airuser28 2 Posted ... hello people, i have a question because of the network lock in airvpn, i activated it but 1 problem: its only working when the AIRVPN client is started, i chose airvpn auto windows start but the problem is that still with ssd its taking maybe 5 seconds to start (it starts with loading beam). the question is how can if fix that? example: the airvpn client eddie crashes (latest version ofc) -> my internet IS UNPROTECTED! thanks for any help regards 1 1 Axarius and HelpNeeded39 reacted to this Quote Share this post Link to post
Staff 10494 Posted ... Hello! 1) Network Lock is not meant to survive a reboot. It's an intended behavior and a very wise decision. 2) Network Lock will remain enforced if Eddie crashes, contrarily to what you claim. It's a set of firewall rules. BUT of course if Eddie crashes at the very start then of course Network Lock will not be set. 3) If you wish that your system is always isolated from the Internet during bootstrap, set a permanent firewall rule (or two, if you have IPv6) blocking all outbound traffic. That's all, because when Network Lock is activated, Eddie will rewrite rules to allow communications to Air VPN servers. Similarly, when Network Lock is disabled by your command, Eddie will restore your previous firewall rules, which will block again all traffic (so you don't need to worry not even during the shutdown). Kind regards 1 HelpNeeded39 reacted to this Quote Share this post Link to post
airnoob 13 Posted ... (edited) > set a permanent firewall rule (or two, if you have IPv6) blocking all outbound traffic. How? I did this on Windows 10 and Eddie just refuses to connect, maybe step by step would be useful for noobs like me please? Edited ... by airnoob 1 HelpNeeded39 reacted to this Quote Share this post Link to post
HelpNeeded39 1 Posted ... On 8/7/2019 at 12:40 PM, Staff said: Hello! 1) Network Lock is not meant to survive a reboot. It's an intended behavior and a very wise decision. 2) Network Lock will remain enforced if Eddie crashes, contrarily to what you claim. It's a set of firewall rules. BUT of course if Eddie crashes at the very start then of course Network Lock will not be set. 3) If you wish that your system is always isolated from the Internet during bootstrap, set a permanent firewall rule (or two, if you have IPv6) blocking all outbound traffic. That's all, because when Network Lock is activated, Eddie will rewrite rules to allow communications to Air VPN servers. Similarly, when Network Lock is disabled by your command, Eddie will restore your previous firewall rules, which will block again all traffic (so you don't need to worry not even during the shutdown). Kind regards Hello, could you please make a tutorial? I tried this but Im doing something wrong, because the client cant connect to the AIR servers after I set the firewall rules ... A permanent network locker is for other vpn providers normal, but here? Why you dont just make a option in the Eddie client? Anyway a tutorial would be great 1 Axarius reacted to this Quote Share this post Link to post
