utun1: File exists
. 2019.08.11 07:49:28 - OpenVPN > /sbin/route add -net 184.75.221.165 10.0.0.1 255.255.255.255
. 2019.08.11 07:49:28 - OpenVPN > add net 184.75.221.165: gateway 10.0.0.1
. 2019.08.11 07:49:28 - OpenVPN > /sbin/route add -net 0.0.0.0 10.9.62.1 128.0.0.0
. 2019.08.11 07:49:28 - OpenVPN > add net 0.0.0.0: gateway 10.9.62.1
. 2019.08.11 07:49:28 - OpenVPN > /sbin/route add -net 128.0.0.0 10.9.62.1 128.0.0.0
. 2019.08.11 07:49:28 - OpenVPN > add net 128.0.0.0: gateway 10.9.62.1
. 2019.08.11 07:49:28 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:53e::1 metric -1) dev utun1
. 2019.08.11 07:49:28 - OpenVPN > /sbin/route add -inet6 :: -prefixlen 3 -iface utun1
. 2019.08.11 07:49:28 - OpenVPN > add net ::: gateway utun1
. 2019.08.11 07:49:28 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:53e::1 metric -1) dev utun1
. 2019.08.11 07:49:28 - OpenVPN > /sbin/route add -inet6 2000:: -prefixlen 4 -iface utun1
. 2019.08.11 07:49:28 - OpenVPN > add net 2000::: gateway utun1
. 2019.08.11 07:49:28 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:53e::1 metric -1) dev utun1
. 2019.08.11 07:49:28 - OpenVPN > /sbin/route add -inet6 3000:: -prefixlen 4 -iface utun1
. 2019.08.11 07:49:28 - OpenVPN > add net 3000::: gateway utun1
. 2019.08.11 07:49:28 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:53e::1 metric -1) dev utun1
. 2019.08.11 07:49:28 - OpenVPN > /sbin/route add -inet6 fc00:: -prefixlen 7 -iface utun1
. 2019.08.11 07:49:28 - OpenVPN > add net fc00::: gateway utun1
. 2019.08.11 07:49:28 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.9.62.1, fde6:7a:7d20:53e::1)
. 2019.08.11 07:49:29 - DNS of a network adapter forced (Bluetooth PAN, from Automatic to 10.9.62.1, fde6:7a:7d20:53e::1)
. 2019.08.11 07:49:29 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.9.62.1, fde6:7a:7d20:53e::1)
. 2019.08.11 07:49:29 - Routes, added a new route, 184.75.221.163 for gateway 10.9.62.1
. 2019.08.11 07:49:29 - Routes, added a new route, 2606:6080:1001:12:257a:8b87:f80d:7579 for gateway fde6:7a:7d20:53e::1
. 2019.08.11 07:49:29 - Flushing DNS
I 2019.08.11 07:49:29 - Checking route IPv4
. 2019.08.11 07:49:49 - curl: (28) Connection timed out after 20005 milliseconds
. 2019.08.11 07:49:49 - Checking route (2° try)
. 2019.08.11 07:50:10 - curl: (28) Connection timed out after 20000 milliseconds
. 2019.08.11 07:50:10 - Checking route (3° try)
Heres one where I restart Eddie
. 2019.08.11 07:50:55 - Eddie version: 2.16.3 / macos_x64, System: MacOS, Name: 10.13.2, Version: Darwin MrButtonss-MacBook-Air.local 17.3.0 Darwin Kernel Version 17.3.0: Thu Nov  9 18:09:22 PST 2017; root:xnu-4570.31.3~1/RELEASE_X86_64 x86_64, Mono/.Net: v4.0.30319
. 2019.08.11 07:50:56 - Reading options from /Users/MrButtons/.airvpn/default.xml
. 2019.08.11 07:50:56 - Command line arguments (1): gui.osx.style="dark"
. 2019.08.11 07:50:57 - Profile path: /Users/MrButtons/.airvpn/default.xml
. 2019.08.11 07:50:58 - OpenVPN Driver - Expected
. 2019.08.11 07:50:58 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
. 2019.08.11 07:50:58 - SSH - Version: OpenSSH_7.6p1, LibreSSL 2.6.2 (/usr/bin/ssh)
. 2019.08.11 07:50:58 - SSL - Version: stunnel 5.48 (/Applications/Eddie.app/Contents/MacOS/stunnel)
. 2019.08.11 07:50:58 - curl - Version: 7.54.0 (/usr/bin/curl)
. 2019.08.11 07:50:58 - Certification Authorities: /Applications/Eddie.app/Contents/MacOS/../Resources/cacert.pem
W 2019.08.11 07:50:59 - Recovery. Unexpected crash?
