anonuem 1 Posted ... since yesterday i cant connect with eddie (2.16.3 AND 2.17.2) to any airvpn server.. i try tunnelblick, but the same problem. eddie cant connect. with my tablet and openvpn it works perfect. log: I 2019.06.01 11:14:10 - Session starting. I 2019.06.01 11:14:10 - Checking authorization ... ! 2019.06.01 11:14:10 - Connecting to Capricornus (Belgium, Brussels) . 2019.06.01 11:14:10 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018 . 2019.06.01 11:14:10 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2019.06.01 11:14:10 - Connection to OpenVPN Management Interface . 2019.06.01 11:14:10 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2019.06.01 11:14:10 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.06.01 11:14:10 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.06.01 11:14:10 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.06.01 11:14:10 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.06.01 11:14:10 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]194.187.251.93:443 . 2019.06.01 11:14:10 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2019.06.01 11:14:10 - OpenVPN > UDP link local: (not bound) . 2019.06.01 11:14:10 - OpenVPN > UDP link remote: [AF_INET]194.187.251.93:443 . 2019.06.01 11:14:10 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2019.06.01 11:14:43 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2019.06.01 11:14:43 - OpenVPN > SIGTERM received, sending exit notification to peer . 2019.06.01 11:14:47 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2019.06.01 11:14:47 - Disconnecting . 2019.06.01 11:14:47 - Connection terminated. I 2019.06.01 11:14:49 - Cancel requested. ! 2019.06.01 11:14:49 - Session terminated. 1 Michaelalofs reacted to this Quote Share this post Link to post
anonuem 1 Posted ... problem solved, i think... what was the only change yesterday? there was an update from adguard to 2.0.4.552. i put adg. out and tried eddie again. but it didn't work. then, for safety, adg. out AND a reboot of my computer. after that the connection with eddie worked again. i don't know why and where adg. block airVPN. Quote Share this post Link to post
Tech Jedi Alex 1518 Posted ... I'm reading this more often these days. One user in Can't connect, keeps reconnecting identified a setting in AdGuard causing this. Can you try it? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
anonuem 1 Posted ... I've checked with adguard, here's their answer: Unfortunately you have a rare problem. It only affects the small number of our users and is usually associated with data corruption with AdGuard settings. This happens due to problems with updates, work of various cleaners, device malfunctions, etc. If the restart does not help, please use the articles about reinstalling the program: https://kb.adguard.com/en/macos/installation Quote Share this post Link to post
anonuem 1 Posted ... adguard is working on the problem... https://github.com/AdguardTeam/AdguardForMac/issues/536 Quote Share this post Link to post
anonuem 1 Posted ... i have just received a nightly from AG. now everything is running perfectly again. the next update from AG should have solved the problem. 1 Tech Jedi Alex reacted to this Quote Share this post Link to post
