chaosfacer 0 Posted ... the error i get when trying to connect using the app sya "The underlinding connection was closed. Could not establish trust relationship for the SSL/TLS secure channel I dont know what to do now everything worked fine yesturday Quote Share this post Link to post
Staff 10336 Posted ... the error i get when trying to connect using the app sya "The underlinding connection was closed. Could not establish trust relationship for the SSL/TLS secure channelI dont know what to do now everything worked fine yesturdayHello!We need additional information to support you properly. Can you please tell us your device, OS and client (for example Air client, OpenVPN direct, OpenVPN GUI, Tunnelblick...) you're using to connect? Also, can you please send us the logs of the client?Kind regards Quote Share this post Link to post
chaosfacer 0 Posted ... Im using windows 7 and airvpn client also i do not know where the logs are stored so if you can tell me ill post them thanks for your help Quote Share this post Link to post
Staff 10336 Posted ... Im using windows 7 and airvpn client also i do not know where the logs are stored so if you can tell me ill post them thanks for your helpHello!Please right-click on the Air dock icon, select "Logs", click on "Copy to clipboard" and finally paste.We're looking forward to hearing from you.Kind regards Quote Share this post Link to post