. 2019.08.11 07:50:59 - Routes, removed a route previously added, 184.75.223.203 for gateway 10.31.222.1
. 2019.08.11 07:50:59 - Routes, removed a route previously added, 2606:6080:1002:5:a1ba:b510:7908:829e for gateway fde6:7a:7d20:1bde::1
! 2019.08.11 07:50:59 - Activation of Network Lock - macOS - PF
. 2019.08.11 07:50:59 - macOS - PF rules updated, reloading
. 2019.08.11 07:50:59 - Updating systems & servers data ...
. 2019.08.11 07:51:00 - Systems & servers data update completed
I 2019.08.11 07:51:01 - Session starting.
I 2019.08.11 07:51:07 - Checking authorization ...
! 2019.08.11 07:51:07 - Connecting to Arkab (Canada, Toronto, Ontario)
. 2019.08.11 07:51:08 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.08.11 07:51:08 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.08.11 07:51:08 - Connection to OpenVPN Management Interface
. 2019.08.11 07:51:08 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3116
. 2019.08.11 07:51:08 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.08.11 07:51:08 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.08.11 07:51:08 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.08.11 07:51:08 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.08.11 07:51:08 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.213:443
. 2019.08.11 07:51:08 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2019.08.11 07:51:08 - OpenVPN > UDP link local: (not bound)
. 2019.08.11 07:51:08 - OpenVPN > UDP link remote: [AF_INET]184.75.221.213:443
. 2019.08.11 07:51:08 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.213:443, sid=50f75135 163f7f70
. 2019.08.11 07:51:08 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.08.11 07:51:08 - OpenVPN > VERIFY KU OK
. 2019.08.11 07:51:08 - OpenVPN > Validating certificate extended key usage
. 2019.08.11 07:51:08 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.08.11 07:51:08 - OpenVPN > VERIFY EKU OK
. 2019.08.11 07:51:08 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.08.11 07:51:08 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3116
. 2019.08.11 07:51:08 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.08.11 07:51:08 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.213:443
. 2019.08.11 07:51:09 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.08.11 07:51:09 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.9.254.1,dhcp-option DNS6 fde6:7a:7d20:5fe::1,tun-ipv6,route-gateway 10.9.254.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:5fe::10b2/64 fde6:7a:7d20:5fe::1,ifconfig 10.9.254.180 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2019.08.11 07:51:09 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.08.11 07:51:09 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.08.11 07:51:09 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.08.11 07:51:09 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.08.11 07:51:09 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.08.11 07:51:09 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.08.11 07:51:09 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.08.11 07:51:09 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.08.11 07:51:09 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.08.11 07:51:09 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.08.11 07:51:09 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.08.11 07:51:09 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.08.11 07:51:09 - OpenVPN > ROUTE_GATEWAY 10.0.0.1/255.255.255.0 IFACE=en0 HWADDR=c4:b3:01:90:16:e2
. 2019.08.11 07:51:09 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2019.08.11 07:51:09 - OpenVPN > GDG6: problem writing to routing socket
