Not connected, Your IP: 216.73.216.85
cayne469
ASUS CM 32-AC2600 wont work
Just got a Asus cm32-ac2600 and have tried everything i've read to no avail. I don't see any custom firmware either, am I SOL on this one? I found a thread somewhere in my searches that someone did get it to work. Just wondering if anyone else has and how.
You haven't tried everything, otherwise it would work. :D
From what I gather, the CM32-AC2600 is an
AC2600 with DOCSIS capability. I can imagine this needs a slightly different firmware. What are you trying to do, anyway? What do you want to install/flash?
I exchanged it for something else. I just wanted to get airvpn to work on it, but the logs kept showing it was trying to connect as PPTP5 , and the stock firmware wont allow for the full file to be uploaded due to a character limit in the firmware. There is no custom firmware that I could find.
What the hell is this? Why? -.- Doesn't matter. Hope everything works now.
Thank you, all is well, i just need to figure out a ip/routing conflict but I believe I know the fix. Thank you for you reply, its nice to see people who care. :)
