davidcrickett 0 Posted ... Eddie works flawlessly, also on my Android now! When restarting Ubuntu Disko Dingo 19.04, Eddie is not starting up by itself, though I have set it to in the settings. I have to manually open Eddie and type in my admin password. Is this normal Ubuntu behavior? (Since you normally seldom restart, like you do all the time in Windows). ... and, btw, I can't do this-> (see image 1) ... and (sry) I get a question mark in the upper right corner? (I have imported the key file) (image 2) Quote Share this post Link to post
davidcrickett 0 Posted ... Well, I SOLVED the problem by manually adding Eddie to Startup Applications, and restarted. Eddie then asks for admin password, and the questionmark is gone too. Well, no, it has returned... ? :S I still can't add the Eddie deb in terminal, though... Quote Share this post Link to post
Tech Jedi Alex 1531 Posted ... 4 hours ago, davidcrickett said: .. and, btw, I can't do this-> (see image 1) The deb line must be appended to /etc/apt/sources.list or, as a best practice, as a separate file in /etc/apt/sources.list.d/eddie.list for example. (If you do the latter, check for the permissions and make sure it's readable for "other". Execute sudo chmod o+r /etc/apt/sources.list.d/eddie.list as a precaution.) 4 hours ago, davidcrickett said: Eddie is not starting up by itself, though I have set it to in the settings. Instead of executing eddie-ui, you could try launching mono instead and provide Eddie-UI.exe as an argument: mono /usr/lib/eddie-ui/Eddie-UI.exe I didn't test it, but seeing as Eddie is a .NET app, it could very well work. Try it out and report at your convenience. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
