mcharris
[SOLVED] Tauri Port Forwarding Problem
All my assigned ports are closed on the Tauri server. When I connect to ANY other server, the correct ports are open. I would prefer to use the Tauri server because it gives me the best connectivity. Any chance you can resolve this issue?
We just checked that the correct ports are forwarded to your account current VPN IP address on Tauri. Can you please double check?
Thanks for the quick response. Unfortunatley, they are still closed. As I said before, I never had a problem before. I haven't changed any settings.
Sorry, bug detected. It should be fixed for your account now, can you please check once again (you don't need to disconnect and reconnect)?
Thank you for your patience.