. 2019.08.11 07:51:09 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2019.08.11 07:51:09 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.08.11 07:51:09 - OpenVPN > Opened utun device utun1
. 2019.08.11 07:51:09 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2019.08.11 07:51:09 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.08.11 07:51:09 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.08.11 07:51:09 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.08.11 07:51:09 - OpenVPN > /sbin/ifconfig utun1 10.9.254.180 10.9.254.180 netmask 255.255.255.0 mtu 1500 up
. 2019.08.11 07:51:09 - OpenVPN > /sbin/route add -net 10.9.254.0 10.9.254.180 255.255.255.0
. 2019.08.11 07:51:09 - OpenVPN > add net 10.9.254.0: gateway 10.9.254.180
. 2019.08.11 07:51:09 - OpenVPN > /sbin/ifconfig utun1 inet6 fde6:7a:7d20:5fe::10b2/64
. 2019.08.11 07:51:09 - OpenVPN > add_route_ipv6(fde6:7a:7d20:5fe::/64 -> fde6:7a:7d20:5fe::10b2 metric 0) dev utun1
. 2019.08.11 07:51:09 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:5fe:: -prefixlen 64 -iface utun1
. 2019.08.11 07:51:09 - OpenVPN > route: writing to routing socket: File exists
. 2019.08.11 07:51:09 - OpenVPN > add net fde6:7a:7d20:5fe::: gateway utun1: File exists
. 2019.08.11 07:51:09 - OpenVPN > /sbin/route add -net 184.75.221.213 10.0.0.1 255.255.255.255
. 2019.08.11 07:51:09 - OpenVPN > add net 184.75.221.213: gateway 10.0.0.1
. 2019.08.11 07:51:09 - OpenVPN > /sbin/route add -net 0.0.0.0 10.9.254.1 128.0.0.0
. 2019.08.11 07:51:09 - OpenVPN > add net 0.0.0.0: gateway 10.9.254.1
. 2019.08.11 07:51:09 - OpenVPN > /sbin/route add -net 128.0.0.0 10.9.254.1 128.0.0.0
. 2019.08.11 07:51:09 - OpenVPN > add net 128.0.0.0: gateway 10.9.254.1
. 2019.08.11 07:51:09 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:5fe::1 metric -1) dev utun1
. 2019.08.11 07:51:09 - OpenVPN > /sbin/route add -inet6 :: -prefixlen 3 -iface utun1
. 2019.08.11 07:51:09 - OpenVPN > add net ::: gateway utun1
. 2019.08.11 07:51:09 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:5fe::1 metric -1) dev utun1
. 2019.08.11 07:51:09 - OpenVPN > /sbin/route add -inet6 2000:: -prefixlen 4 -iface utun1
. 2019.08.11 07:51:09 - OpenVPN > add net 2000::: gateway utun1
. 2019.08.11 07:51:09 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:5fe::1 metric -1) dev utun1
. 2019.08.11 07:51:09 - OpenVPN > /sbin/route add -inet6 3000:: -prefixlen 4 -iface utun1
. 2019.08.11 07:51:09 - OpenVPN > add net 3000::: gateway utun1
. 2019.08.11 07:51:09 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:5fe::1 metric -1) dev utun1
. 2019.08.11 07:51:09 - OpenVPN > /sbin/route add -inet6 fc00:: -prefixlen 7 -iface utun1
. 2019.08.11 07:51:09 - OpenVPN > add net fc00::: gateway utun1
. 2019.08.11 07:51:09 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.9.254.1, fde6:7a:7d20:5fe::1)
. 2019.08.11 07:51:10 - DNS of a network adapter forced (Bluetooth PAN, from Automatic to 10.9.254.1, fde6:7a:7d20:5fe::1)
. 2019.08.11 07:51:10 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.9.254.1, fde6:7a:7d20:5fe::1)
. 2019.08.11 07:51:10 - Routes, added a new route, 184.75.221.211 for gateway 10.9.254.1
. 2019.08.11 07:51:10 - Routes, added a new route, 2606:6080:1001:17:9ea4:71f9:d294:d7b7 for gateway fde6:7a:7d20:5fe::1
. 2019.08.11 07:51:10 - Flushing DNS
. 2019.08.11 07:51:10 - macOS - PF rules updated, reloading
I 2019.08.11 07:51:12 - Checking route IPv4
I 2019.08.11 07:51:12 - Checking route IPv6
! 2019.08.11 07:51:13 - Connected.
. 2019.08.11 07:51:13 - OpenVPN > Initialization Sequence Completed
. 2019.08.11 08:01:06 - Updating systems & servers data ...
. 2019.08.11 08:01:07 - Systems & servers data update completed
Edited ... by giganerd
Apply LOG formatting to logs
