Not connected, Your IP: 216.73.216.20
tutyy
routes option not work!
hello, i have add some ip to routes option (setting > routes )  outside vpn but routes not work ! and go through vpn tunnel still !
network lock is on.
what i do?
I had same issue about half year ago. I made bug report and I think they were able to confirm it as an issue but no fix has arrived as far as I know. If you are using gnu/linux you can set it go outside tunnel manually with command like this
sudo ip route add 169.0.0.1/24 via 169.2.2.12 dev enp2s0u
Unprofessional explanation: sudo ip route add <ip you want to set outside vpn> via <your default gateway> dev <network interface you want to use>'
You will still need to have it also in (settings > routes) to pass network lock.
