last0ne 0 Posted ... I choice today to use different wife channels to avoid conflicting with other networks and as a result eddie kept disconnecting me, and not aloud me to quit the app, I have to put wifi in back on in automatic connection rather than the channels I selected (e.g.2, and 36)? if I chose to do selected a channel rather than automatic detection why I can't? today eddie keeps on disconect me several times , in the middle of downloadin files. KR Eddie_20190614_190405.txt Hide last0ne's signature Hide all signatures I've learned.... That being kind is more important than being right. Share this post Link to post
Tech Jedi Alex 1531 Posted ... I've seen this quite often. If your device predominantly uses the 5G WiFi band, connecting with OpenVPN via UDP will result in exactly the symptoms you are seeing. Either use a cable or, if that is not possible, not practical or simply not wanted, resort to the 2.4G band or use TCP to connect. Port and server do not matter. 1 last0ne reacted to this Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
zhang888 1067 Posted ... On 6/15/2019 at 2:04 AM, last0ne said: to use different wife channels to avoid conflicting with other Depends on the wife But yes, 5G is less crowded and if both your client and router can use those channels, they will have less interference, however you must check if you don't actually maximize your router speed, on cheap routers without proper QoS if you saturate your entire channel they will go unresponsive. 1 last0ne reacted to this Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
